when i turn on my laptop and then open chromium browser, its asking me for a keyring password. I want to disable that
Hi,
You must adjust your launcher with this
/usr/bin/google-chrome-stable %U --password-store=basic
thanks, i will try it
You have not mentioned your DE/wm. If it uses a keyring (gnome-keyring, kwallet) then your keyrings isn’t getting unlocked at login which it should, unless you fiddled with their configs somewhere.
If it’s a bare-bone window manager, make sure respective keyring services are added to autostart.
Ref:
https://wiki.archlinux.org/index.php/KDE_Wallet
https://wiki.archlinux.org/index.php/GNOME/Keyring
These articles have sections dealing with potential login/unlocking problems.
