Where do I report manjaro kernel issues?
I’m on manjaro unstable branch and want to report problems in the latest 5.15.6-2-MANJARO kernel.
What happened is that i updated my system using sudo pacman -Syu and it updated everything including my kernel. In the latest kernel, one of my usb ports was not detecting and also there was an errror while building the dkms modules for the kernel. For the time being, i downgraded my kernel to 5.15.2-2-MANJARO and it’s respective headers and everything works flawlessly. Here is the log from /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/make.log:
DKMS make.log for rtl8821ce-1.0.5.r128.gf93db73 for kernel 5.15.6-2-MANJARO (x86_64)
Sunday 05 December 2021 08:46:28 AM IST
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.15.6-2-MANJARO/build M=/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build  modules
make[1]: Entering directory '/usr/lib/modules/5.15.6-2-MANJARO/build'
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_cmd.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_security.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_debug.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_io.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_ioctl_query.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_ioctl_set.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_ieee80211.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_mlme.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_mlme_ext.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_mi.o
/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_mlme.c: In function ‘rtw_drv_scan_by_self’:
/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_mlme.c:3161:17: warning: this ‘else’ clause does not guard... [-Wmisleading-indentation]
 3161 |                 else
/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_mlme.c:3164:25: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
 3164 |                         goto exit;
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_wlan_util.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_vht.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_pwrctrl.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_rf.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_chplan.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_recv.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_sta_mgt.o
/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_rf.c: In function ‘dump_txpwr_lmt’:
/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_rf.c:765:9: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
  765 |         if (IS_HARDWARE_TYPE_JAGUAR_AND_JAGUAR2(adapter))
In file included from /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/include/drv_types.h:60,
                 from /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_rf.c:17:
/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/include/rtw_debug.h:220:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
  220 |         do {\
/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_rf.c:767:17: note: in expansion of macro ‘RTW_PRINT_SEL’
  767 |                 RTW_PRINT_SEL(sel, "txpwr_lmt_5g_20_40_ref:0x%02x\n", rfctl->txpwr_lmt_5g_20_40_ref);
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_ap.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/mesh/rtw_mesh.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/mesh/rtw_mesh_pathtbl.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/mesh/rtw_mesh_hwmp.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_xmit.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_p2p.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_rson.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_tdls.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_br_ext.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_iol.o
  CC [M]  /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_sreset.o
/var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_br_ext.c:20:18: fatal error: net/ipx.h: No such file or directory
   20 |         #include <net/ipx.h>
compilation terminated.
make[2]: *** [scripts/Makefile.build:277: /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build/core/rtw_br_ext.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:1868: /var/lib/dkms/rtl8821ce/1.0.5.r128.gf93db73/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.15.6-2-MANJARO/build'
make: *** [Makefile:2244: modules] Error 2```
why not here
thanks
Please don’t post into update threads. This forum is the correct one.
That is your issue … This is due to kernel commit 6c9b40844751 (“net: Remove net/ipx.h and uapi/linux/ipx.h header files”), merged in v5.15-rc1
alr thanks
