Based on IBus’ Arch Wiki page, ibus is integrated into the Gnome DE and I was wondering which Input Framework that xfce uses by default.
I’ve tried to add other layouts via the keyboard settings, but even though the languages (Chinese, etc.) are listed, they don’t seem to work. Why is that?
I got it to work using Fcitx5 and I don’t mind using Fcitx5, but I’m just curious why these features aren’t available for the default.
to set the keyboard layout is using setckbmap
trough the xkb
plugin
Having setxkbmap installed is not sufficient as requires also at least a IME(Input Method Editor) to enter languages that make use of Chinese characters. If you look inside /usr/share/X11/xkb/symbols
and you read the cn
file, you will see how it works, and how the symbos are “translated” to match the key codes from keyboard model and variant. Or you go by such keyboard:
Because are available for those that require them to install and configure. 90% (maybe more) of the people using Manjaro do not write in Chinese nor Japanese. You can always install manjaro-asian-input-support-fcitx
or manjaro-asian-input-support-ibus
if you need those.
