What about appimagelauncher ?!?
Hello,
i see, that the software “appimagelauncher” is not in the repos.
How can I run an appimage like “musescore studio”? Is therefore an another application instead?
regards
caho
  Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.3.4 Distro: Manjaro Linux
  Type: Laptop System: TUXEDO product: TUXEDO Pulse 15 Gen1 v: Standard
    serial: <superuser required>
  Mobo: TUXEDO s model: PULSE1501 v: Standard serial: <superuser required>
    UEFI: American Megatrends v: N.1.07.A02 date: 12/08/2020
  ID-1: BAT0 charge: 86.0 Wh (95.0%) condition: 90.5/91.6 Wh (98.7%)
  Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
    type: MT MCP cache: L2: 4 MiB
  Speed (MHz): avg: 1400 min/max: 1400/2900 cores: 1: 1400 2: 1400 3: 1400
    4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
    13: 1400 14: 1400 15: 1400 16: 1400
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel
  Device-2: Chicony HD Webcam driver: uvcvideo type: USB
    dri: radeonsi gpu: amdgpu resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
    renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM 3.61
    6.14.0-1-MANJARO)
  API: Vulkan v: 1.4.309 drivers: radv surfaces: xcb,xlib,wayland
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio driver: snd_hda_intel
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    driver: N/A
  Device-4: DisplayLink USB-C Triple-4K Dock driver: cdc_ncm,snd-usb-audio
    type: USB
  API: ALSA v: k6.14.0-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.4.1 status: active
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
    driver: r8169
  IF-ID-1: enp4s0f3u1u1i5 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth driver: btusb type: USB
  Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
    rfk-block: hardware: no software: no address: <filter> bt-v: 5.2
  Local Storage: total: 232.89 GiB used: 140.37 GiB (60.3%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8250G size: 232.89 GiB
  ID-1: / size: 219.81 GiB used: 140.37 GiB (63.9%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 511 MiB used: 300 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p3
  System Temperatures: cpu: 49.6 C mobo: N/A gpu: amdgpu temp: 37.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB note: est. available: 7.18 GiB used: 2.16 GiB (30.1%)
  Processes: 357 Uptime: 7m Shell: Zsh inxi: 3.3.38
appimagelauncher was dropped from the repos earlier this year:
Although it does look like there has been some recent work done on it, according to its GitHub page. It is still available in the AUR: AUR (en) - appimagelauncher
Here are the details for Gear Lever:
It can be installed from Manjaro’s extra repo:
pamac info gearlever
Version               : 3.1.1-1
Description           : Manage AppImages with ease
URL                   : https://mijorus.it/projects/gearlever
Licenses              : GPL-3.0-or-later
Repository            : extra
Installed Size        : 1.2 MB
Groups                : --
Depends On            : 7zip binutils fuse2 libadwaita python-dbus python-gobject python-pyxdg python-requests which
Optional Dependencies : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Mark Wagie <mark@manjaro.org>
Build Date            : Wed 02 Apr 2025 04:14:25
Validated By          : MD5 Sum  SHA-256 Sum  Signature
Note: There is also a gearlever package in the AUR. If installing gearlever using Pamac’s GUI or any other software installation app which includes an AUR helper, users should double-check which one they have selected for installation before proceeding:
mbn info gearlever -q | grep -Ev 'Name|Repository|Packager'
Branch         : unstable
Version        : 3.1.1-1
Branch         : testing
Version        : 3.1.1-1
Branch         : stable
Version        : 3.1.1-1
AUR            : ------
Version        : 3.1.1-3
Date           : Thu 03 Apr 2025 00:09:36
Url            : https://aur.archlinux.org/packages/gearlever
mbn can be found in the manjaro-check-repos package
~/.local/bin is in your $PATH by default, if I’m not mistaken.
echo $PATH
will tell you
You can put the Appimage there, make it executable and can then start it from terminal by typing it’s name.
This is the way I use Clipgrab.
Or you call it with the full PATH to wherever you decide to put it.
You can create a desktop launcher that uses this information - can’t tell you how exactly that works in KDE.
You’ll figure it out.
OK, thank you for your fast answer. I will install Gear Lever now.
regards
caho
until now, I started the appimage by click to my musescore-files. In the kde system-settings I included it so:
It works fine for me.
So do I need gearlever or appimagelauncher really?
how can I simple test it without them with a backup option?
the flatpak package is unfortunately not up to date…
It does for me, too.
Not really, no.
I told you how I do this - I put the Appimage somewhere in my $PATH (~/.local/bin), make it executable and call it via Terminal by it’s name.
I haven’t bothered to create a Launcher.
I use Xfce4.
What you describe here is associating musescore files with this application.
That should be fine - it can be changed or removed at any time.
I’m however not used to with KDE/Plasma.
I do not know how to answer your question:
OK, thank you very much for your hints, @Nachlese
regards
caho
Just in case it wasn’t clear in the linked thread above, I dropped appimagelauncher and added gearlever at the same time.
