I used to i3, but I don’t want to lose my application caches, such as Deluge and Wi-Fi settings, in my Cinnamon environment.Instead, I need to add i3 packages like dmenu and so on, and eventually transfer vim etc. config. So, which packages are necessary? ( I need to merge two computers data, but essential one is cinnamon)
It seems there are numerous packages I need, and counting them one by one is exhausting. Is there an ‘i3-full’ package that contains the entire collection of necessary components, like a supreme package collection? I feel passing application’s caches to new clean installation exhausting rather than to do so
I did log in with it, and then I couldn’t even open a terminal window. (It’s quite frustrating, by the way).
The beauty if i3 is that you can configure everything and you’re not locked to certain programs.
However, there is the manjaro-i3-settings
package that you could use or start with.
There is a small i3 package group:
❯ pacman -Sg i3
i3 i3-wm
i3 i3blocks
i3 i3lock
i3 i3status
Thank you, I thought, I should install additional packages more than @Yochanan’s suggestion but not, I was looking wrong config location and of course wrong keybindings…
~/.i3/config
instead
~/.config/i3/config
It’s going well, thank you
