What is yaru session?
I’ve installed yaru gtk, application, icon, shell, cursor, sound themes from AUR using pamac manager.
I saw “yaru session”. Should I install it?
What is it?
The package description is lacking to say the least, and the package URL just points to Yaru theme on github.
It’s a custom GNOME Session you can choose on the login screen. It will load the Yaru wallpaper, icons, sound theme, etc. automatically. You don’t need it if you’d rather set things manually.
