Hi people!
After spending 6 months using the same Manjaro install, learning how to use Linux and making a awful lot of mistakes I decided to start from scratch and reinstall the OS (the old installation was becoming slow and bloated).
This time I went with separate / and /home partitions, but when I tried to do a full backup with timeshift I sadly found out that it doesn’t really like to backup my /home files (it just tries to sync the files indefinitely), while I was able to backup my root partition.
So, what do you use to backup you files?
Is there a nice and easy way you would recommend?
I love timeshift, but I want so secure my personal files too!
Well I use Timeshift and include all files in my /home backed up to /run/timeshift/backup/timeshift/snapshots/ (actually /mnt/T3/timeshift/ which gets re-mounted).
I also started using a separate config backup (konsave) to export plasma configs to my Dropbox so I can switch very easily between styles.
And also old-fashioned manual backups on hard drives or USB flash drives (or even DVDs sometime, yes, they still exists in 2021). Just create an archive and copy the file in HDD/USB drive.
Deja Dup onto a 2TB external drive, once a week or so. I confess to using the cloud via MegaSync so I have the same Documents and Pictures folders across multiple computers.
is it possible to run Deja-Dup with 2 external hard drives? I have tried but I have to change the drive in the settings each time which I find really clunky. I would prefer if it just recognized either of the drives without me having to go in and switch it.
Since I am on Unstable, I backup the entire system (/ and /home, excluding some dirs) using Back in Time (root) almost every time I see a big and/or scary list of packages’ updates. Those like icu, qt*, systemd* and so on.
