HI!
Using the XFCE version from 2 months and I just love it!
But from 3 days, after the 21.3 update, the theme for the simplescreenrecorder and vlc media player is weird like this:
Please help me fix it!
Regards,
Hrishikesh
HI!
Regards,
Hrishikesh
Those are Qt applications.
AFAIK Manjaro uses Kvantum by default for theming those applications. Otherwise, you can use this for theming them: Uniform look for Qt and GTK applications - ArchWiki
But I wanna use the Matcha-Dark-Sea theme!!..
from applications menu,open kvantum,click on change -delete theme,select theme from drop-down box
But its not having the matcha-sea-dark theme idk why, it has the aliz and aluz theme, but sea theme is not there!
Do you still have kvantum-manjaro installed?
matcha-dark in my case gives me the appearance similar to what you want, however it is true that KvMatchaDarkSea expected me to fix it…but I was wrong it is a different issue.
sorry…my mistake
Oh yes!
Same!!!
I tried only the matcha-dark and it’s giving me the dark-sea look!
Thanks!
