I have ignored this topic for a relatively long time, but now I finally want to make sure that my AMD GPUs (both in my Z16 AMD ThinkPad and in my AMD Ryzen 9 3900X desktop system) can be used properly. For example, I would like to record with OBS via my GPUs.
Unfortunately, despite reading quite a few threads and Manjaro as well as Arch Wiki pages, I am still unsure which way I need to go:
- Compile MESA with proprietary codecs
- Install the nonfree AMD GPU driver
Interestingly, sudo mhwd -a pci nonfree 0300 says on my laptop:
> Skipping already installed config 'video-linux' for device: 0000:64:00.0 (0300:1002:1681) Display controller ATI Technologies Inc Rembrandt [Radeon 680M]
… and on my desktop:
> Skipping already installed config 'video-linux' for device: 0000:3f:00.0 (0300:1002:67c4) Display controller ATI Technologies Inc Ellesmere [Radeon Pro WX 7100]
> Skipping already installed config 'video-linux' for device: 0000:3e:00.0 (0300:1002:67c4) Display controller ATI Technologies Inc Ellesmere [Radeon Pro WX 7100]
Do I have to remove the open source drivers with mhwd before I can install the nonfree drivers?
I would be grateful if someone could lead me the way. Many thanks in advance!
This is my laptop:
Kernel: 6.14.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
root=UUID=2b7072e2-76a6-42f5-83c2-2ab80366d449 rw
cryptdevice=UUID=0547c112-bbd6-43c9-8e23-ad3207afedf1:luks-0547c112-bbd6-43c9-8e23-ad3207afedf1
root=/dev/mapper/luks-0547c112-bbd6-43c9-8e23-ad3207afedf1
udev.log_priority=3 amd_pstate.shared_mem=1 amd_pstate=passive splash
Desktop: GNOME v: 48.1 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 21D4CTO1WW v: ThinkPad Z16 Gen 1
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 21D4CTO1WW serial: <filter>
part-nu: LENOVO_MT_21D4_BU_Think_FM_ThinkPad Z16 Gen 1
uuid: 59f8f4dc-ac00-11ec-80f1-6c24081382c1 UEFI: LENOVO v: N3GET72W (1.72 )
date: 03/31/2025
ID-1: BAT0 charge: 49.4 Wh (79.4%) condition: 62.2/72.0 Wh (86.4%)
volts: 16.8 min: 15.5 model: SMP 5B10W51887 type: Li-poly serial: <filter>
status: not charging cycles: 728
System RAM: total: 16 GiB available: 14.89 GiB used: 4.61 GiB (31.0%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
max: 0.5 width (bits): data: 32 total: 32 manufacturer: Hynix
part-no: H9JCNNNCP3MLYR-N6E serial: N/A
Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 5 PRO 6650H with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA40410A
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4070 min/max: 400/4566 boost: enabled
base/boost: 3300/4550 scaling: driver: amd-pstate governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 4070 2: 4070 3: 4070 4: 4070
5: 4070 6: 4070 7: 4070 8: 4070 9: 4070 10: 4070 11: 4070 12: 4070
bogomips: 79051
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
Writeback-1 bus-ID: 64:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 60.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 04f2:b78b
Device-3: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 04f2:b78c
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Lenovo 0x4146 built: 2021 res: 3840x2400 dpi: 284
gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
modes: max: 3840x2400 min: 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
rembrandt LLVM 19.1.7 DRM 3.61 6.14.6-2-MANJARO) device-ID: 1002:1681
memory: 500 MiB unified: no display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 64:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 64:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 64:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.6-2-MANJARO status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0489:e0d9
Device-1: luks-0547c112-bbd6-43c9-8e23-ad3207afedf1 maj-min: 253:0
type: LUKS dm: dm-0 size: 937.18 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 937.18 GiB
Device-2: luks-b3063d16-3277-4725-89a2-14f079d36d79 maj-min: 253:1
type: LUKS dm: dm-1 size: 16.39 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 16.39 GiB
Local Storage: total: 953.87 GiB used: 441.58 GiB (46.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL7
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EL3QGXA7 temp: 53.9 C
scheme: GPT
SMART: yes health: PASSED on: 32d 5h cycles: 6,125
read-units: 81,476,421 [41.7 TB] written-units: 24,808,847 [12.7 TB]
ID-1: / raw-size: 937.18 GiB size: 921.39 GiB (98.32%)
used: 441.54 GiB (47.9%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 253:0 mapped: luks-0547c112-bbd6-43c9-8e23-ad3207afedf1 label: N/A
uuid: 2b7072e2-76a6-42f5-83c2-2ab80366d449
used: 47.2 MiB (15.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: FEEC-51B2
ID-3: /mnt/smb/vault/amadeus raw-size: N/A size: 21.65 TiB
used: 12.49 TiB (57.7%) fs: cifs dev: /dev/amadeus
ID-4: /mnt/smb/vault/backup raw-size: N/A size: 21.65 TiB
used: 12.49 TiB (57.7%) fs: cifs dev: /dev/backup
ID-5: /mnt/smb/vault/shared raw-size: N/A size: 21.65 TiB
used: 12.49 TiB (57.7%) fs: cifs dev: /dev/shared
ID-1: swap-1 type: partition size: 16.39 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 253:1
mapped: luks-b3063d16-3277-4725-89a2-14f079d36d79 label: swap
uuid: f204fe9e-1387-44d5-b256-f0e540591fd7
Device-1: 1-4:2 info: Chicony Integrated Camera type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b78b class-ID: fe01 serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-2:2 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e0d9 class-ID: e001 serial: <filter>
Hub-4: 3-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-3.4:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:658c class-ID: ef00 serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: Chicony Integrated IR Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b78c class-ID: 0e02 serial: <filter>
Hub-7: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-9: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-10: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-11: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 77.0 C mobo: 50.0 C gpu: amdgpu temp: 58.0 C
Fan Speeds (rpm): fan-1: 2670 fan-2: 2436
Processes: 420 Power: uptime: 9m states: freeze,mem,disk suspend: s2idle
image: 5.94 GiB services: gsd-power, power-profiles-daemon, upowerd
Packages: 1216 pm: pacman pkgs: 1100 libs: 327 tools: gnome-software,pamac
pm: flatpak pkgs: 116 Compilers: N/A Shell: Bash v: 5.2.37 running-in: kgx
inxi: 3.3.38
And this is my desktop:
root=UUID=7e83c4e1-9989-4fe6-b427-929ed254be96 rw udev.log_priority=3
splash
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: ProArt X570-CREATOR WIFI v: Rev X.0x serial: <filter>
part-nu: SKU uuid: 4c62fe88-107c-bfc9-152a-7c10c9bf1529
UEFI: American Megatrends v: 0801 date: 04/26/2022
System RAM: total: 64 GiB available: 62.7 GiB used: 3.17 GiB (5.1%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF3200C16D4/16GX serial: <filter>
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4363 min/max: 550/4673 boost: enabled
base/boost: 3800/4650 scaling: driver: amd-pstate-epp governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 4363 2: 4363 3: 4363 4: 4363
5: 4363 6: 4363 7: 4363 8: 4363 9: 4363 10: 4363 11: 4363 12: 4363 13: 4363
14: 4363 15: 4363 16: 4363 17: 4363 18: 4363 19: 4363 20: 4363 21: 4363
22: 4363 23: 4363 24: 4363 bogomips: 182061
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon Pro WX 7100]
driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: DP-4 empty: DP-1,DP-2,DP-3 bus-ID: 3e:00.0
chip-ID: 1002:67c4 class-ID: 0300 temp: 61.0 C
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon Pro WX 7100]
built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none empty: DP-5, DP-6, DP-7, DP-8
bus-ID: 3f:00.0 chip-ID: 1002:67c4 class-ID: 0300
Device-3: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-4.4.4.1:11
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Monitor-1: DP-4 model: VP32UQ serial: <filter> built: 2023 res: 3840x2160
dpi: 139 gamma: 1.2 size: 700x390mm (27.56x15.35") diag: 801mm (31.5")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Pro WX 7100 Graphics
(radeonsi polaris10 ACO DRM 3.61 6.14.6-2-MANJARO) device-ID: 1002:67c4
memory: 7.81 GiB unified: no display-ID: :0.0
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
470/480 / 570/580/590] driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 3e:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
470/480 / 570/580/590] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 3f:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 42:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Microchip (formerly SMSC) Fireface UFX (23609326)
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-4:2 chip-ID: 0424:3fb8 class-ID: 0103 serial: <filter>
Device-5: XMOS USB Audio 2.0 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 20b1:2001
Device-6: Atmel Intech Studio: Grid
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3.4.2:11 chip-ID: 03eb:ecad
class-ID: 0103
Device-7: Logitech BRIO Ultra HD Webcam
Device-1: Aquantia AQtion AQC113CS NBase-T/IEEE 802.3an Ethernet [Antigua
10G] vendor: ASUSTeK ProArt X570-CREATOR WIFI driver: atlantic v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 2 port: N/A bus-ID: 38:00.0
chip-ID: 1d6a:94c0 class-ID: 0200
IF: enp56s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 39:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlp57s0 state: down mac: <filter>
Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 3a:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp58s0 state: down mac: <filter>
IF-ID-1: br-623793b0473c state: down mac: <filter>
IF-ID-2: br-86bcf5cc8a22 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 8087:0032
class-ID: e001
Local Storage: total: 3.64 TiB used: 1.64 TiB (45.0%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
SMART: yes health: PASSED on: 223d 2h cycles: 1,726
read-units: 22,805,328 [11.6 TB] written-units: 46,757,004 [23.9 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 50.9 C scheme: GPT
SMART: yes health: PASSED on: 61d 14h cycles: 1,230
read-units: 2,426,989,845 [1.24 PB] written-units: 2,184,943,529 [1.11 PB]
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 484.1 GiB (26.9%)
fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p3 maj-min: 259:5 label: N/A
uuid: 7e83c4e1-9989-4fe6-b427-929ed254be96
used: 320 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:3 label: N/A uuid: 9240-29B4
ID-3: /mnt/e410ce8d-4e17-4b15-801a-c3419dfa69ca raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 1.17 TiB (65.2%) fs: ext4 block-size: 4096 B
dev: /dev/nvme0n1p1 maj-min: 259:2 label: backup
uuid: e410ce8d-4e17-4b15-801a-c3419dfa69ca
ID-4: /mnt/smb/vault/amadeus raw-size: N/A size: 21.65 TiB
ID-5: /mnt/smb/vault/backup raw-size: N/A size: 21.65 TiB
ID-6: /mnt/smb/vault/shared raw-size: N/A size: 21.65 TiB
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p2 maj-min: 259:4 label: N/A
uuid: 68e6c686-aa00-47e4-93d2-b1e6ca82a495
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: Microchip (formerly SMSC) Fireface UFX (23609326)
type: audio driver: snd-usb-audio interfaces: 5 rev: 2.0
Device-2: 3-5:3 info: XMOS USB Audio 2.0 type: audio driver: snd-usb-audio
interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 20b1:2001 class-ID: fe01 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 5-2:2 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
Hub-6: 5-3:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Hub-7: 5-3.4:5 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
Device-1: 5-3.4.1:8 info: Elgato Systems GmbH Stream Deck MK.2 type: HID
driver: usbfs interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0fd9:0080 class-ID: 0300 serial: <filter>
Device-2: 5-3.4.2:11 info: Atmel Intech Studio: Grid
type: abstract (modem),CDC-data,mouse,keyboard,audio
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
chip-ID: 03eb:ecad class-ID: 0103
Hub-8: 5-3.4.4:14 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
Hub-9: 5-3.4.4.4:16 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
Hub-10: 5-4:4 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
Device-1: 5-4.1:7 info: Holtek USB-HID Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:0192 class-ID: 0300
Device-2: 5-4.2:20 info: Wings Tech Xtrfy MZ1 type: mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 480mA chip-ID: 2ea8:2203 class-ID: 0301
Hub-11: 5-4.4:13 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
Device-1: 5-4.4.2:15 info: Arduino SA Leonardo (CDC ACM HID)
type: abstract (modem),CDC-data,HID driver: cdc_acm,hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 2341:8036 class-ID: 0300 serial: <filter>
Hub-12: 5-4.4.4:18 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
Hub-13: 5-4.4.4.4:19 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
Hub-14: 5-5:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-15: 5-6:9 info: Genesys Logic Hub ports: 3 rev: 2.0
Device-1: 5-6.1:12 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-16: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-17: 6-3:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
Hub-18: 6-3.4:4 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
Hub-19: 6-3.4.4:12 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
Hub-20: 6-3.4.4.4:14 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
Device-1: 6-3.4.4.4.4:15 info: Genesys Logic SDXC and microSDXC CardReader
type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 05e3:0743 class-ID: 0806 serial: <filter>
Hub-21: 6-4:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
Hub-22: 6-4.4:5 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
Hub-23: 6-4.4.4:8 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
Device-1: 6-4.4.4.1:11 info: Logitech BRIO Ultra HD Webcam
type: video,audio,HID driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
interfaces: 6 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 896mA chip-ID: 046d:085e class-ID: 0300
serial: <filter>
Hub-24: 6-4.4.4.4:13 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
Hub-25: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-26: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 55.0 C mobo: 39.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 1362 fan-2: 1953 fan-3: 1320 fan-4: 1220
fan-5: 0 fan-6: 0 fan-7: 0
GPU: device: amdgpu temp: 61.0 C fan: 1146 watts: 21.19 device: amdgpu
temp: 38.0 C watts: 13.04
Processes: 553 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.06 GiB services: gsd-power,
tool: systemctl
Packages: 1316 pm: pacman pkgs: 1199 libs: 356 tools: gnome-software,pamac
pm: flatpak pkgs: 117 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Bash
v: 5.2.37 running-in: kgx inxi: 3.3.38
