I’ve setup a brand new Manjaro-Setup, but don’t find dig or nslookup.
Which package do I need to install ?
Bizarrely, they’re both owned by bind. Seems a bit of overkill installing that for them, but such is life.
Ok, I’m surprised that I didn’t found it in a package like dnstools like in other distributions.
I thought I missed something ![]()
Or does there any alternatives to use for dig and nslookup which also good, but not bundled with bind?
Manjaro comes with ldns - which contains a dig equivalent - drill.
nice to hear, does it have the same syntax / parameters as dig. So I might add an alias in bash and don’t need to remember this new Tool-name ![]()
man drill
not the ape ![]()
Just FYI, one can discover what package includes which binaries like this:
First make sure you’re fully up to date and update your local database:
sudo pacman -Syu && sudo pacman -Fy
Then search for the binary names; i.e., with dig:
❯ pacman -F /usr/bin/dig
usr/bin/dig is owned by extra/bind 9.18.25-1
Or, as you can update and search the database at once, and it has no affect on your package sync;
sudo pacman -Fyx 'bin/dig'
And as you should always sync and update before/while installing, and that it can be combined too;
sudo pacman -Syu bind
