Whenever I launch an application with DRI_PRIME=1 <application_name>
For Example :
DRI_PRIME=1 steam
system freezes and have to force shutdown to get back to normal.
This happens only with kernels other than 5.4 LTS
For Example:
with kernel 5.13 and 5.10 LTS , the mentioned problem occurs.
The problem is not occurring with 5.4 LTS.
Previously the freeze problem occurred on 5.4 LTS too, but after switching to amdgpu driver the problem was rectified.
unfortunately the problem continued on other kernels except 5.4 LTS
System Info:
System: Kernel: 5.4.143-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.4-x86_64 root=UUID=25ef3aaf-fb0a-4b8d-a4e3-27c0c1dd2336 rw
rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.15.0 date: 06/16/2021
CPU: Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check family: 6
model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
Speed: 2501 MHz min/max: 400/2500 MHz Core speeds (MHz): 1: 2501 2: 2500 3: 2500 4: 2500
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] vendor: Dell driver: amdgpu
v: kernel alternate: radeon bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati,modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel alternate: snd_soc_skl
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.4.143-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Network: Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 8086:3165
class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 931.51 GiB used: 244.4 GiB (26.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3 scheme: GPT
Partition: ID-1: / raw-size: 100.1 GiB size: 100.1 GiB (100.00%) used: 10.05 GiB (10.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 200.2 MiB size: 197.1 MiB (98.45%) used: 554 KiB (0.3%) fs: vfat dev: /dev/sda4
maj-min: 8:4
ID-3: /home raw-size: 828.19 GiB size: 828.19 GiB (100.00%) used: 234.35 GiB (28.3%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 100.1 GiB size: 100.1 GiB (100.00%) used: 10.05 GiB (10.0%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 49.0 C mobo: 47.0 C gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 219 Uptime: 14m wakeups: 1 Memory: 7.64 GiB used: 1.79 GiB (23.5%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1278 lib: 357 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
ok I’ll wait
