How
8 October 2020 16:43
1
I have ubuntu and manjaro installed on my PC and both of them have trouble waking up from suspend. I made the following attempts but no luck:
rollback kernel from 5.8 to 5.7
turn off secure boot
description
Every time I tried to wake my PC from suspend, I can see the fans spinning but the display is not light up. There is no signal to the display. I cannot ssh
to the PC either.
Error info
I notice there are some error messages in dmesg
output:
[ 12.670450] rfkill: input handler enabled
[ 13.396289] [drm:mod_hdcp_add_display_to_topology [amdgpu]] *ERROR* Failed to add display topology, DTM TA is not initialized.
[ 13.396291] [drm] [Link 0] WARNING MOD_HDCP_STATUS_FAILURE IN STATE HDCP_UNINITIALIZED STAY COUNT 0
[ 14.581857] rfkill: input handler disabled
[ 17.009819] kauditd_printk_skb: 9 callbacks suppressed
[ 17.009820] audit: type=1334 audit(1602172881.009:94): prog-id=17 op=LOAD
[ 17.009858] audit: type=1334 audit(1602172881.009:95): prog-id=18 op=LOAD
other related info
inxi
produces:
ā ~ inxi
CPU: 6-Core AMD Ryzen 5 PRO 4400G with Radeon Graphics (-MT MCP-) speed/min/max: 2999/1400/3700 MHz
Kernel: 5.8.11-1-MANJARO x86_64 Up: 18m Mem: 2232.8/14991.5 MiB (14.9%) Storage: 2.29 TiB (3.6% used) Procs: 357 Shell:
inxi: 3.1.05
question
What could be the possible cause of this kind of ācannot wake from suspendā problem?
Since my ubuntn install and manjaro install both have the same problem, could it be the graphics driver that causes the problem?
Any possible approaches to fix it?
How
8 October 2020 16:48
2
I noticed there are many other topics in manjaro forum that are related to this topic. I looked through them and tried some of them but no luck.
Any suggestion is welcome.
Fabby
8 October 2020 20:07
3
The full output of an inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information⦠(Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
write down the time
go to a terminal and execute systemctl suspend
reboot using the REISUB procedure (if possible)
post the output of:
journalctl --system --boot=-1 --since "YYYY-MM-DD HH:MM:SS"
where obviously --since
is the datetime of suspend
use https://textbin.net/ if the output would be too long.
How
9 October 2020 00:23
4
The output of inxi --admin --verbosity=7 --filter --no-host --width
is as follows:
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=358d281b-1623-4cb7-9eca-6bd92cbb0cf0 rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <filter> UEFI: American Megatrends v: 2.00 date: 06/04/2020
RAM: total: 14.64 GiB used: 2.07 GiB (14.1%)
Topology: 6-Core model: AMD Ryzen 5 PRO 4400G with Radeon Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 L2 cache: 3072 KiB bogomips: 88845
Speed: 1847 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz):
1: 2016 2: 1348 3: 1400 4: 1401 5: 1357 6: 1400 7: 1399 8: 1400 9: 1585
10: 1378 11: 1399 12: 1399
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir driver: amdgpu v: kernel bus ID: 30:00.0
chip ID: 1002:1636
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 30:00.1 chip ID: 1002:1637
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 30:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus ID: 29:00.0 chip ID: 8086:24fb
IF: wlo1 state: down mac: <filter>
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 2a:00.0
chip ID: 10ec:8168
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.29 TiB used: 83.59 GiB (3.6%)
ID-1: /dev/nvme0n1 vendor: Colorful model: CN600 512GB size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: T0629A3 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-22MFCA0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-3: /dev/sdb type: USB vendor: Seagate model: Expansion size: 931.51 GiB
block size: physical: 4096 B logical: 512 B serial: <filter> rev: 8101
scheme: GPT
ID-1: / raw size: 80.00 GiB size: 78.24 GiB (97.81%) used: 9.92 GiB (12.7%)
fs: ext4 dev: /dev/nvme0n1p3 label: N/A
uuid: 358d281b-1623-4cb7-9eca-6bd92cbb0cf0
ID-2: /boot/efi raw size: 512.0 MiB size: 511.0 MiB (99.80%)
used: 28.5 MiB (5.6%) fs: vfat dev: /dev/nvme0n1p8 label: N/A
uuid: D34C-62BF
ID-3: /home raw size: 100.00 GiB size: 97.93 GiB (97.93%)
used: 35.04 GiB (35.8%) fs: ext4 dev: /dev/nvme0n1p1 label: N/A
uuid: b34c68f3-623e-40df-ab08-5a56602738c4
ID-4: /home/<filter>/job raw size: 100.00 GiB size: 100.00 GiB (100.00%)
used: 3.97 GiB (4.0%) fs: ntfs dev: /dev/sda2 label: N/A
uuid: 232894BB69D53B86
ID-5: /run/media/z/Documents raw size: 250.00 GiB size: 250.00 GiB (100.00%)
used: 4.78 GiB (1.9%) fs: ntfs dev: /dev/sdb1 label: Documents
uuid: 7D96AB7924913773
ID-6: /run/media/z/iso raw size: 200.00 GiB size: 200.00 GiB (100.00%)
used: 29.00 GiB (14.5%) fs: ntfs dev: /dev/sdb2 label: iso
uuid: 8688E1BE88E1AD3D
ID-7: /usr/local raw size: 80.00 GiB size: 78.24 GiB (97.81%)
used: 877.2 MiB (1.1%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
uuid: 875370f9-e32f-437b-9e53-46f4feac9460
ID-1: swap-1 type: partition size: 7.63 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p9 label: N/A uuid: 8a914415-38c9-42fd-b9cb-49eb8c7e4021
ID-1: /dev/nvme0n1p4 size: 529.0 MiB fs: ntfs
label: \xe6\x81\xa2\xe5\xa4\x8d uuid: EE168B1A168AE347
ID-2: /dev/nvme0n1p5 size: 100.0 MiB fs: vfat label: N/A uuid: 0A8C-EFA3
ID-3: /dev/nvme0n1p6 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-4: /dev/nvme0n1p7 size: 149.37 GiB fs: ntfs label: N/A
uuid: 8C588F18588EFFE6
ID-5: /dev/sda1 size: 200.00 GiB fs: ntfs label: N/A uuid: 0B833D52059C3DA8
Hub: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-6:2 info: Xiaomi Mi Wireless Combo type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 2717:5010
Hub: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 05e3:0608
Device-1: 1-7.1:5 info: Seagate RSS LLC type: Mass Storage driver: uas
interfaces: 1 rev: 2.1 speed: 480 Mb/s chip ID: 0bc2:2101 serial: <filter>
Device-2: 1-8:4 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip ID: 1462:7c95 serial: <filter>
Device-3: 1-9:6 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aa7
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 37.8 C mobo: N/A gpu: amdgpu temp: 29 C
Processes: 382 Uptime: 2m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1214 lib: 328 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
I did systemctl suspend and it suspends but I wasnāt able to do a REISUB procedure later. Keyboard not active. The numlock led is not on.
The output of journalctl --system --boot=-1 --since "2020-08-08 00:08:08"
is huge and is pasted here: textbin .
Fabby
9 October 2020 08:35
5
OK, the only weird thing that I can find is:
10ę 09 08:05:29 z-matrix gnome-session[1087]: gnome-session-binary[1087]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
So could you do me a favour and:
Enable hibernation (You donāt seem to have that active)
try to hibernate instead of suspend and see it that works?
If not, please report back and weāll fiddle with ACPI parameters.
If yes, Thatās your workaround until that gnome bug gets fixed (open/search for an existing bug here )
How
9 October 2020 10:40
6
Thanks for your time Fabby. The hibernation workaround works fine for me.
Fabby
9 October 2020 11:38
7
Iāve marked the below answer as the solution to your question as it is by far the best answer youāll get.
If not, please report back and weāll fiddle wiā¦
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please please donāt forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most :
so that the next person that has the exact same problem you just had will benefit from your post as well as your question will now be in the āsolvedā status.
How
9 October 2020 12:03
8
Got it. I will surely remember to mark the solution next time.
system
Closed
24 October 2020 12:03
9
