I am a bit suprised Gnome has a single hot corner: top left.
When you move the panel to the left side (vertical), because you would like to maximise vertical screen space, the ArcMenu is the top left icon.
Often when I want to open the menu, I get Activities instead.
It seems strange of me these defaults have been chosen, as one of the popular ways to use Gnome is with the vertical panel.
Thankfully, you can change the hot corner action: to open ArcMenu (right-click ArcMenu > ArcMenu Settings > General > “Modify Activities Hot Corner” (wheel)).
But currently it is not possible to configure other hot corners. For example:
Top Left - Application Launcher (ArcMenu), done.
Bottom Left - Activities (currently open apps)
Top Right - show desktop
What is the official, recommended solution to add support for other hot corners?
I found the following:
- Waycorner AUR package and Github project
→ unclear if this is meant for Gnome?
→ It asks “Choose a provider for cargo”, giving me 2 options “Rust (extra)” or “Rust (community)”, I am clueless about this stuff. - CustomCorner AUR package and Github project → seems outdated, predates Gnome with Wayland.
- Custom Hot Corners Extended Github project → Seems absolutely overkill, hot corners is just one of its features. I just need to add bottom left and top right.
I would like to install (and be dependent on) as little 3rd party things as possible. I am not using any Gnome Extension yet and haven’t installed the requirements for it (why install a browser addon if I all want is a few extra hot corners?).
I hope someone can shed some light on the absolute simplest solution. Waycorner needs to install 15 things, among them 85MB of Rust library and 35MB GCC. Then it needs some manual setup. I don’t mind doing that if it’s still the fastest/lightweight solution with least amount of dependencies.
Is there a future Gnome update coming that supports more hotcorners?
