I’m in the latest KDE plasma & I’ve been seeing this weird screen bug for a long time.
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=261e3e34-3aa2-4cb0-85bb-1358fb778207 rw quiet udev.log_priority=3
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUS Laptop X505ZA_X505ZA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X505ZA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X505ZA.313 date: 02/25/2020
ID-1: BAT0 charge: 13.9 Wh (59.7%) condition: 23.3/42.1 Wh (55.4%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 1027
RAM: total: 6.8 GiB used: 2.58 GiB (38.0%)
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 8101007 cache: L2: 2 MiB bogomips: 31948
Speed: 1368 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz):
1: 1368 2: 1367 3: 1369 4: 1366 5: 1369 6: 1366 7: 1485 8: 1592
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:15dd
class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.1:3 chip-ID: 13d3:5a03 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.49-1-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.4 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus-ID: 02:00.0
bus-ID: 3-2.2:4 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 469.68 GiB (50.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 82.12 GiB size: 80.28 GiB (97.76%) used: 32.29 GiB (40.2%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 261e3e34-3aa2-4cb0-85bb-1358fb778207
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 36.6 MiB (14.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: 226E-201B
ID-3: /run/media/zexu/New Volume raw-size: 468.6 GiB
size: 468.6 GiB (100.00%) used: 437.36 GiB (93.3%) fs: ntfs dev: /dev/sda5
maj-min: 8:5 label: New Volume uuid: 0402A78D02A78272
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 356.67 GiB fs: ntfs label: OS
uuid: DE1E71131E70E5C5
ID-3: /dev/sda7 maj-min: 8:7 size: 850 MiB fs: ntfs label: RECOVERY
uuid: A04AD8624AD8372E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 058f:6254 class-ID: 0900
Device-1: 3-2.1:3 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Device-2: 3-2.2:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 72.5 C mobo: 72.0 C gpu: amdgpu temp: 72.0 C
Fan Speeds (RPM): cpu: 4200
Processes: 260 Uptime: 1h 26m wakeups: 8 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1087 lib: 295
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
