I update my mirrorlist regularly with
sudo pacman-mirrors -f 5 && sudo pacman -Syyu, after I have previously selected the mirrors for my country. I guess this concerns pacman, not pamac, right? But then what does the pamac-mirrorlist-timer do additionally? Does it mess up the mirrorlist, which I created, in regular indifference to the defaults of others again?
It regenerates the mirror list weekly.
/usr/lib/systemd/system/pamac-mirrorlist.timer
[Unit]
Description=Generate mirrorlist weekly
[Timer]
OnCalendar=Thu *-*-* 7:00:00
RandomizedDelaySec=15h
Persistent=true
[Install]
WantedBy=timers.target
/usr/lib/systemd/system/pamac-mirrorlist.service
[Unit]
Wants=network-online.target
After=network-online.target
[Service]
Type=oneshot
ExecStart=/usr/bin/pacman-mirrors -f8
So you can save the manual editing because it becomes pointless?
No, just disable the timer for your use case:
$ systemctl disable pamac-mirrorlist.timer
no reason to do if the pc does not travel
you can also change one service (persistent after pamac update)
sudo systemctl edit pamac-mirrorlist.timer # for change OnCalendar date
#or
sudo systemctl edit pamac-mirrorlist.service # for change params
