I’m new to Manjaro Phosh, and am excited about how fast it is on my Pinephone. I’ve been working to make sure my few usual-apps are working (I’m coming from Mobian). I’ve run up against a tough one:
What VPN client is known to work?
I tried manually configuring NordVPN on CLI - it wouldn’t connect. I’ve tried ProtonVPN’s UI client - it just sat spinning forever. I tried NordVPN’s command-line client - it connected once, but then has failed ever since - despite trying UDP, TCP, re-logging-in, etc.
I’m using a fresh install without adding any firewalls. I was using the DEV release, so I’m working on installing BETA16 to try. I’m working on installing BETA16 to try, but if someone knows of a working VPN (and maybe has some notes on how to set it up), that’d be great!
