Hey all,
Totally new to Manjaro, XFCE & never really committed to Linux as a daily PC - but I’ve taken that plunge on a pretty dated PC (which i use daily) and over all am enjoying Manjaro a lot.
Considering the age of my hardware, i thought it would be good to check on some of the temperatures and the sensor app completely confused me. Below are some of my key system specs .
- Processor: AMD FX-8150 CPU (8x 3.60GHz/8MB L2 Cache)
- Motherboard: Gigabyte GA-970A-UD3 – AMD 970
- Memory: 8 GB [4 GB x2] DDR3-1600 Memory Module - Kingston HyperX
- Video Card: AMD Radeon HD 7970 - 3GB - Single Card
When i run the sensor app, i get three results:
- amdgpu-100 - Name=edge, value= 51 degrees C.
- k10temp-c3 - Name=temp1, value= 13 degrees C.
- fam15h_power-c4 - Name=power1, value= 42.5w
amdgpu-100, i assume is the AMD 7970 video card? The temp values feel like they are in range of what this card should be idle (maybe?). k10temp-c3? Can anyone tell me what that is? the temp is consistently pretty low. Lastly, fam15h_power-c4 - is that the power supply wattage?
How would get this set up to register the processor temperatures?
Thanks for anyone’s help, really appreciate you taking any time you have to help a Linux newbie.
