Hi
I have Lenovo V14. It have Full HD Display and 14" Size
What’s best DPI value for 14" display ? I use Manjaro KDE
Hello, check this maybe DPI Calculator / PPI Calculator
There is no universal “best”: it depends on your eyes, the season, the time of day, the clouds, … so therefore I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
