Is Manajaro copying packages from Arch, or rebuilding them?
I saw that the Arch RFC-002 “Provide a x86-64-v3 microarchitecture level port” was merged (sorry, this forum forbids me to include links - just google it).
In Manjaro, are x86-64 packages build with v2 or v3 level? Is there any plan for that?
Most of our packages are taken over directly from Arch in binary form, but we do of course have some custom packages, i.e. packages that were specifically developed for Manjaro — e.g. pamac, manjaro-settings-manager, et al — as well as a couple of packages that we compile ourselves with different or custom patches, such as for instance the different kernels.
We follow Arch in that regard.
Anything that Arch introduces as a distro-specific standard will immediately be imported into Manjaro Unstable, and barring any serious-enough difficulties that would have us trace back on that step, things will then be sufficiently tested by the community in Manjaro Testing, and will then percolate down into Manjaro Stable by way of the next bundled update.
Ultimately, it will then also be solidified in Manjaro Summit, which is a so-called “immutable” system. Yet, switching between the different branches — even to and from Summit — is always possible. Manjaro is very flexible in that regard.
The above all said, we always strongly advise new members to subscribe to notifications for the Stable Updates category — or to Testing Updates if you’re on the Testing branch — because unlike Arch, Manjaro is a curated rolling-release distribution, which means that with the exception of fast-tracked packages (for security reasons), updates are always bundled, and every such update always comes with a dedicated Announcements thread.
The first post of every announcement thread details all of the important changes, and the second post highlights any potential gotchas and how to work around them or avoid them.
Or, just type it between two ` characters;
for example: `https://forum.manjaro.com`.
This way, others can easily copy/paste a link if they desire.
Welcome to the Manjaro community.
As a new or infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
The answer is simple. All packages are currently packaged at v1 level.
x86-64 is a 64-bit version of the x86 CPU instruction set supported by AMD and Intel CPUs, among others. Since the first generations of CPUs, more low-level CPU features have been added over the years. The x86-64 CPU features can be grouped into four CPU microarchitecture levels:
The x86-64-v1 level is the same as the original, baseline x86-64 level. These levels are subsets of each other, i.e. x86-64-v1 ⊂ x86-64-v2 ⊂ x86-64-v3 ⊂ x86-64-v4. For a CPU to support a level, it must support all CPU features of that version level, and, because they are subsets of each other, all those of the lower versions.
@Aragorn there is a ALPH https://somegit.dev/ALHP/ALHP.GO community repo, which copies and recompiles all Arch packages to v2 , v3 and v4.
I guess, it will not work alongside Manjaro repos, correct?
The chances to that are small, even if only because Arch is a little bit ahead of us with their package versions. The results will be unpredictable at best.
