I’ve been recently getting the error message below (output from journalctl -p 3 -xb) and I can’t figure out if this is something I should be concerned about.
Oct 27 14:55:16 hp-manjaro kernel: ioremap error for 0xccedb000-0xccedc000, requested 0x2, got 0x0
Oct 27 14:55:16 hp-manjaro kernel: amd_pmc AMDI0005:00: SMU debugging info not supported on this platform
Here are the specs of the device:
- Kernel 5.14.10-1
- OS: Manjaro KDE
- Device: HP Envy x360
- Processor: Ryzen 4700u
Here is what has changed recently
- I created a dual boot setup with Windows. Previously (when there was no error), it only had Manjaro but the partition onto which I installed Windows was already there
- I updated the BIOS from Windows
- Resized swap partition to use up a small amount of unallocated memory that was available after swap
- I believe I did’t see the error after I last updated kernel.
Things I did to try and fix issue
- Research but all posts linked to this error seem to be quite old and don’t really have any suggested fix.
- Re-installed kernel. This had no effect and errors persist. I just reinstalled through pamac since I’m not yet fully confident with pacman or yay.
Reasons I am concerned
- I would like to know if the dual boot is messing with anything.
- Could this cause issues later?
- Do I need to report this as a bug somewhere. If so, where would be best?
