Before I explain, I have read most of the problems, but I haven’t found any that is quite similar to mine. The problem is that I open two programs, then the system freezes completely. To clarify more, I always use the Firefox browser, and when I open another program with the browser still open, for example Steam, the device freezes.
My System Information
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=76a49975-913f-47aa-b07d-75c76b483dc4 rw quiet splash
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Hewlett-Packard product: HP Compaq dc7900 Small Form
Factor v: N/A serial: <superuser required> Chassis: type: 4
Mobo: Hewlett-Packard model: 3031h serial: <superuser required>
BIOS: Hewlett-Packard v: 786G1 v01.16 date: 03/05/2009
System RAM: available: 2.85 GiB used: 1.94 GiB (68.1%)
Info: model: Intel Core2 Duo E8400 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1995 min/max: 1998/3000 scaling: driver: acpi-cpufreq
governor: schedutil cores: 1: 1995 2: 1995 bogomips: 11973
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel 4 Series Integrated Graphics vendor: Hewlett-Packard 4
driver: i915 v: kernel arch: Gen-5 process: Intel 45nm built: 2008 ports:
active: VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:2e12
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: xfwm v: 4.18.0 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: VGA-1 res: 1440x900 hz: 60 size: N/A modes: max: 1024x768
min: 640x480
API: OpenGL v: 2.1 Mesa 23.0.4 renderer: Mesa Intel Q45/Q43 (ELK)
direct-render: Yes
Device-1: Intel 82801JD/DO HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a6e
class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel 82567LM-3 Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 1100 bus-ID: 00:19.0 chip-ID: 8086:10de
class-ID: 0200
IF: enp0s25 state: up speed: 100 Mbps duplex: full mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 11e0
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 465.76 GiB used: 32.84 GiB (7.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1SB10A
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: HPH3 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%) used: 32.84 GiB (7.2%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 76a49975-913f-47aa-b07d-75c76b483dc4
Hub-1: 1-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Device-1: 3-1:2 info: HP Elite Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 03f0:034a class-ID: 0300
Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
Device-1: 4-2:2 info: USB OPTICAL MOUSE type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 0000:0538 class-ID: 0301
Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-8: 8-0:1 info: full speed or root hub ports: 2 rev: 1.1
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 182 Uptime: 41m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1197 libs: 433 tools: pamac Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.27
