I use Manjaro on HDD not SSD. I want to know what are safe to mask that way I can speed up boot without damaging my laptop
systemd-analyze
Startup finished in 6.496s (firmware) + 2.654s (loader) + 3.783s (kernel) + 24.195s (userspace) = 37.129s
graphical.target reached after 19.689s in userspace
systemd-analyze blame
12.262s udisks2.service
10.221s dev-sda2.device
9.641s systemd-journal-flush.service
8.395s polkit.service
4.514s cups.service
4.119s apparmor.service
3.575s upower.service
3.378s dev-loop2.device
3.362s dev-loop1.device
3.356s dev-loop3.device
3.297s dev-loop0.device
2.798s systemd-tmpfiles-setup-dev.service
2.610s systemd-udevd.service
2.576s tlp.service
2.138s run-media-soumi-Luna.mount
2.024s var-lib-snapd-snap-core18-2128.mount
1.955s modprobe@drm.service
1.841s systemd-fsck@dev-disk-by\x2duuid-3DC6\x2dA581.service
1.761s var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1515.mount
1.756s var-lib-snapd-snap-snapd-12883.mount
1.756s var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-161.mount
1.558s systemd-random-seed.service
1.295s systemd-sysctl.service
1.228s systemd-modules-load.service
1.015s lvm2-monitor.service
995ms user@1000.service
813ms NetworkManager.service
800ms wpa_supplicant.service
799ms systemd-journald.service
763ms boot-efi.mount
594ms avahi-daemon.service
561ms modprobe@fuse.service
494ms rtkit-daemon.service
469ms systemd-rfkill.service
421ms colord.service
320ms alsa-restore.service
309ms linux-module-cleanup.service
284ms systemd-udev-trigger.service
276ms systemd-logind.service
235ms sys-kernel-config.mount
217ms systemd-tmpfiles-setup.service
212ms systemd-backlight@backlight:intel_backlight.service
160ms systemd-binfmt.service
141ms systemd-timesyncd.service
137ms dev-hugepages.mount
136ms dev-mqueue.mount
134ms sys-kernel-debug.mount
133ms sys-kernel-tracing.mount
131ms kmod-static-nodes.service
128ms modprobe@configfs.service
95ms dev-disk-by\x2duuid-d27dc7f4\x2dce4f\x2d48b8\x2dba69\x2d9971d9cc4ca0.swap
69ms systemd-update-utmp.service
60ms systemd-remount-fs.service
22ms user-runtime-dir@1000.service
19ms sys-fs-fuse-connections.mount
6ms systemd-user-sessions.service
3ms tmp.mount
3ms proc-sys-fs-binfmt_misc.mount
systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @19.689s
ββsddm.service @19.689s
ββsystemd-user-sessions.service @19.682s +6ms
ββnetwork.target @19.678s
ββwpa_supplicant.service @23.210s +800ms
ββdbus.service @18.860s
ββbasic.target @18.853s
ββsockets.target @18.853s
ββdbus.socket @18.853s
ββsysinit.target @18.751s
ββsystemd-timesyncd.service @18.609s +141ms
ββsystemd-tmpfiles-setup.service @18.303s +217ms
ββsystemd-journal-flush.service @8.660s +9.641s
ββsystemd-journald.service @7.861s +799ms
ββhaveged.service @7.859s
ββsystemd-tmpfiles-setup-dev.service @4.147s +2.798s
ββkmod-static-nodes.service @3.779s +131ms
ββsystemd-journald.socket @3.652s
ββ-.mount @3.580s
ββ-.slice @3.580s
neofetch
ββββββββββββββββββ ββββββββ soumi@Hori
ββββββββββββββββββ ββββββββ ----------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: Aspire A514-53 V1.16
ββββββββ ββββββββ Kernel: 5.14.2-1-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 14 mins
ββββββββ ββββββββ ββββββββ Packages: 1389 (pacman)
ββββββββ ββββββββ ββββββββ Shell: bash 5.1.8
ββββββββ ββββββββ ββββββββ Resolution: 1366x768
ββββββββ ββββββββ ββββββββ DE: Plasma 5.22.5
ββββββββ ββββββββ ββββββββ WM: KWin
ββββββββ ββββββββ ββββββββ Theme: Breeze Light [Plasma], Breeze [GTK2/3]
ββββββββ ββββββββ ββββββββ Icons: breeze [Plasma], breeze [GTK2/3]
ββββββββ ββββββββ ββββββββ Terminal: konsole
CPU: Intel i3-1005G1 (4) @ 3.400GHz
GPU: Intel Iris Plus Graphics G1
Memory: 2627MiB / 7630MiB
inxi -Fazy
Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=3e711149-8ebe-45af-8e9a-78a1cdacff3f rw quiet apparmor=1
security=apparmor resume=UUID=d27dc7f4-ce4f-48b8-ba69-9971d9cc4ca0
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire A514-53 v: V1.16 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: IL model: Sneezy_IL v: V1.16 serial: <filter> UEFI: Insyde v: 1.16
date: 01/18/2021
ID-1: BAT0 charge: 31.7 Wh (100.0%) condition: 31.7/53.0 Wh (59.9%)
volts: 16.5 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
serial: <filter> status: Full cycles: 386
Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L2: 4 MiB
bogomips: 9524
Speed: 1702 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 1702 2: 1659
3: 1625 4: 1715
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
Sound Server-1: ALSA v: k5.14.2-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.35 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Device-1: md126 maj-min: 9:126 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2136 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme0n1 maj-min: 259:0 size: 476.94 GiB state: S
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2944 chunk-size: N/A
0: nvme1n1 maj-min: 259:5 size: 27.25 GiB state: S
Local Storage: total: 1.4 TiB used: 138.47 GiB (9.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: G002 temp: 27.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Intel model: HBRPEKNX0202AO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 32.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: MBR
ID-1: / raw-size: 400 GiB size: 392.65 GiB (98.16%) used: 66.4 GiB (16.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 816 KiB (0.2%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 62.0 C mobo: N/A
Processes: 207 Uptime: 15m wakeups: 1 Memory: 7.45 GiB
used: 2.74 GiB (36.7%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: apt: 0 pacman: 1389 lib: 392 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
