Hi everyone! Is there a place I can learn how the Manjaro repos are updated? For instance, who updates the thousands of software in the stable repo?
Thanks!
oddperson
Thanks!
oddperson
Lot’s of the part is automated.
The origin of many packages that are build the same are using the Arch’s packages. Arch Linux - Package Search
The packages you isntall from AUR has nothing to do with Manjaro development, they are for all major Arch based distributions.
However Manjaro has more packages than Arch linux has because they are projects Manjaro specific like MHWD.
Thanks for the info! How does someone submit their software to the Manjaro repo (since it is different than arch)?
They are mostly in sync as far as I know.
The packaging is the same, no difference there.
You can showcase it here in the forum if is yours, and the team will decide about a PCKBUILD.
Install pacui
and browse the installed packages with option 4 X
Package manager UI
| 1 Update System 2 Maintain System |
| 3 Install Packages 4 Remove Packages and Deps |
| 5 Dependency Tree 6 Reverse Dependency Tree |
| 7 List Package Files 8 Search Package Files |
9 Roll Back System Z Fix Pacman Errors
Y Edit Config Files X List Packages by Size
| W Force Update AUR V List Installed from AUR |
Press number or marked letter H Help 0 Quit
You get the list of installed packages which you can remove (but don’t hit Enter to remove the package, pres Esc instead to leave; or better avoid it and see the alternative). You can enter the first letters or some letters from the middle of the package name and get a filtered list.
(Can’t find a current video how it works.)
[Recommendation]: Select option X List packages by size
, it will list the installed packages by size, and you can still filter the list.
Enter string to filter list > gc < 10/1372
Navigate with PageUp / PageDown. ESC to quit.
> 148.88 MiB - gcc-libs
147.32 MiB - gcc
104.67 MiB - lib32-gcc-libs
5.79 MiB - gcr
1.33 MiB - libgcrypt
1.12 MiB - libsigc++
0.90 MiB - lib32-libgcrypt
0.73 MiB - gc
0.38 MiB - gcab
0.15 MiB - pkgconf +----------------------------------------------------------------------------------------------------------------+
| Installed package info: 1/34 |
| Version : 10.2.0-3 |
| Description : Runtime libraries shipped by GCC |
| Architecture : x86_64 |
| URL : https://gcc.gnu.org |
| Licenses : GPL LGPL FDL custom |
| Groups : None |
| Provides : gcc-libs-multilib libgo.so=16-64 libgfortran.so=5-64 libgphobos.so=1-64 | | libubsan.so=1-64 libasan.so=6-64 libtsan.so=0-64 liblsan.so=0-64 | | Depends On : glibc>=2.27 |
| Optional Deps : None |
| Required By : aom aspell atomicparsley avisynthplus base blas brotli chromaprint clucene db |
| double-conversion elfutils exiv2 fftw flac gc gcc gettext glslang gmp |
| gnustep-base gnutls gptfdisk graphite-mozilla groff gtest hunspell icu intel-gmmlib |
| intel-media-driver jack js60 js68 js78 ladspa libbs2b libcdio libde265 libelf |
| libgme libimagequant libmfx libmodplug libnumbertext libproxy libreoffice-fresh |
| libsidplay libsigc++ libsoxr libstdc++5 libvoikko libvpx libwpd libwpe libzen |
| llvm-libs lshw mjpegtools ncurses openal p7zip pcre pcre2 poppler portaudio |
| powertop protobuf rav1e re2 rubberband sane shaderc smartmontools snappy |
| soundtouch spirv-tools tbb thin-provisioning-tools uchardet unarchiver v4l-utils |
| vamp-plugin-sdk vid.stab virtualbox vmaf webrtc-audio-processing wxgtk-common x265 |
| xapian-core zeromq zita-alsa-pcmi zita-resampler zxing-cpp |
| Optional For : None |
| Conflicts With : None |
| Replaces : gcc-libs-multilib libgphobos |
| Installed Size : 148.88 MiB |
| Packager : Evangelos Foutras <foutrelis@archlinux.org> |
| Build Date : Wed Sep 30 09:38:18 2020 |
| Install Date : Fri Oct 2 01:11:42 2020 |
| Install Reason : Explicitly installed |
| Install Script : No |
| Validated By : Signature | +----------------------------------------------------------------------------------------------------------------+
And there you see "Packager: ", here it is an Arch packager. For Manjaro packages you will see a packager from the Manjaro Team.
Does @excalibur1234 still work on pacui, I didn’t see much pacui activity what’ve happen to him?
This is in addition to the above responses.
These links are from the main menu:
Also:
Manjaro Testing receives Archlinux repositories on a daily basis (if I’m reading the diagram correctly). Does this include community, core, extra? linux-doc
is in the Archlinux Core, but not Manjaro. So there is some selection going on?
Update: The above SHOULD HAVE been Manjaro Unstable and not Testing.
Three was a lot of work on it during bmenu revamp by @pux.
you can see all pacui-related activity on github:
i have not developed major new features for a while, but pacui is still my favorite “package manager” and i use it almost every day.
i have not taken a look at the github page for a while, it seems there are new pull requests and issues waiting. have to take a look at them…
No problem, I thought you left as your profile is hidden from public , the one PR from me is for Arch’s sake. I still cannot wrap my head around that they banished it from AUR.
Yes I do too excellent script
Not quite. Backup one step in the diagram, you’ll see Unstable gets daily updates.
Yes, and multilib.
Some Arch-specific packages are not in the Manjaro repo. Some will not work and some are not applicable since Manjaro has it’s own kernel and packages.
Thank you all for the fantastic information!
What about dde himself?
$ pacman -Si deepin-desktop-base
Repository : community
Version : 2:2020.04.12.2-2
Description : Base component for Deepin
Architecture : any
URL : https://github.com/linuxdeepin/deepin-desktop-base
Licenses : GPL3
Groups : deepin
Provides : None
Depends On : None
Replaces : None
Download Size : 15.59 KiB
Installed Size : 45.78 KiB
Packager : Felix Yan <felixonmars@archlinux.org>
Build Date : Fri 26 Jun 2020 05:55:54 AM PDT
Validated By : MD5 Sum SHA-256 Sum Signature
