Hi there,
I recently switched to Wayland, and there are a few issues that appeared after that. I don’t know where to write this issue, so if this is not the place let me know. When the laptop goes to sleep mode because of inactivity, when I hit keys or click mouse for it to turnback on, it only shows black screen, and nothing turns it on, until I turn the laptop off with the button and turn it back on. Does anybody have this kind of problem, or its something on my end.
info:
Kernel: 6.5.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.9 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82UX v: Lenovo Slim 7 16ARH7
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN
serial: <superuser required> UEFI: LENOVO v: KLCN19WW date: 06/08/2023
ID-1: BAT0 charge: 52.1 Wh (78.3%) condition: 66.5/75.0 Wh (88.6%)
volts: 16.1 min: 15.4 model: LENOVO AP16L5J status: not charging
Info: 8-core model: AMD Ryzen 7 6800HS Creator Edition bits: 64 type: MT MCP
arch: Zen 3+ rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 1250 high: 2329 min/max: 400/4785 cores: 1: 1396 2: 1396
3: 400 4: 1396 5: 1397 6: 400 7: 2115 8: 1397 9: 1397 10: 400 11: 1395
12: 1396 13: 1397 14: 1397 15: 400 16: 2329 bogomips: 102243
Device-1: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Lenovo
driver: nvidia v: 535.129.03 arch: Ampere bus-ID: 01:00.0
Device-2: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
v: kernel arch: RDNA-2 bus-ID: 05:00.0 temp: 44.0 C
Device-3: IMC Networks [] driver: uvcvideo type: USB bus-ID: 5-1:2
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau dri: radeonsi gpu: nvidia,amdgpu resolution:
1: 1920x1080 2: 1707x1067
API: EGL v: 1.5 drivers: nvidia,radeonsi,swrast platforms:
active: wayland,x11,surfaceless,device inactive: gbm,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
16.0.6 DRM 3.54 6.5.9-1-MANJARO)
API: Vulkan v: 1.3.269 drivers: nvidia,radv surfaces: xcb,xlib,wayland
devices: 2
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6
API: ALSA v: k6.5.9-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.83 status: off
Server-3: PulseAudio v: 16.1 status: active
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel port: 2000
bus-ID: 02:00.0
Device-2: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
driver: hid-generic,usbhid type: USB bus-ID: 3-1:2
Device-1: Realtek [] driver: btusb v: 0.8 type: USB bus-ID: 3-3:3
Local Storage: total: 931.51 GiB used: 100.06 GiB (10.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN850X 1000GB
size: 931.51 GiB temp: 45.9 C
ID-1: / size: 577.2 GiB used: 100 GiB (17.3%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 256 MiB used: 67.5 MiB (26.4%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 55.5 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (rpm): N/A
Processes: 359 Uptime: 25m Memory: total: 16 GiB note: est.
available: 13.34 GiB used: 4.33 GiB (32.4%) Init: systemd Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: 1419 Shell: Zsh v: 5.9 inxi: 3.3.31
