“Stuck” is the past tense of “stick”. “Stucked” is not a word.
I’ve tried it but the command takes to long. After 25 min still no output and no return.
fsck -a /dev/nvme0n1/nvme0n1p2
fsck from util-linux 2.36.1
fsck.ext2: Not a directory while trying to open /dev/nvme0n1/nvme0n1p2
/dev/nvme0n1/nvme0n1p2:
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
Is what I get now and the commands with ef2fsck
do not work…
Could you post the result of lsblk --output NAME,SIZE,TYPE,FSTYPE,MOUNTPOINT
NAME SIZE TYPE FSTYPE MOUNTPOINT
loop0 55,4M loop squashfs /var/lib/snapd/snap/core18/1944
loop1 31,1M loop squashfs /var/lib/snapd/snap/snapd/11036
loop2 169,3M loop squashfs /var/lib/snapd/snap/spotify/42
loop3 210,1M loop squashfs /var/lib/snapd/snap/eclipse/48
loop4 55,5M loop squashfs /var/lib/snapd/snap/core18/1988
loop5 173M loop squashfs /var/lib/snapd/snap/spotify/43
loop6 32,3M loop squashfs /var/lib/snapd/snap/snapd/11107
sda 111,8G disk
├─sda1 100M part vfat
├─sda2 16M part
├─sda3 111,2G part ntfs
└─sda4 513M part ntfs
sdb 931,5G disk
├─sdb1 16M part
├─sdb2 634,8G part ntfs
└─sdb3 296,7G part ext4
nvme0n1 465,8G disk
├─nvme0n1p1 300M part vfat /boot/efi
└─nvme0n1p2 465,5G part ext4 /
I think I figured out…I was using kernel 5.10. Switching to 5.9 seems to be a good decision. I would rather use 5.4 because it’s LTS but some apps (e.g. Spotify) simply do not run on 5.4 kernel…
The error from spotify:
cannot query current apparmor profile: Invalid argument
Oh is that so? Nice then, but be careful, this kernel is End Of Life, it won’t receive updates anymore (potential security issues) and it could be removed from Manjaro repos some updates later.
I’m not actively reading the linux news and I’d rather stay on something stable. Is there a reasons to use 5.9 or 5.10 (or even 5.11) instead of 5.4 (which is LTS)? Note that (as said) I’m not following all news and sometimes I hate to repair conflicts after updates.
I don’t understand why do I have problems with 5.10 when it is a LTS in Comparison with 5.9…
5.4 is the stable LTS, still updated until 2 or 3 years if I remember (it’s on kernel.org). It has been proved solid and it’s good to have it installed, just in case. You can have several kernels installed.
But it’s older, and newest hardwares and softwares are not always compatible with it.
5.10 is destined to be the next LTS. It is supposed to be rock solid and all… But it had (still has?) some youth issues and bugs. For a LTS wannabe, it’s not the as stable and reliable as it should be.
For many, as myself and my ooold hardware, 5.10 works very fine. For others, some problems could arise and it’s not the 1st time I saw that downgrading to 5.9 fixes it.
5.9 is a transition kernel. If it fixes more than damages your system, go for it. But keep in mind it will disappear in the next few months from Manjaro. And let’s hope 5.10, 5.11, will be good for your system when it’s time.
For 5.11, it’s still too young. But if you’re a developer who needs absolute new features, go for it. Otherwise, keep the stable proven kernels.
There seems to be a problem with kernel 5.4 on Manjaro: Snaps stopped working after 2020-12-30 update - #11 by philm
Unfortunately, there is apparently no solution other than using a newer kernel.
