Hi. I want to change this settings but I can’t find it the same way as where it is in kde plasma.
Is there a way to configure it?
thanks.
thanks.
there’s no GUI for this but there’s a terminal command available. I get it in this link.
setxkbmap -option lv3:lalt_switch -option lv3:ralt_alt
In addition to the above:
In KDE, most of those setting are itemized under Settings > Input Devices > Keyboard.
In XFCE, those options can be viewed by either:
man xkeyboard-config
and then those options are used in the command setxkbmap
. The older command is xmodmap
There’s a short user-friendly blog entry that discussions the two utilities.
Archlinux keyboard wiki pages:
