Um, delete the file?
Can you give me a command line to do so ? Bear with me guys I’m totally noob here
sudo rm /etc/X11/xorg.conf.d/20-intel.conf
Done. But the problem is still there nothing changed failed to start simple desktop display manager.
Well, I’m afraid that at this point, I’m out of advice. Your sddm
was working earlier, and all you’ve done now was create a configuration file and deleted it again. So I have no idea what’s going on there.
I would:
mhwd-kernel --remove linux57
mhwd-kernel --remove linux419
as 5.7 and 5.8 doesn’t make sense and 4.19 doesn’t work for you.
Sorry to hear that didn’t solve your problem though…
Also, re-install sddm by:
