I have my headphones/microphone plugged in to the front panel and my speakers plugged in to the motherboard in the back.
If I change audio port in the PulseAudio control panel while the headphones are still plugged in, I can’t hear anything. Unplugging the headphones solves the problem and I can use my speakers.
Now, on Windows I can swap between headphones and speakers without having to unplug anything, and I was wondering if there was any kind of hidden option to do exactly this.
The system is dual-booting with Windows 10 using rEFInd and is almost on a fresh installation, I haven’t touched any kind of audio settings.
My ALSA settings (alsa-info.sh)
!!ALSA Information Script v 0.4.65
!!Script ran on: Mon Mar 15 13:15:04 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: To Be Filled By O.E.M.
Product Name: To Be Filled By O.E.M.
Product Version: To Be Filled By O.E.M.
Firmware Version: P2.80
System SKU: To Be Filled By O.E.M.
Board Vendor: ASRock
Board Name: Z77 Extreme4
!!ACPI Device Status Information
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0501:00/status 15
/sys/bus/acpi/devices/PNP0C01:00/status 15
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
!!Kernel Information
Kernel release: 5.9.16-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.9.16-1-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
snd_usb_audio
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf7f10000 irq 40
1 [HDMI ]: HDA-Intel - HDA ATI HDMI
HDA ATI HDMI at 0xf7e60000 irq 41
2 [U0x46d0x825 ]: USB-Audio - USB Device 0x46d:0x825
USB Device 0x46d:0x825 at usb-0000:00:14.0-3, high speed
!!PCI Soundcards installed in the system
00:1b.0 Audio device [0403]: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller [8086:1e20] (rev 04)
Subsystem: ASRock Incorporation Z77 Extreme4 motherboard [1849:1898]
01:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] [1002:aab0]
Subsystem: ASUSTeK Computer Inc. Device [1043:aab0]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1
!!Module: snd_usb_audio
autoclock : Y
delayed_register : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
device_setup : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
ignore_ctl_error : N
pid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
quirk_alias : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
skip_validation : N
use_vmalloc : Y
vid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC898
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0899
Subsystem Id: 0x18491898
Revision Id: 0x100003
No Modem Function Group found
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x411: Stereo
Device: name="ALC898 Analog", type="Audio", device=0
Converter: stream=5, channel=0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC898 Digital", type="SPDIF", device=1
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x3f 0x3f]
Converter: stream=1, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC898 Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
Converter: stream=0, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=2, device=0
Control: name="Capture Switch", index=2, device=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100791: Stereo Digital
SDI-Select: 0
Digital:
PCM:
rates [0x570]: 32000 44100 48000 96000 192000
formats [0x1]: PCM
Unsolicited: tag=00, enabled=0
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Rear Mic Playback Volume", index=0, device=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=5, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x4f 0x4f]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
Amp-Out vals: [0x00 0x00]
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Connection: 2
0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400701: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Pincap 0x0001003c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=05, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Amp-Out vals: [0x80 0x80]
Pincap 0x0000003c: IN OUT HP Detect
Pin Default 0x01011012: [Jack] Line Out at Ext Rear
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x00:
Unsolicited: tag=06, enabled=1
Connection: 5
0x0c 0x0d* 0x0e 0x0f 0x26
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Pin Default 0x01016011: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x00:
Unsolicited: tag=07, enabled=1
Connection: 5
0x0c 0x0d 0x0e* 0x0f 0x26
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Rear Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x0000373c: IN OUT HP Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19840: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=03, enabled=1
Connection: 5
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Pin Default 0x02a19850: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Line Boost Volume", index=0, device=0
Pin Default 0x0181304f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=04, enabled=1
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x02214020: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 5
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4015e601: [N/A] Speaker at Ext N/A
Conn = Optical, Color = White
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400701: Stereo Digital
Pin Default 0x01451130: [Jack] SPDIF Out at Ext Rear
Conn = Optical, Color = Black
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=28
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 11
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 11
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 12
0x18 0x19* 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x25 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Amp-Out vals: [0x57 0x57]
Connection: 2
0x25 0x0b
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100300
Default PCM:
rates [0x70]: 32000 44100 48000
bits [0x2]: 16
formats [0x1]: PCM
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
Pincap 0x00000094: OUT Detect HDMI
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x40: OUT
Connection: 1
0x02
Node 0x04 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x05 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=1, device=0
Control: name="IEC958 Playback Pro Mask", index=1, device=0
Control: name="IEC958 Playback Default", index=1, device=0
Control: name="IEC958 Playback Switch", index=1, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Node 0x06 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x07 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=2, device=0
Control: name="IEC958 Playback Pro Mask", index=2, device=0
Control: name="IEC958 Playback Default", index=2, device=0
Control: name="IEC958 Playback Switch", index=2, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x08 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x09 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=3, device=0
Control: name="IEC958 Playback Pro Mask", index=3, device=0
Control: name="IEC958 Playback Default", index=3, device=0
Control: name="IEC958 Playback Switch", index=3, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x08
Node 0x0a [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x0b [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=4, device=0
Control: name="IEC958 Playback Pro Mask", index=4, device=0
Control: name="IEC958 Playback Default", index=4, device=0
Control: name="IEC958 Playback Switch", index=4, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x0a
Node 0x0c [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x0d [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=5, device=0
Control: name="IEC958 Playback Pro Mask", index=5, device=0
Control: name="IEC958 Playback Default", index=5, device=0
Control: name="IEC958 Playback Switch", index=5, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x0c
--endcollapse--
!!USB Mixer information
--startcollapse--
USB Mixer: usb_id=0x046d0825, ctrlif=2, ctlerr=0
Card: USB Device 0x46d:0x825 at usb-0000:00:14.0-3, high speed
Unit: 5
Control: name="Mic Capture Volume", index=0
Info: id=5, control=2, cmask=0x0, channels=1, type="S16"
Volume: min=1536, max=7680, dBmin=600, dBmax=3000
Unit: 5
Control: name="Mic Capture Switch", index=0
Info: id=5, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
Volume: min=0, max=1, dBmin=0, dBmax=0
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 15 Mar 15 08:53 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 9 Mar 15 08:53 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 17 Mar 15 08:53 /dev/snd/controlC2
crw-rw---- 1 root audio 116, 14 Mar 15 08:53 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 8 Mar 15 08:53 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 11 Mar 15 13:00 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 10 Mar 15 13:00 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 12 Mar 15 08:53 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 13 Mar 15 08:53 /dev/snd/pcmC0D2c
crw-rw---- 1 root audio 116, 6 Mar 15 08:53 /dev/snd/pcmC1D10p
crw-rw---- 1 root audio 116, 7 Mar 15 08:53 /dev/snd/pcmC1D11p
crw-rw---- 1 root audio 116, 2 Mar 15 08:53 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 3 Mar 15 08:53 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 4 Mar 15 08:53 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 5 Mar 15 08:53 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 16 Mar 15 09:09 /dev/snd/pcmC2D0c
crw-rw---- 1 root audio 116, 1 Mar 15 08:53 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Mar 15 08:53 /dev/snd/timer
/dev/snd/by-id:
total 0
drwxr-xr-x 2 root root 60 Mar 15 08:53 .
drwxr-xr-x 4 root root 440 Mar 15 08:53 ..
lrwxrwxrwx 1 root root 12 Mar 15 08:53 usb-046d_0825_908755A0-02 -> ../controlC2
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 100 Mar 15 08:53 .
lrwxrwxrwx 1 root root 12 Mar 15 08:53 pci-0000:00:14.0-usb-0:3:1.2 -> ../controlC2
lrwxrwxrwx 1 root root 12 Mar 15 08:53 pci-0000:00:1b.0 -> ../controlC0
lrwxrwxrwx 1 root root 12 Mar 15 08:53 pci-0000:01:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC898 Analog [ALC898 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC898 Digital [ALC898 Digital]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC898 Alt Analog [ALC898 Alt Analog]
Subdevices: 2/2
Subdevice #1: subdevice #1
card 2: U0x46d0x825 [USB Device 0x46d:0x825], device 0: USB Audio [USB Audio]
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0xf7f10000 irq 40'
Mixer name : 'Realtek ALC898'
Components : 'HDA:10ec0899,18491898,00100003'
Controls : 53
Simple ctrls : 24
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 79 [91%] [-6.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Center',0
Mono: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Beep',0
Mono:
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 63 [100%] [30.00dB] [on]
Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Capture',2
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Input Source',2
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
!!-------Mixer controls for card HDMI
Card hw:1 'HDMI'/'HDA ATI HDMI at 0xf7e60000 irq 41'
Mixer name : 'ATI R6xx HDMI'
Components : 'HDA:1002aa01,00aa0100,00100300'
Controls : 42
Simple ctrls : 6
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
!!-------Mixer controls for card U0x46d0x825
Card hw:2 'U0x46d0x825'/'USB Device 0x46d:0x825 at usb-0000:00:14.0-3, high speed'
Mixer name : 'USB Mixer'
Components : 'USB046d:0825'
Controls : 4
Simple ctrls : 1
Simple mixer control 'Mic',0
Capabilities: cvolume cvolume-joined cswitch cswitch-joined
Capture channels: Mono
Limits: Capture 0 - 16
Mono: Capture 12 [75%] [24.00dB] [off]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Front Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Front Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Surround Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.4 {
iface MIXER
name 'Surround Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Center Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
control.6 {
iface MIXER
name 'LFE Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
control.7 {
iface MIXER
name 'Center Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.8 {
iface MIXER
name 'LFE Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'Headphone Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.12 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.13 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.14 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.15 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.16 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.17 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.18 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.19 {
iface MIXER
name 'Input Source'
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.20 {
iface MIXER
name 'Input Source'
index 1
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.21 {
iface MIXER
name 'Input Source'
index 2
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.22 {
iface MIXER
name 'Capture Volume'
value.0 63
value.1 63
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.23 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.24 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.25 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.26 {
iface MIXER
index 2
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.27 {
iface MIXER
index 2
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.28 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.29 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.30 {
iface MIXER
name 'Line Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.31 {
iface MIXER
name 'Beep Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.32 {
iface MIXER
name 'Beep Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.33 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.35 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.36 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.37 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.38 {
iface MIXER
name 'Master Playback Volume'
value 79
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -600
control.39 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.40 {
iface CARD
name 'Front Mic Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.41 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.42 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.43 {
iface CARD
name 'Line Out Front Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.44 {
iface CARD
name 'Line Out Surround Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.45 {
iface CARD
name 'Line Out CLFE Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.46 {
iface CARD
name 'Front Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.47 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.48 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
comment {
access read
type INTEGER
count 6
range '0 - 36'
control.49 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.50 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.51 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.52 {
iface PCM
device 2
index 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.53 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.HDMI {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value '100005000010000100000000000000000000000009070700'
comment {
access 'read volatile'
type BYTES
count 24
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.38 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.39 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.40 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.41 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.42 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.U0x46d0x825 {
control.1 {
iface PCM
value 0
comment {
access read
type INTEGER
count 1
range '0 - 36'
control.2 {
iface MIXER
name 'Mic Capture Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.3 {
iface MIXER
name 'Mic Capture Volume'
value 12
comment {
access 'read write'
type INTEGER
count 1
range '0 - 16'
dbmin 600
dbmax 3000
dbvalue.0 2400
control.4 {
iface CARD
name 'Keep Interface'
value false
comment {
access 'read write'
type BOOLEAN
count 1
--endcollapse--
!!All Loaded Modules
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
amdgpu
arp_tables
at24
bluetooth
bnep
br_netfilter
bridge
btbcm
btintel
btrtl
btusb
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
ehci_hcd
ehci_pci
evdev
ext4
fat
fb_sys_fops
ff_memless
fuse
ghash_clmulni_intel
glue_helper
gpu_sched
hid
hid_generic
i2c_algo_bit
i2c_i801
i2c_smbus
iTCO_vendor_support
iTCO_wdt
input_leds
intel_cstate
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
ip6_tables
ip6table_filter
ip_tables
iptable_filter
iptable_nat
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libcrc32c
libphy
llc
loop
lpc_ich
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mousedev
msr
mxm_wmi
nf_conntrack
nf_defrag_ipv4
nf_defrag_ipv6
nf_nat
nfnetlink
nls_cp437
nls_iso8859_1
overlay
pcspkr
radeon
rapl
rc_core
rfcomm
rfkill
sg
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_rawmidi
snd_seq_device
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
squashfs
stp
syscopyarea
sysfillrect
sysimgblt
tg3
ttm
uas
uinput
usb_storage
usbhid
uvcvideo
vboxdrv
vboxnetadp
vboxnetflt
veth
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
x86_pkg_temp_thermal
x_tables
xfrm_algo
xfrm_user
xhci_hcd
xhci_pci
xpad
xt_MASQUERADE
xt_addrtype
xt_conntrack
xt_nat
xt_tcpudp
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x411111f0
0x12 0x411111f0
0x14 0x01014010
0x15 0x01011012
0x16 0x01016011
0x17 0x411111f0
0x18 0x01a19840
0x19 0x02a19850
0x1a 0x0181304f
0x1b 0x02214020
0x1c 0x411111f0
0x1d 0x4015e601
0x1e 0x01451130
0x1f 0x411111f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x185600f0
0x05 0x185600f0
0x07 0x185600f0
0x09 0x185600f0
0x0b 0x185600f0
0x0d 0x185600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
$ inxi -Faz
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: ro root=UUID=99f1b73c-ae9d-40a6-ac96-e15449cc0dbc initrd=boot\initramfs-5.9-x86_64.img
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 info: latte-dock, docker wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: Z77 Extreme4 serial: <filter> UEFI: American Megatrends v: P2.80 date: 01/17/2013
CPU: Info: Quad Core model: Intel Core i5-3570K bits: 64 type: MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 15 L2 cache: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27212
Speed: 1600 MHz min/max: 1600/4200 MHz Core speeds (MHz): 1: 1600 2: 1601 3: 1600 4: 1600
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Pitcairn XT [Radeon HD 7870 GHz Edition] vendor: ASUSTeK driver: radeon
v: kernel alternate: amdgpu bus ID: 01:00.0 chip ID: 1002:6818 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: ati,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.9.16-1-MANJARO LLVM 11.1.0) v: 4.5 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASRock Z77 Extreme4 driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20 class ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 1002:aab0 class ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus ID: 2-3:4 chip ID: 046d:0825
class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0 chip ID: 8086:095a
class ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-2: Broadcom NetLink BCM57781 Gigabit Ethernet PCIe vendor: ASRock Z77 Extreme4 driver: tg3 v: kernel
port: d000 bus ID: 04:00.0 chip ID: 14e4:16b1 class ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: veth30e23ec state: up speed: 10000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus ID: 1-1.1:3 chip ID: 8087:0a2a
class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 2.33 TiB used: 23.22 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G size: 447.13 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 1103 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37960G size: 894.25 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 2101 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC47 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Sabrent model: SABRENT size: 111.79 GiB block size: physical: 4096 B
logical: 512 B serial: <filter> rev: 0204 scheme: GPT
Partition: ID-1: / raw size: 102.69 GiB size: 100.58 GiB (97.94%) used: 23.22 GiB (23.1%) fs: ext4 dev: /dev/sdd2
maj-min: 8:50
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat dev: /dev/sdd1
maj-min: 8:49
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdd3 maj-min: 8:51
Sensors: System Temperatures: cpu: 36.0 C mobo: N/A gpu: radeon temp: 29.0 C
Info: Processes: 238 Uptime: 5h 21m wakeups: 0 Memory: 15.59 GiB used: 2.5 GiB (16.1%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1306 pacman: 1291 lib: 381 flatpak: 5 snap: 10 Shell: fish v: 3.1.2 default: Bash v: 5.1.0
running in: konsole inxi: 3.3.01
