Dear All,
I am not sure if this is the way should i create a post in forum. Please advice if any mistakes.
I ran the above topic command to know if any errors in booting my laptop. Below is the output.
It seams to be related to my graphics card. Please help me if i need to install any driver for my graphics card to remove all the below errors.
Jan 23 19:32:18 remyaj-inspiron5537 kernel: ipmi:dmi: Base address is zero, assuming no IPMI interface
Jan 23 19:32:23 remyaj-inspiron5537 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.D>
Jan 23 19:32:23 remyaj-inspiron5537 kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PEGP.DD02._BCL due to >
Jan 23 19:32:39 remyaj-inspiron5537 kernel: debugfs: File 'radeon_ring_gfx' in directory '1' already present!
Jan 23 19:32:39 remyaj-inspiron5537 kernel: debugfs: File 'radeon_ring_cp1' in directory '1' already present!
Jan 23 19:32:39 remyaj-inspiron5537 kernel: debugfs: File 'radeon_ring_cp2' in directory '1' already present!
Jan 23 19:32:39 remyaj-inspiron5537 kernel: debugfs: File 'radeon_ring_dma1' in directory '1' already present!
Jan 23 19:32:39 remyaj-inspiron5537 kernel: debugfs: File 'radeon_ring_dma2' in directory '1' already present!
Jan 23 19:32:39 remyaj-inspiron5537 kernel: debugfs: File 'radeon_ring_uvd' in directory '1' already present!
Jan 23 19:32:39 remyaj-inspiron5537 kernel: debugfs: File 'radeon_ring_vce1' in directory '1' already present!
Jan 23 19:32:39 remyaj-inspiron5537 kernel: debugfs: File 'radeon_ring_vce2' in directory '1' already present!
Jan 23 19:33:30 remyaj-inspiron5537 pipewire[1287]: spa.v4l2: '/dev/video0' VIDIOC_QUERYCTRL: Connection time>
Jan 23 19:33:30 remyaj-inspiron5537 kernel: usb 1-1.8: Failed to query (GET_DEF) UVC control 2 on unit 2: -11>
Please help me to rectify the above issued in my laptop.
My laptop configuration is:
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Portable System: Dell product: Inspiron 5537 v: A12
serial: <superuser required> Chassis: type: 8 v: A12
Mobo: Dell model: 03VVKX v: A00 serial: <superuser required> UEFI: Dell
v: A12 date: 05/27/2019
ID-1: BAT1 charge: 29.3 Wh (100.0%) condition: 29.3/66.6 Wh (44.0%)
volts: 12.8 min: 11.1 model: SANYO DELL 6HY593B8 type: Li-ion
serial: <filter> status: Full
RAM: total: 7.65 GiB used: 2.35 GiB (30.7%)
RAM Report:
Info: dual core model: Intel Core i7-4500U bits: 64 type: MT MCP
smt: enabled arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 4 MiB
Speed (MHz): avg: 1367 high: 1765 min/max: 800/3000 cores: 1: 1765
2: 1057 3: 1407 4: 1240 bogomips: 19161
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: AMD Venus PRO [Radeon HD 8850M / R9 M265X] vendor: Dell
driver: radeon v: kernel bus-ID: 03:00.0 chip-ID: 1002:6823 class-ID: 0300
Device-3: Suyin Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.8:5 chip-ID: 064e:8132 class-ID: 0e02
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: ati,modesetting,radeon alternate: fbdev,vesa
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell driver: ath9k v: kernel bus-ID: 02:00.0 chip-ID: 168c:0036
class-ID: 0280
Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.5:6 chip-ID: 0cf3:0036 class-ID: e001
Local Storage: total: 931.51 GiB used: 197.25 GiB (21.2%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0001 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A100
dev-links: cdrom
ID-1: / size: 915.53 GiB used: 197.25 GiB (21.5%) fs: ext4 dev: /dev/sda2
label: N/A uuid: 8643de3f-5fa9-4311-8b1e-65b93bcb681f
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sda1 label: NO_LABEL uuid: D415-4CF0
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Device-1: 1-1.5:6 info: Qualcomm Atheros AR9462 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-2: 1-1.7:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 1-1.8:5 info: Suyin Laptop_Integrated_Webcam_HD type: Video
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 46.0 C mobo: N/A gpu: radeon temp: 49.0 C
Fan Speeds (RPM): cpu: 2600
Processes: 197 Uptime: 32m wakeups: 1 Init: systemd v: 250 Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1295 Shell: Zsh v: 5.8
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
