While trying to do yay dstat I get this list:
`yay dstat` output
18 aur/cloudstation-3.0 3111-1 (+0 0.00) (Out-of-date: 2024-01-25)
Synology Cloud Station. This version is for DSM versions that only works with CloudStation 3.0 (DSM 4.2 on a DS209 for example)
17 aur/uksmdstats-git 1.2.8.r108.20231220.65b9974-1 (+0 0.00)
Statistics output for uksmd, a userspace KSM helper daemon. Latest git checkout.
16 aur/r-readstata13 0.10.1-1 (+0 0.00)
Import 'Stata' Data Files
15 aur/uksmd-cachyos-nosystemd-git 1.2.8.r108.20231220.65b9974-3 (+0 0.00)
Userspace KSM helper daemon. CachyOS-version with 'uksmdstats'. Without systemd dependency, latest git checkout.
14 aur/synodl 0.5.3-1 (+1 0.00)
Command-line client for Synology's DownloadStation
13 aur/loadstat 0.1.1-2 (+1 0.00)
Calculate load averages adjusted by number of cores
12 aur/kdstatemachineeditor 1.2.8-1 (+1 0.00) (Orphaned)
11 aur/systray-mdstat 1.1.0-1 (+2 0.00) (Orphaned) (Out-of-date: 2022-02-21)
System tray icon indicating the state of local Linux Software (MD) RAID by checking /proc/mdstat periodically
10 aur/ddstats-rust-git 0.6.10.1-1 (+0 0.00)
9 aur/ddstats-rust-bin 4-3 (+0 0.00)
8 aur/python2-mdstat 1.0.4-2 (+0 0.00) (Out-of-date: 2023-11-29)
Convert your /proc/mdstat file into an object usable in Python
7 aur/python-mdstat 1.0.4-2 (+0 0.00) (Out-of-date: 2023-11-29)
6 aur/python-pyreadstat 1.2.1-1 (+1 0.00) (Orphaned) (Out-of-date: 2023-11-07)
Reads sas, spss and stata files into Pandas data frames.
5 aur/dbuildstat-git r9.6ab0467-1 (+1 0.00) (Out-of-date: 2024-01-04)
Measure and visualize per-module build times of D projects
4 aur/jedstate-git 1.0.0.r0.g81d6d40-1 (+1 0.65)
S-Lang module for the JED editor to remember its cursor position across invocations (built from latest commit)
3 aur/pidgin-gtalksharedstatus 0.2.5-2 (+37 0.00)
Adds Google Shared Status compatibility that permits to set the status for all the resources connected. This allows to go Invisible on GTalk.
2 extra/readstat 1.1.9-1 (143.6 KiB 383.9 KiB)
Command-line tool (+ C library) for converting SAS, Stata, and SPSS files
1 extra/sysstat 12.7.5-1 (452.1 KiB 1.6 MiB) (Installed)
a collection of performance monitoring tools (iostat,isag,mpstat,pidstat,sadf,sar)
==> Packages to install (eg: 1 2 3, 1-3 or ^4)
Searching the Arch repos:
So where is it? How can I get it? Could it be that my mirrors are simply not having it?
For reference, I’ve ran this shortly after I finished Manjaro’s installtion:
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
So the US mirrors are definitely not on top of the list, in case that matters.
