Logs you could look up:
journalctl -b -0
ls /var/log/lightdm
cat /var/log/Xorg.0.log
cat /var/log/Xorg.0.log.old
journalctl -b -0
ls /var/log/lightdm
Isnāt that specific to Windows only?
Anyway, since you use XFCE, just check or remove the file:
~/.config/xfce4/xfconf/xfce-perchannel-xml/displays.xml
It will regenerate after reboot.
Iāve checked the BIOS settings, and there is indeed no way to disable the Intel integrated GPU from there.
The closest setting I could find was the Primary Display setting, with options Auto, Intel HD Graphics, and NVIDIA HD Graphics, and this description:
This field determines which video controller will become the primary display when multiple controllers are available in the system.
If you select a device other than what you are currently using, you will have to reconnect your video cable to your selected device.
NOTE: When Auto is not selected, the onboard graphics device will be present and enabled.
The last part sounds like it might do it, but that doesnāt seem to be the case. When āAutoā is selected, the onboard graphics is present and enabled too. The note is just informing us that the iGPU doesnāt get disabled by selecting the dGPU. Edit: Iām not sure why some words are bolded in the monospace text block above. I didnāt do that in markdown.
I have these now. I tried to post their output all in this, but got Body is limited to 150000 characters; you entered 324088. from the forum software. I realized that some of it shows exactly what software Iām running that may not be related, so decided to avoid posting it all for now. If I can trim these to exactly what we need to see, I can post them. Iāll browse them now.
OK, Iāll try that. That sounds promising.
No. Hereās an ubuntu wiki article about it: https://wiki.ubuntu.com/IntelQuickSyncVideo
Aha! I see something in here.
[ 7.243] (II) Initializing extension GLX
[ 7.243] (II) Indirect GLX disabled.
[ 7.243] (II) GLX: Another vendor is already registered for screen 0
Hereās the full log:
[ 6.946]
X.Org X Server 1.20.8
[ 6.946] Build Operating System: Linux Manjaro Linux
[ 6.946] Current Operating System: Linux alex-pc 5.8.3-2-MANJARO #1 SMP PREEMPT Sat Aug 22 12:35:25 UTC 2020 x86_64
[ 6.946] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=40346435-d703-431f-801b-16e28237cd64 rw quiet resume=UUID=87f9c587-557a-4003-a0fa-bd01450b24b2
[ 6.946] Build Date: 01 August 2020 07:25:56AM
[ 6.946]
[ 6.946] Current version of pixman: 0.40.0
[ 6.946] Before reporting problems, check http://wiki.x.org
[ 6.946] Markers: (--) probed, (**) from config file, (==) default setting,
[ 6.946] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Sep 8 00:12:02 2020
[ 6.949] (==) Using config file: "/etc/X11/xorg.conf"
[ 6.949] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.949] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.952] (==) ServerLayout "layout"
[ 6.952] (**) |-->Screen "Screen0" (0)
[ 6.952] (**) | |-->Monitor "Monitor0"
[ 6.953] (**) | |-->Device "Device0"
[ 6.953] (**) | |-->GPUDevice "Device0"
[ 6.953] (==) Automatically adding devices
[ 6.953] (==) Automatically enabling devices
[ 6.953] (==) Automatically adding GPU devices
[ 6.953] (==) Automatically binding GPU devices
[ 6.953] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.955] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 6.955] Entry deleted from font path.
[ 6.956] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 6.956] Entry deleted from font path.
[ 6.956] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 6.956] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 6.956] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 6.956] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 6.956] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 6.956] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.956] (II) The server relies on udev to provide the list of input devices.
[ 6.956] (II) Module ABI versions:
[ 6.956] X.Org ANSI C Emulation: 0.4
[ 6.956] X.Org Video Driver: 24.1
[ 6.956] X.Org XInput driver : 24.1
[ 6.956] X.Org Server Extension : 10.0
[ 6.957] (++) using VT number 7
[ 6.957] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.959] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.959] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 6.961] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 6.961] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 6.962] (--) PCI: (0@0:2:0) 8086:1912:1028:06b8 rev 6, Mem @ 0xdd000000/16777216, 0xb0000000/268435456, I/O @ 0x0000f000/64
[ 6.962] (--) PCI:*(1@0:0:0) 10de:1b06:3842:6696 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 6.962] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 6.962] (II) LoadModule: "glx"
[ 6.970] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.985] (II) Module glx: vendor="X.Org Foundation"
[ 6.985] compiled for 1.20.8, module version = 1.0.0
[ 6.985] ABI class: X.Org Server Extension, version 10.0
[ 6.985] (II) LoadModule: "nvidia"
[ 6.985] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 6.994] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 6.994] compiled for 1.6.99.901, module version = 1.0.0
[ 6.994] Module class: X.Org Video Driver
[ 6.996] (II) NVIDIA dlloader X Driver 450.66 Wed Aug 12 19:44:12 UTC 2020
[ 6.996] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 6.998] (II) Loading sub module "fb"
[ 6.998] (II) LoadModule: "fb"
[ 6.999] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.000] (II) Module fb: vendor="X.Org Foundation"
[ 7.000] compiled for 1.20.8, module version = 1.0.0
[ 7.000] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.000] (II) Loading sub module "wfb"
[ 7.000] (II) LoadModule: "wfb"
[ 7.001] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.002] (II) Module wfb: vendor="X.Org Foundation"
[ 7.002] compiled for 1.20.8, module version = 1.0.0
[ 7.002] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.002] (II) Loading sub module "ramdac"
[ 7.003] (II) LoadModule: "ramdac"
[ 7.003] (II) Module "ramdac" already built-in
[ 7.005] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 7.005] (==) NVIDIA(0): RGB weight 888
[ 7.005] (==) NVIDIA(0): Default visual is TrueColor
[ 7.005] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.005] (**) Option "AllowNVIDIAGpuScreens"
[ 7.005] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 7.006] (**) NVIDIA(0): Option "Stereo" "0"
[ 7.006] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[ 7.006] (**) NVIDIA(0): Option "VertRefresh" "DVI-D-0: 59.95; DP-5: 60.0"
[ 7.006] (**) NVIDIA(0): Option "SLI" "Off"
[ 7.006] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 7.006] (**) NVIDIA(0): Option "TripleBuffer" "on"
[ 7.006] (**) NVIDIA(0): Option "BaseMosaic" "off"
[ 7.006] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 7.006] (**) NVIDIA(0): Stereo disabled by request
[ 7.006] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 7.006] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 7.006] (**) NVIDIA(0): Option "MetaModes" "DVI-D-0: nvidia-auto-select +1920+0 {ForceCompositionPipeline=On}, DP-5: nvidia-auto-select +0+0"
[ 7.006] (**) NVIDIA(0): Enabling 2D acceleration
[ 7.006] (II) Loading sub module "glxserver_nvidia"
[ 7.006] (II) LoadModule: "glxserver_nvidia"
[ 7.006] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 7.061] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 7.061] compiled for 1.6.99.901, module version = 1.0.0
[ 7.061] Module class: X.Org Server Extension
[ 7.061] (II) NVIDIA GLX Module 450.66 Wed Aug 12 19:41:37 UTC 2020
[ 7.064] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 7.065] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 7.065] (--) NVIDIA(0): DFP-0 (boot)
[ 7.065] (--) NVIDIA(0): DFP-1
[ 7.065] (--) NVIDIA(0): DFP-2
[ 7.065] (--) NVIDIA(0): DFP-3
[ 7.065] (--) NVIDIA(0): DFP-4
[ 7.065] (--) NVIDIA(0): DFP-5
[ 7.065] (--) NVIDIA(0): DFP-6
[ 7.065] (--) NVIDIA(0): DFP-7
[ 7.065] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1080 Ti (GP102-A) at PCI:1:0:0 (GPU-0)
[ 7.065] (--) NVIDIA(0): Memory: 11534336 kBytes
[ 7.065] (--) NVIDIA(0): VideoBIOS: 86.02.39.00.90
[ 7.065] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 7.081] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): connected
[ 7.081] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): Internal TMDS
[ 7.081] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): 330.0 MHz maximum pixel clock
[ 7.081] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 7.081] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 7.081] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 7.081] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 7.081] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 7.081] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 7.081] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 7.081] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 7.081] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 7.081] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 7.081] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 7.081] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 7.081] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 7.081] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 7.081] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 7.081] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 7.081] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 7.081] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[ 7.145] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): connected
[ 7.145] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): Internal TMDS
[ 7.145] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): 600.0 MHz maximum pixel clock
[ 7.148] (II) NVIDIA(0): Validated MetaModes:
[ 7.148] (II) NVIDIA(0): "DVI-D-0:nvidia-auto-select+1920+0{ForceCompositionPipeline=On},DP-5:nvidia-auto-select+0+0"
[ 7.148] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 1200
[ 7.151] (--) NVIDIA(0): DPI set to (93, 95); computed from "UseEdidDpi" X config
[ 7.151] (--) NVIDIA(0): option
[ 7.151] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 7.151] (II) NVIDIA: access.
[ 7.154] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 7.154] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 7.154] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 7.154] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 7.154] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 7.154] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 7.154] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 7.154] (II) NVIDIA(0): Config Options in the README.
[ 7.167] (II) NVIDIA(0): Setting mode "DVI-D-0:nvidia-auto-select+1920+0{ForceCompositionPipeline=On},DP-5:nvidia-auto-select+0+0"
[ 7.238] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 7.239] (==) NVIDIA(0): Backing store enabled
[ 7.239] (==) NVIDIA(0): Silken mouse disabled
[ 7.239] (**) NVIDIA(0): DPMS enabled
[ 7.240] (II) Loading sub module "dri2"
[ 7.240] (II) LoadModule: "dri2"
[ 7.240] (II) Module "dri2" already built-in
[ 7.240] (II) NVIDIA(0): [DRI2] Setup complete
[ 7.240] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 7.241] (II) Initializing extension Generic Event Extension
[ 7.241] (II) Initializing extension SHAPE
[ 7.241] (II) Initializing extension MIT-SHM
[ 7.241] (II) Initializing extension XInputExtension
[ 7.241] (II) Initializing extension XTEST
[ 7.241] (II) Initializing extension BIG-REQUESTS
[ 7.242] (II) Initializing extension SYNC
[ 7.242] (II) Initializing extension XKEYBOARD
[ 7.242] (II) Initializing extension XC-MISC
[ 7.242] (II) Initializing extension SECURITY
[ 7.242] (II) Initializing extension XFIXES
[ 7.243] (II) Initializing extension RENDER
[ 7.243] (II) Initializing extension RANDR
[ 7.243] (II) Initializing extension COMPOSITE
[ 7.243] (II) Initializing extension DAMAGE
[ 7.243] (II) Initializing extension MIT-SCREEN-SAVER
[ 7.243] (II) Initializing extension DOUBLE-BUFFER
[ 7.243] (II) Initializing extension RECORD
[ 7.243] (II) Initializing extension DPMS
[ 7.243] (II) Initializing extension Present
[ 7.243] (II) Initializing extension DRI3
[ 7.243] (II) Initializing extension X-Resource
[ 7.243] (II) Initializing extension XVideo
[ 7.243] (II) Initializing extension XVideo-MotionCompensation
[ 7.243] (II) Initializing extension XFree86-VidModeExtension
[ 7.243] (II) Initializing extension XFree86-DGA
[ 7.244] (II) Initializing extension XFree86-DRI
[ 7.244] (II) Initializing extension DRI2
[ 7.244] (II) Initializing extension NV-GLX
[ 7.244] (II) Initializing extension NV-CONTROL
[ 7.244] (II) Initializing extension XINERAMA
[ 7.338] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 7.338] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.338] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.338] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.338] (II) LoadModule: "libinput"
[ 7.338] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.345] (II) Module libinput: vendor="X.Org Foundation"
[ 7.345] compiled for 1.20.8, module version = 0.30.0
[ 7.345] Module class: X.Org XInput Driver
[ 7.345] ABI class: X.Org XInput driver, version 24.1
[ 7.345] (II) Using input driver 'libinput' for 'Power Button'
[ 7.345] (**) Power Button: always reports core events
[ 7.345] (**) Option "Device" "/dev/input/event2"
[ 7.345] (**) Option "_source" "server/udev"
[ 7.350] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.350] (II) event2 - Power Button: device is a keyboard
[ 7.350] (II) event2 - Power Button: device removed
[ 7.377] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 7.377] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.377] (**) Option "xkb_model" "pc105"
[ 7.377] (**) Option "xkb_layout" "us"
[ 7.378] (**) Option "xkb_variant" "dvorak"
[ 7.394] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.395] (II) event2 - Power Button: device is a keyboard
[ 7.395] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 7.395] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 7.395] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 7.395] (**) Video Bus: Applying InputClass "system-keyboard"
[ 7.395] (II) Using input driver 'libinput' for 'Video Bus'
[ 7.395] (**) Video Bus: always reports core events
[ 7.395] (**) Option "Device" "/dev/input/event3"
[ 7.395] (**) Option "_source" "server/udev"
[ 7.395] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 7.395] (II) event3 - Video Bus: device is a keyboard
[ 7.396] (II) event3 - Video Bus: device removed
[ 7.444] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3/event3"
[ 7.444] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 7.444] (**) Option "xkb_model" "pc105"
[ 7.444] (**) Option "xkb_layout" "us"
[ 7.444] (**) Option "xkb_variant" "dvorak"
[ 7.445] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 7.445] (II) event3 - Video Bus: device is a keyboard
[ 7.445] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 7.445] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.445] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.445] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.445] (II) Using input driver 'libinput' for 'Power Button'
[ 7.445] (**) Power Button: always reports core events
[ 7.445] (**) Option "Device" "/dev/input/event1"
[ 7.445] (**) Option "_source" "server/udev"
[ 7.446] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.446] (II) event1 - Power Button: device is a keyboard
[ 7.446] (II) event1 - Power Button: device removed
[ 7.464] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 7.464] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 7.464] (**) Option "xkb_model" "pc105"
[ 7.464] (**) Option "xkb_layout" "us"
[ 7.464] (**) Option "xkb_variant" "dvorak"
[ 7.465] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.465] (II) event1 - Power Button: device is a keyboard
[ 7.465] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 7.465] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 7.465] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 7.465] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 7.465] (II) Using input driver 'libinput' for 'Sleep Button'
[ 7.465] (**) Sleep Button: always reports core events
[ 7.465] (**) Option "Device" "/dev/input/event0"
[ 7.465] (**) Option "_source" "server/udev"
[ 7.466] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 7.466] (II) event0 - Sleep Button: device is a keyboard
[ 7.466] (II) event0 - Sleep Button: device removed
[ 7.511] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 7.511] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 7.511] (**) Option "xkb_model" "pc105"
[ 7.511] (**) Option "xkb_layout" "us"
[ 7.511] (**) Option "xkb_variant" "dvorak"
[ 7.514] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 7.514] (II) event0 - Sleep Button: device is a keyboard
[ 7.516] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event7)
[ 7.516] (II) No input driver specified, ignoring this device.
[ 7.516] (II) This device may have been added with another device file.
[ 7.517] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event8)
[ 7.517] (II) No input driver specified, ignoring this device.
[ 7.517] (II) This device may have been added with another device file.
[ 7.518] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event9)
[ 7.518] (II) No input driver specified, ignoring this device.
[ 7.518] (II) This device may have been added with another device file.
[ 7.519] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event10)
[ 7.519] (II) No input driver specified, ignoring this device.
[ 7.519] (II) This device may have been added with another device file.
[ 7.520] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event11)
[ 7.520] (II) No input driver specified, ignoring this device.
[ 7.520] (II) This device may have been added with another device file.
[ 7.521] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event12)
[ 7.521] (II) No input driver specified, ignoring this device.
[ 7.521] (II) This device may have been added with another device file.
[ 7.522] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event6)
[ 7.522] (II) No input driver specified, ignoring this device.
[ 7.522] (II) This device may have been added with another device file.
[ 7.525] (II) config/udev: Adding input device ARCHISS PTR21 ARCHISS PTR21 (/dev/input/event257)
[ 7.525] (**) ARCHISS PTR21 ARCHISS PTR21: Applying InputClass "evdev keyboard catchall"
[ 7.525] (**) ARCHISS PTR21 ARCHISS PTR21: Applying InputClass "libinput keyboard catchall"
[ 7.525] (**) ARCHISS PTR21 ARCHISS PTR21: Applying InputClass "system-keyboard"
[ 7.525] (II) Using input driver 'libinput' for 'ARCHISS PTR21 ARCHISS PTR21'
[ 7.525] (**) ARCHISS PTR21 ARCHISS PTR21: always reports core events
[ 7.525] (**) Option "Device" "/dev/input/event257"
[ 7.525] (**) Option "_source" "server/udev"
[ 7.528] (II) event257 - ARCHISS PTR21 ARCHISS PTR21: is tagged by udev as: Keyboard
[ 7.529] (II) event257 - ARCHISS PTR21 ARCHISS PTR21: device is a keyboard
[ 7.529] (II) event257 - ARCHISS PTR21 ARCHISS PTR21: device removed
[ 7.551] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0/0003:2BE8:0005.0006/input/input38/event257"
[ 7.551] (II) XINPUT: Adding extended input device "ARCHISS PTR21 ARCHISS PTR21" (type: KEYBOARD, id 10)
[ 7.551] (**) Option "xkb_model" "pc105"
[ 7.551] (**) Option "xkb_layout" "us"
[ 7.551] (**) Option "xkb_variant" "dvorak"
[ 7.555] (II) event257 - ARCHISS PTR21 ARCHISS PTR21: is tagged by udev as: Keyboard
[ 7.555] (II) event257 - ARCHISS PTR21 ARCHISS PTR21: device is a keyboard
[ 7.558] (II) config/udev: Adding input device ARCHISS PTR21 ARCHISS PTR21 Mouse (/dev/input/event258)
[ 7.558] (**) ARCHISS PTR21 ARCHISS PTR21 Mouse: Applying InputClass "evdev pointer catchall"
[ 7.558] (**) ARCHISS PTR21 ARCHISS PTR21 Mouse: Applying InputClass "libinput pointer catchall"
[ 7.558] (II) Using input driver 'libinput' for 'ARCHISS PTR21 ARCHISS PTR21 Mouse'
[ 7.558] (**) ARCHISS PTR21 ARCHISS PTR21 Mouse: always reports core events
[ 7.558] (**) Option "Device" "/dev/input/event258"
[ 7.558] (**) Option "_source" "server/udev"
[ 7.562] (II) event258 - ARCHISS PTR21 ARCHISS PTR21 Mouse: is tagged by udev as: Mouse
[ 7.562] (II) event258 - ARCHISS PTR21 ARCHISS PTR21 Mouse: device is a pointer
[ 7.563] (II) event258 - ARCHISS PTR21 ARCHISS PTR21 Mouse: device removed
[ 7.614] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.1/0003:2BE8:0005.0007/input/input39/event258"
[ 7.614] (II) XINPUT: Adding extended input device "ARCHISS PTR21 ARCHISS PTR21 Mouse" (type: MOUSE, id 11)
[ 7.615] (**) Option "AccelerationScheme" "none"
[ 7.615] (**) ARCHISS PTR21 ARCHISS PTR21 Mouse: (accel) selected scheme none/0
[ 7.615] (**) ARCHISS PTR21 ARCHISS PTR21 Mouse: (accel) acceleration factor: 2.000
[ 7.615] (**) ARCHISS PTR21 ARCHISS PTR21 Mouse: (accel) acceleration threshold: 4
[ 7.619] (II) event258 - ARCHISS PTR21 ARCHISS PTR21 Mouse: is tagged by udev as: Mouse
[ 7.619] (II) event258 - ARCHISS PTR21 ARCHISS PTR21 Mouse: device is a pointer
[ 7.621] (II) config/udev: Adding input device ARCHISS PTR21 ARCHISS PTR21 Mouse (/dev/input/mouse0)
[ 7.621] (II) No input driver specified, ignoring this device.
[ 7.621] (II) This device may have been added with another device file.
[ 7.622] (II) config/udev: Adding input device ARCHISS PTR21 ARCHISS PTR21 System Control (/dev/input/event259)
[ 7.622] (**) ARCHISS PTR21 ARCHISS PTR21 System Control: Applying InputClass "evdev keyboard catchall"
[ 7.622] (**) ARCHISS PTR21 ARCHISS PTR21 System Control: Applying InputClass "libinput keyboard catchall"
[ 7.622] (**) ARCHISS PTR21 ARCHISS PTR21 System Control: Applying InputClass "system-keyboard"
[ 7.622] (II) Using input driver 'libinput' for 'ARCHISS PTR21 ARCHISS PTR21 System Control'
[ 7.622] (**) ARCHISS PTR21 ARCHISS PTR21 System Control: always reports core events
[ 7.622] (**) Option "Device" "/dev/input/event259"
[ 7.622] (**) Option "_source" "server/udev"
[ 7.625] (II) event259 - ARCHISS PTR21 ARCHISS PTR21 System Control: is tagged by udev as: Keyboard
[ 7.625] (II) event259 - ARCHISS PTR21 ARCHISS PTR21 System Control: device is a keyboard
[ 7.625] (II) event259 - ARCHISS PTR21 ARCHISS PTR21 System Control: device removed
[ 7.634] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.1/0003:2BE8:0005.0007/input/input40/event259"
[ 7.634] (II) XINPUT: Adding extended input device "ARCHISS PTR21 ARCHISS PTR21 System Control" (type: KEYBOARD, id 12)
[ 7.634] (**) Option "xkb_model" "pc105"
[ 7.634] (**) Option "xkb_layout" "us"
[ 7.634] (**) Option "xkb_variant" "dvorak"
[ 7.635] (II) event259 - ARCHISS PTR21 ARCHISS PTR21 System Control: is tagged by udev as: Keyboard
[ 7.635] (II) event259 - ARCHISS PTR21 ARCHISS PTR21 System Control: device is a keyboard
[ 7.636] (II) config/udev: Adding input device ARCHISS PTR21 ARCHISS PTR21 Consumer Control (/dev/input/event260)
[ 7.636] (**) ARCHISS PTR21 ARCHISS PTR21 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 7.636] (**) ARCHISS PTR21 ARCHISS PTR21 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 7.636] (**) ARCHISS PTR21 ARCHISS PTR21 Consumer Control: Applying InputClass "system-keyboard"
[ 7.636] (II) Using input driver 'libinput' for 'ARCHISS PTR21 ARCHISS PTR21 Consumer Control'
[ 7.636] (**) ARCHISS PTR21 ARCHISS PTR21 Consumer Control: always reports core events
[ 7.636] (**) Option "Device" "/dev/input/event260"
[ 7.636] (**) Option "_source" "server/udev"
[ 7.637] (II) event260 - ARCHISS PTR21 ARCHISS PTR21 Consumer Control: is tagged by udev as: Keyboard
[ 7.637] (II) event260 - ARCHISS PTR21 ARCHISS PTR21 Consumer Control: device is a keyboard
[ 7.637] (II) event260 - ARCHISS PTR21 ARCHISS PTR21 Consumer Control: device removed
[ 7.694] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.1/0003:2BE8:0005.0007/input/input41/event260"
[ 7.694] (II) XINPUT: Adding extended input device "ARCHISS PTR21 ARCHISS PTR21 Consumer Control" (type: KEYBOARD, id 13)
[ 7.694] (**) Option "xkb_model" "pc105"
[ 7.694] (**) Option "xkb_layout" "us"
[ 7.694] (**) Option "xkb_variant" "dvorak"
[ 7.695] (II) event260 - ARCHISS PTR21 ARCHISS PTR21 Consumer Control: is tagged by udev as: Keyboard
[ 7.695] (II) event260 - ARCHISS PTR21 ARCHISS PTR21 Consumer Control: device is a keyboard
[ 7.696] (II) config/udev: Adding input device Logitech G700s (/dev/input/event26)
[ 7.696] (**) Logitech G700s: Applying InputClass "evdev pointer catchall"
[ 7.696] (**) Logitech G700s: Applying InputClass "libinput pointer catchall"
[ 7.696] (II) Using input driver 'libinput' for 'Logitech G700s'
[ 7.696] (**) Logitech G700s: always reports core events
[ 7.696] (**) Option "Device" "/dev/input/event26"
[ 7.696] (**) Option "_source" "server/udev"
[ 7.697] (II) event26 - Logitech G700s: is tagged by udev as: Mouse
[ 7.697] (II) event26 - Logitech G700s: device is a pointer
[ 7.697] (II) event26 - Logitech G700s: device removed
[ 7.743] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:046D:C531.0002/0003:046D:102A.0008/input/input46/event26"
[ 7.743] (II) XINPUT: Adding extended input device "Logitech G700s" (type: MOUSE, id 14)
[ 7.744] (**) Option "AccelerationScheme" "none"
[ 7.744] (**) Logitech G700s: (accel) selected scheme none/0
[ 7.744] (**) Logitech G700s: (accel) acceleration factor: 2.000
[ 7.744] (**) Logitech G700s: (accel) acceleration threshold: 4
[ 7.747] (II) event26 - Logitech G700s: is tagged by udev as: Mouse
[ 7.748] (II) event26 - Logitech G700s: device is a pointer
[ 7.750] (II) config/udev: Adding input device Logitech G700s (/dev/input/mouse1)
[ 7.750] (II) No input driver specified, ignoring this device.
[ 7.750] (II) This device may have been added with another device file.
[ 7.752] (II) config/udev: Adding input device Topre REALFORCE 87 US (/dev/input/event30)
[ 7.752] (**) Topre REALFORCE 87 US: Applying InputClass "evdev keyboard catchall"
[ 7.752] (**) Topre REALFORCE 87 US: Applying InputClass "libinput keyboard catchall"
[ 7.752] (**) Topre REALFORCE 87 US: Applying InputClass "system-keyboard"
[ 7.752] (II) Using input driver 'libinput' for 'Topre REALFORCE 87 US'
[ 7.752] (**) Topre REALFORCE 87 US: always reports core events
[ 7.752] (**) Option "Device" "/dev/input/event30"
[ 7.752] (**) Option "_source" "server/udev"
[ 7.755] (II) event30 - Topre REALFORCE 87 US: is tagged by udev as: Keyboard
[ 7.755] (II) event30 - Topre REALFORCE 87 US: device is a keyboard
[ 7.756] (II) event30 - Topre REALFORCE 87 US: device removed
[ 7.771] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:0853:0145.0003/input/input35/event30"
[ 7.771] (II) XINPUT: Adding extended input device "Topre REALFORCE 87 US" (type: KEYBOARD, id 15)
[ 7.771] (**) Option "xkb_model" "pc105"
[ 7.772] (**) Option "xkb_layout" "us"
[ 7.772] (**) Option "xkb_variant" "dvorak"
[ 7.778] (II) event30 - Topre REALFORCE 87 US: is tagged by udev as: Keyboard
[ 7.778] (II) event30 - Topre REALFORCE 87 US: device is a keyboard
[ 7.781] (II) config/udev: Adding input device Topre REALFORCE 87 US Consumer Control (/dev/input/event31)
[ 7.781] (**) Topre REALFORCE 87 US Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 7.781] (**) Topre REALFORCE 87 US Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 7.781] (**) Topre REALFORCE 87 US Consumer Control: Applying InputClass "system-keyboard"
[ 7.781] (II) Using input driver 'libinput' for 'Topre REALFORCE 87 US Consumer Control'
[ 7.781] (**) Topre REALFORCE 87 US Consumer Control: always reports core events
[ 7.781] (**) Option "Device" "/dev/input/event31"
[ 7.781] (**) Option "_source" "server/udev"
[ 7.785] (II) event31 - Topre REALFORCE 87 US Consumer Control: is tagged by udev as: Keyboard
[ 7.785] (II) event31 - Topre REALFORCE 87 US Consumer Control: device is a keyboard
[ 7.785] (II) event31 - Topre REALFORCE 87 US Consumer Control: device removed
[ 7.831] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:0853:0145.0004/input/input36/event31"
[ 7.831] (II) XINPUT: Adding extended input device "Topre REALFORCE 87 US Consumer Control" (type: KEYBOARD, id 16)
[ 7.831] (**) Option "xkb_model" "pc105"
[ 7.831] (**) Option "xkb_layout" "us"
[ 7.831] (**) Option "xkb_variant" "dvorak"
[ 7.832] (II) event31 - Topre REALFORCE 87 US Consumer Control: is tagged by udev as: Keyboard
[ 7.832] (II) event31 - Topre REALFORCE 87 US Consumer Control: device is a keyboard
[ 7.832] (II) config/udev: Adding input device Topre REALFORCE 87 US Keyboard (/dev/input/event256)
[ 7.832] (**) Topre REALFORCE 87 US Keyboard: Applying InputClass "evdev keyboard catchall"
[ 7.832] (**) Topre REALFORCE 87 US Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.832] (**) Topre REALFORCE 87 US Keyboard: Applying InputClass "system-keyboard"
[ 7.832] (II) Using input driver 'libinput' for 'Topre REALFORCE 87 US Keyboard'
[ 7.832] (**) Topre REALFORCE 87 US Keyboard: always reports core events
[ 7.832] (**) Option "Device" "/dev/input/event256"
[ 7.832] (**) Option "_source" "server/udev"
[ 7.833] (II) event256 - Topre REALFORCE 87 US Keyboard: is tagged by udev as: Keyboard
[ 7.833] (II) event256 - Topre REALFORCE 87 US Keyboard: device is a keyboard
[ 7.834] (II) event256 - Topre REALFORCE 87 US Keyboard: device removed
[ 7.865] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:0853:0145.0004/input/input37/event256"
[ 7.865] (II) XINPUT: Adding extended input device "Topre REALFORCE 87 US Keyboard" (type: KEYBOARD, id 17)
[ 7.865] (**) Option "xkb_model" "pc105"
[ 7.865] (**) Option "xkb_layout" "us"
[ 7.865] (**) Option "xkb_variant" "dvorak"
[ 7.866] (II) event256 - Topre REALFORCE 87 US Keyboard: is tagged by udev as: Keyboard
[ 7.867] (II) event256 - Topre REALFORCE 87 US Keyboard: device is a keyboard
[ 7.867] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event13)
[ 7.867] (II) No input driver specified, ignoring this device.
[ 7.867] (II) This device may have been added with another device file.
[ 7.868] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event14)
[ 7.868] (II) No input driver specified, ignoring this device.
[ 7.868] (II) This device may have been added with another device file.
[ 7.868] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event15)
[ 7.868] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event16)
[ 7.869] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event17)
[ 7.869] (II) No input driver specified, ignoring this device.
[ 7.869] (II) This device may have been added with another device file.
[ 7.869] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event18)
[ 7.870] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event19)
[ 7.870] (II) No input driver specified, ignoring this device.
[ 7.870] (II) This device may have been added with another device file.
[ 7.870] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event20)
[ 7.870] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event21)
[ 7.871] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event22)
[ 7.871] (II) No input driver specified, ignoring this device.
[ 7.871] (II) This device may have been added with another device file.
[ 7.871] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event23)
[ 7.871] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event24)
[ 7.872] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event25)
[ 7.872] (II) No input driver specified, ignoring this device.
[ 7.872] (II) This device may have been added with another device file.
[ 7.872] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event5)
[ 7.872] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 7.872] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 7.872] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 7.872] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 7.873] (**) Dell WMI hotkeys: always reports core events
[ 7.873] (**) Option "Device" "/dev/input/event5"
[ 7.873] (**) Option "_source" "server/udev"
[ 7.874] (II) event5 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 7.874] (II) event5 - Dell WMI hotkeys: device is a keyboard
[ 7.874] (II) event5 - Dell WMI hotkeys: device removed
[ 7.924] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/PNP0C14:00-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input8/event5"
[ 7.924] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 18)
[ 7.924] (**) Option "xkb_model" "pc105"
[ 7.924] (**) Option "xkb_layout" "us"
[ 7.924] (**) Option "xkb_variant" "dvorak"
[ 7.928] (II) event5 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 7.928] (II) event5 - Dell WMI hotkeys: device is a keyboard
[ 7.930] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 7.930] (II) No input driver specified, ignoring this device.
[ 7.930] (II) This device may have been added with another device file.
[ 7.943] (II) config/udev: Adding input device C922 Pro Stream Webcam (/dev/input/event264)
[ 7.943] (**) C922 Pro Stream Webcam: Applying InputClass "evdev keyboard catchall"
[ 7.943] (**) C922 Pro Stream Webcam: Applying InputClass "libinput keyboard catchall"
[ 7.943] (**) C922 Pro Stream Webcam: Applying InputClass "system-keyboard"
[ 7.943] (II) Using input driver 'libinput' for 'C922 Pro Stream Webcam'
[ 7.943] (**) C922 Pro Stream Webcam: always reports core events
[ 7.943] (**) Option "Device" "/dev/input/event264"
[ 7.943] (**) Option "_source" "server/udev"
[ 7.947] (II) event264 - C922 Pro Stream Webcam: is tagged by udev as: Keyboard
[ 7.947] (II) event264 - C922 Pro Stream Webcam: device is a keyboard
[ 7.947] (II) event264 - C922 Pro Stream Webcam: device removed
[ 8.004] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2:1.0/input/input53/event264"
[ 8.004] (II) XINPUT: Adding extended input device "C922 Pro Stream Webcam" (type: KEYBOARD, id 19)
[ 8.004] (**) Option "xkb_model" "pc105"
[ 8.004] (**) Option "xkb_layout" "us"
[ 8.004] (**) Option "xkb_variant" "dvorak"
[ 8.008] (II) event264 - C922 Pro Stream Webcam: is tagged by udev as: Keyboard
[ 8.008] (II) event264 - C922 Pro Stream Webcam: device is a keyboard
[ 8.918] (II) config/udev: Adding input device CORSAIR CORSAIR K63 Wireless USB Receiver (/dev/input/event261)
[ 8.918] (II) No input driver specified, ignoring this device.
[ 8.918] (II) This device may have been added with another device file.
[ 8.922] (II) config/udev: Adding input device CORSAIR CORSAIR K63 Wireless USB Receiver (/dev/input/event27)
[ 8.922] (**) CORSAIR CORSAIR K63 Wireless USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 8.922] (**) CORSAIR CORSAIR K63 Wireless USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 8.922] (**) CORSAIR CORSAIR K63 Wireless USB Receiver: Applying InputClass "system-keyboard"
[ 8.922] (II) Using input driver 'libinput' for 'CORSAIR CORSAIR K63 Wireless USB Receiver'
[ 8.922] (**) CORSAIR CORSAIR K63 Wireless USB Receiver: always reports core events
[ 8.922] (**) Option "Device" "/dev/input/event27"
[ 8.922] (**) Option "_source" "server/udev"
[ 8.923] (II) event27 - CORSAIR CORSAIR K63 Wireless USB Receiver: is tagged by udev as: Keyboard
[ 8.923] (II) event27 - CORSAIR CORSAIR K63 Wireless USB Receiver: device is a keyboard
[ 8.923] (II) event27 - CORSAIR CORSAIR K63 Wireless USB Receiver: device removed
[ 8.945] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.4/1-7.4.4/1-7.4.4.2/1-7.4.4.2:1.0/0003:1B1C:1B50.0009/input/input47/event27"
[ 8.946] (II) XINPUT: Adding extended input device "CORSAIR CORSAIR K63 Wireless USB Receiver" (type: KEYBOARD, id 20)
[ 8.946] (**) Option "xkb_model" "pc105"
[ 8.946] (**) Option "xkb_layout" "us"
[ 8.946] (**) Option "xkb_variant" "dvorak"
[ 8.947] (II) event27 - CORSAIR CORSAIR K63 Wireless USB Receiver: is tagged by udev as: Keyboard
[ 8.947] (II) event27 - CORSAIR CORSAIR K63 Wireless USB Receiver: device is a keyboard
[ 8.948] (II) config/udev: Adding input device CORSAIR CORSAIR K63 Wireless USB Receiver (/dev/input/event262)
[ 8.948] (II) No input driver specified, ignoring this device.
[ 8.948] (II) This device may have been added with another device file.
[ 8.949] (II) config/udev: Adding input device CORSAIR CORSAIR K63 Wireless USB Receiver System Control (/dev/input/event263)
[ 8.949] (**) CORSAIR CORSAIR K63 Wireless USB Receiver System Control: Applying InputClass "evdev keyboard catchall"
[ 8.949] (**) CORSAIR CORSAIR K63 Wireless USB Receiver System Control: Applying InputClass "libinput keyboard catchall"
[ 8.949] (**) CORSAIR CORSAIR K63 Wireless USB Receiver System Control: Applying InputClass "system-keyboard"
[ 8.949] (II) Using input driver 'libinput' for 'CORSAIR CORSAIR K63 Wireless USB Receiver System Control'
[ 8.949] (**) CORSAIR CORSAIR K63 Wireless USB Receiver System Control: always reports core events
[ 8.949] (**) Option "Device" "/dev/input/event263"
[ 8.949] (**) Option "_source" "server/udev"
[ 8.950] (II) event263 - CORSAIR CORSAIR K63 Wireless USB Receiver System Control: is tagged by udev as: Keyboard
[ 8.950] (II) event263 - CORSAIR CORSAIR K63 Wireless USB Receiver System Control: device is a keyboard
[ 8.950] (II) event263 - CORSAIR CORSAIR K63 Wireless USB Receiver System Control: device removed
[ 8.977] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.4/1-7.4.4/1-7.4.4.2/1-7.4.4.2:1.1/0003:1B1C:1B50.000A/input/input52/event263"
[ 8.978] (II) XINPUT: Adding extended input device "CORSAIR CORSAIR K63 Wireless USB Receiver System Control" (type: KEYBOARD, id 21)
[ 8.978] (**) Option "xkb_model" "pc105"
[ 8.978] (**) Option "xkb_layout" "us"
[ 8.978] (**) Option "xkb_variant" "dvorak"
[ 8.979] (II) event263 - CORSAIR CORSAIR K63 Wireless USB Receiver System Control: is tagged by udev as: Keyboard
[ 8.980] (II) event263 - CORSAIR CORSAIR K63 Wireless USB Receiver System Control: device is a keyboard
[ 8.980] (II) config/udev: Adding input device CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard (/dev/input/event28)
[ 8.980] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: Applying InputClass "evdev keyboard catchall"
[ 8.981] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.981] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: Applying InputClass "system-keyboard"
[ 8.981] (II) Using input driver 'libinput' for 'CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard'
[ 8.981] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: always reports core events
[ 8.981] (**) Option "Device" "/dev/input/event28"
[ 8.981] (**) Option "_source" "server/udev"
[ 8.982] (II) event28 - CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: is tagged by udev as: Keyboard
[ 8.982] (II) event28 - CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: device is a keyboard
[ 8.983] (II) event28 - CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: device removed
[ 9.004] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.4/1-7.4.4/1-7.4.4.2/1-7.4.4.2:1.1/0003:1B1C:1B50.000A/input/input48/event28"
[ 9.004] (II) XINPUT: Adding extended input device "CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard" (type: KEYBOARD, id 22)
[ 9.004] (**) Option "xkb_model" "pc105"
[ 9.004] (**) Option "xkb_layout" "us"
[ 9.004] (**) Option "xkb_variant" "dvorak"
[ 9.010] (II) event28 - CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: is tagged by udev as: Keyboard
[ 9.010] (II) event28 - CORSAIR CORSAIR K63 Wireless USB Receiver Keyboard: device is a keyboard
[ 9.012] (II) config/udev: Adding input device CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control (/dev/input/event29)
[ 9.013] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 9.013] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 9.013] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 9.013] (II) Using input driver 'libinput' for 'CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control'
[ 9.013] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: always reports core events
[ 9.013] (**) Option "Device" "/dev/input/event29"
[ 9.013] (**) Option "_source" "server/udev"
[ 9.018] (II) event29 - CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 9.018] (II) event29 - CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: device is a keyboard
[ 9.018] (II) event29 - CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: device removed
[ 9.044] (II) libinput: CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: needs a virtual subdevice
[ 9.044] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.4/1-7.4.4/1-7.4.4.2/1-7.4.4.2:1.1/0003:1B1C:1B50.000A/input/input49/event29"
[ 9.044] (II) XINPUT: Adding extended input device "CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control" (type: MOUSE, id 23)
[ 9.045] (**) Option "AccelerationScheme" "none"
[ 9.045] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: (accel) selected scheme none/0
[ 9.045] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: (accel) acceleration factor: 2.000
[ 9.045] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: (accel) acceleration threshold: 4
[ 9.050] (II) event29 - CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 9.050] (II) event29 - CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: device is a keyboard
[ 9.051] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 9.051] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 9.051] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 9.051] (II) Using input driver 'libinput' for 'CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control'
[ 9.051] (**) CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: always reports core events
[ 9.051] (**) Option "Device" "/dev/input/event29"
[ 9.051] (**) Option "_source" "_driver/libinput"
[ 9.051] (II) libinput: CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control: is a virtual subdevice
[ 9.051] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.4/1-7.4.4/1-7.4.4.2/1-7.4.4.2:1.1/0003:1B1C:1B50.000A/input/input49/event29"
[ 9.051] (II) XINPUT: Adding extended input device "CORSAIR CORSAIR K63 Wireless USB Receiver Consumer Control" (type: KEYBOARD, id 24)
[ 9.051] (**) Option "xkb_model" "pc105"
[ 9.051] (**) Option "xkb_layout" "us"
[ 9.051] (**) Option "xkb_variant" "dvorak"
[ 9.429] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): connected
[ 9.429] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): Internal TMDS
[ 9.429] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): 330.0 MHz maximum pixel clock
[ 9.429] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 9.429] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 9.429] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 9.429] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.429] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.429] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 9.429] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.429] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.429] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.429] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 9.429] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 9.429] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 9.429] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 9.429] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 9.429] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 9.429] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 9.429] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 9.429] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[ 9.494] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): connected
[ 9.494] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): Internal TMDS
[ 9.494] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): 600.0 MHz maximum pixel clock
[ 9.689] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): connected
[ 9.690] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): Internal TMDS
[ 9.690] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): 330.0 MHz maximum pixel clock
[ 9.690] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 9.690] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 9.690] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 9.690] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 9.690] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 9.690] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 9.690] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 9.690] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 9.690] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 9.690] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 9.690] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 9.690] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 9.690] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 9.690] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 9.690] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 9.690] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 9.690] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 9.690] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[ 9.753] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): connected
[ 9.753] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): Internal TMDS
[ 9.753] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): 600.0 MHz maximum pixel clock
[ 15.477] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): connected
[ 15.477] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): Internal TMDS
[ 15.478] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): 330.0 MHz maximum pixel clock
[ 15.478] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 15.478] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 15.478] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 15.478] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 15.478] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 15.478] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 15.478] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 15.478] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 15.478] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 15.478] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 15.478] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 15.478] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 15.478] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 15.478] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 15.478] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 15.478] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 15.478] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 15.478] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[ 15.542] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): connected
[ 15.542] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): Internal TMDS
[ 15.542] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): 600.0 MHz maximum pixel clock
[ 30.568] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): connected
[ 30.568] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): Internal TMDS
[ 30.568] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): 330.0 MHz maximum pixel clock
[ 30.568] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 30.568] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 30.568] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 30.568] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 30.568] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 30.568] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 30.568] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 30.568] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 30.568] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 30.568] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 30.568] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 30.568] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 30.568] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 30.568] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 30.568] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 30.568] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 30.568] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 30.568] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[ 30.633] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): connected
[ 30.633] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): Internal TMDS
[ 30.633] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): 600.0 MHz maximum pixel clock
[ 42.711] (EE) event26 - Logitech G700s: client bug: event processing lagging behind by 14ms, your system is too slow
[ 55.655] (EE) event26 - Logitech G700s: client bug: event processing lagging behind by 13ms, your system is too slow
[ 55.707] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): connected
[ 55.707] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): Internal TMDS
[ 55.707] (--) NVIDIA(GPU-0): Acer G24 (DFP-0): 330.0 MHz maximum pixel clock
[ 55.707] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 55.707] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 55.707] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 55.707] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 55.707] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 55.707] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[ 55.708] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 55.708] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 55.708] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 55.708] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 55.708] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 55.708] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[ 55.708] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 55.708] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 55.708] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 55.708] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 55.708] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 55.708] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[ 55.773] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): connected
[ 55.773] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): Internal TMDS
[ 55.773] (--) NVIDIA(GPU-0): TOSHIBA-TV (DFP-7): 600.0 MHz maximum pixel clock
[ 99.958] (EE) event26 - Logitech G700s: client bug: event processing lagging behind by 11ms, your system is too slow
[ 106.030] (EE) event26 - Logitech G700s: client bug: event processing lagging behind by 13ms, your system is too slow
[ 106.147] (EE) event26 - Logitech G700s: client bug: event processing lagging behind by 13ms, your system is too slow
[ 106.280] (EE) event26 - Logitech G700s: client bug: event processing lagging behind by 14ms, your system is too slow
[ 106.414] (EE) event26 - Logitech G700s: client bug: event processing lagging behind by 14ms, your system is too slow
[ 106.547] (EE) event26 - Logitech G700s: client bug: event processing lagging behind by 14ms, your system is too slow
[ 106.547] (EE) event26 - Logitech G700s: WARNING: log rate limit exceeded (5 msgs per 60s). Discarding future messages.
[ 117.106] (EE) client bug: timer event26 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[ 118.599] (II) NVIDIA(0): Setting mode "DPY-0:nvidia-auto-select+1920+0,DPY-7:nvidia-auto-select+0+0"
[ 121.544] (II) NVIDIA(0): Setting mode "DPY-0:nvidia-auto-select+1920+0{ForceCompositionPipeline=On},DPY-7:nvidia-auto-select+0+0"
It seems somehow āanother vendorā is getting the display first.
Doing this made my primary display appear on startup! Thatās much better than a black screen! However, itās laggy, and I can tell just by dragging a window around.
Iām not 100% sure about the log entries I read above, but it seems from them (especially GLX: Another vendor is already registered for screen 0) that the Intel GPU is somehow registering my primary display for GLX early or something. Iāll look at the LightDM logs.
Maybe make both your ports use the ForceCompositionPipeline=On or none use that. Might be better. Also, make sure your config is not missing this last lines:
You can also safely use the Option "ConnectToAcpid" "Off" in Device Section.
Thank you for those tweaks, but Iām not really interested in optimizing right now. My setup is exactly how I want it after using āApplyā in the nvidia-settings tool. For now, I just want to make sure Iām using the right GPU for both my displays on startup without having to use the workaround. I will look into those tweaks later though, once Iāve determined that Iām using the right GPU after the display manager has initialized, without using āApplyā in the nvidia-settings tool.
If I can figure out how to set which GPU is truly in use on the display managerās startup, then the issue will be solved.
Not sure what you mean. If the monitors are connected to the dGPU aka Nvidia, and the monitors are showing the desktop, then that is what your system is using.
glxinfo | grep "OpenGL"
will show you that too
Another test with sudo systemctl restart display-manager, waiting a short while (a few extra seconds), dragging windows around, and checking vsynctester.com in Chromium (not Firefox because Firefox has a vsync issue in Linux as it targets exactly 60 Hz and canāt be set to my displayās refresh rate of 59.95 Hz) revealed that I have perfect vsync right after initialization, so the problem does indeed seem to be solved!
Thanks for all your help! The big issue from my first post is resolved, and Iāve marked the post that solved it as the solution.
In the end, the solution to my black screen issue was to delete ~/.config/xfce4/xfconf/xfce-perchannel-xml/displays.xml and seemingly it had nothing to do with the internal GPU after all.
Regarding optimization, I have exactly the tweaks I want. I have perfect vsync with software that synchronizes properly (Chromium only, seemingly; Firefox still has vsync bugs), and the input lag is as minimal as I could get it. The input lag seems like itās 1 frame (as low as it can get) except when the CPU is in heavy use, because it seems to not do as much rendering on the GPU as Windows.
I tried enabling this composite extension and it did nothing discernable. My terminal is still semi-transparent as it already was with XFWM composition enabled. I also researched it on https://download.nvidia.com/XFree86/Linux-x86_64/450.66/README/xcompositeextension.html and read that it also adds a whole lot of configuration complexity that Iād rather not bother with, including many possible issues, so it seems safest to avoid it for now.
For those curious about the XFCE setup Iām using for perfect vsync on my main monitor with Nvidia, Iām using:
xfconf xfwm:vblank_mode offsync_to_vblank falseuse_compositing true (not using compton or picom because I found them to be buggy)nvidia-settings (aka āNvidia X Server Settingsā):I donāt need other tweaks since it seems perfect now. Iāve validated it in vsynctester.com with Chromium and seen it show that āVSYNCā text in grey blinking perfectly for more than a few minutes without a single frame drop or red spike. Thatās as good as it can get. I hope Firefox catches up with Chromiumās vsync in Linux soon. I use Firefox as my main browser for multiple reasons.
