A long time ago I used Orage to handle my ICS calendar as a file. It was ugly but 100% efficient and totally satisfied me. Unfortunately it has been, I presume, abandoned and I have not been able to find a suitable replacement ever since. I’ve tried Thunderbird (to also replace Claws Mail) but it came with another batch of annoyances and I grew fed up of it. I’ve also wanted to try Gnome calendar but it comes with Evolution Data Server /o\ . As for Claws, plugin vcalendar doesn’t seem to support ICS files (as a backend data file that is)…My bad: it does! My bad again: it does but read-only…
I only need an app that can use my ICS file(s) as a backend and take new appointments/events when I need to, preferably from my Xfce desktop — I know there are console applications and they are great however I need something to notify me of upcoming events using Xfce’s notification area, for instance.
Using AUR is not especially recommended, right? I admit I never have Manjaro break because I’m using AUR but I haven’t been using this OS long enough to have experienced such a breakage.
I have tried pantheon-calendar; it doesn’t live on ICS files, only imports them, which is not what I want. As for remind, neither that one uses ICS files as the backend, so neither will that one do unfortunately. I don’t want to have to import my ICS file everytime I add events, I want a solution that shares a single file, just like Orage. IMHO I’ll just install it from AUR and call it a day. Thanks for your suggestions anyway, these are really nice pieces of software.
