Weird rectangles on default desktop background (KDE Plasma/Wayland)
For a while now I have been seeing weird rectangles on the desktop background:
These stay in the same spot, but flicker slightly in their upper left corners.
Weirdly enough, when taking this screenshot, the flickering continued within the screenshot manager even after selecting the region to screenshot.
It is not an issue of the screen, because they move with the background when switching virtual desktops, and do not display on top of other windows.
They also only appear after my desktop has been turned on for a while, but I can’t give a time frame in which they appear.
I would guess around a day maybe?
I am afraid that this may be a corruption of the buffer in which the desktop background is stored/rendered, but how would I go about debugging this?
Also I really hope this isn’t some hardware issue that manages to stay under the radar most of the time except for this…
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
inxi --filter --verbosity=8
inxi -zv8
For some reason I cannot edit my post (I get an error along the lines of “You cannot embed media items in a post”).
But here is my inxi output:
inxi output
  Kernel: 7.3.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.3-x86_64
    root=UUID=1c6aea99-0def-4813-9512-48567e173870 rw quiet loglevel=3
    rd.udev.log_level=3
  Desktop: KDE Plasma v: 6.8.2 tk: Qt v: N/A info: frameworks v: 6.31.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASRock model: B650M-HDV/M.2 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: 4.03 date: 12/18/2025
  System RAM: total: 64 GiB available: 60.4 GiB used: 8.09 GiB (13.4%)
  Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: spec: 4800 MT/s actual: 6000 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMK64GX5M2B6000Z30 serial: N/A
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 603 min/max: 603/5272 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 603 2: 603 3: 603
    4: 603 5: 603 6: 603 7: 603 8: 603 9: 603 10: 603 11: 603 12: 603 13: 603
    14: 603 15: 603 16: 603 bogomips: 150108
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
    ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
    perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
    stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
    umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-4
    code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
    speed: 32 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
    Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon 610M]
    vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2,
    Writeback-2 bus-ID: 0b:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 41.0 C
  Device-3: Logitech Brio 500
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:4 chip-ID: 046d:0943
    class-ID: 0300 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.25 with: Xwayland v: 24.1.14
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 1
  Monitor-1: DP-1 model: AOC AG346UCD serial: <filter> built: 2024 res:
    mode: 3440x1440 hz: 175 scale: 110% (1.1) to: 3127x1309 dpi: 109 gamma: 1.2
    chroma: red: x: 0.690 y: 0.302 green: x: 0.239 y: 0.718 blue: x: 0.145
    y: 0.059 white: x: 0.314 y: 0.329 size: 800x337mm (31.5x13.27")
    diag: 868mm (34.2") modes: 3440x1440, 2560x1440, 2560x1080, 1920x1080,
    1680x1050, 1280x1024, 1440x900, 1280x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 75 2: parse_edid:
    unhandled CEA mode 76 3: parse_edid: unhandled CEA mode 89 4: parse_edid:
    unhandled CEA mode 90 5: parse_edid: unknown tag 112
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.6-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi gfx1201 ACO
    DRM 3.64 7.3.3-1-MANJARO) device-ID: 1002:7550 memory: 15.62 GiB
    unified: no
  API: Vulkan v: 1.4.363 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 26.2.6-arch1.1
    device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Ryzen 7 9800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 26.2.6-arch1.1 device-ID: 1002:13c0 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    bus-ID: 0b:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASRock
    bus-ID: 0b:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Logitech Brio 500
  API: ALSA v: k7.3.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.10 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlp6s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:2 chip-ID: 8087:0032
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 6 state: up address: <filter> bt-v: 5.4
    lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 3.73 TiB used: 2.94 TiB (78.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D4096G
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK51.2 temp: 54.9 C
    scheme: GPT
  ID-1: / raw-size: 3.73 TiB size: 3.67 TiB (98.40%) used: 2.94 TiB (80.2%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 1c6aea99-0def-4813-9512-48567e173870
    used: 344 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 33FC-38C3
  ID-1: swap-1 type: file size: 97.66 GiB used: 0 KiB (0.0%) priority: -1
    file: /swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:4 info: Logitech Brio 500 type: video,audio,HID
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 2.1
    chip-ID: 046d:0943 class-ID: 0300 serial: <filter>
  Device-2: 1-8:2 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-9: 7-1.2:3 info: AOC USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05f6:1003
  Device-1: 7-1.2.2:23 info: AOC AGON3 AG346UCD Light FX Device type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 05f6:ac2e class-ID: 0300
    serial: <filter>
  Device-2: 7-1.2.4:6 info: Cooler Master Gaming MECH KB type: keyboard,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 2516:007f class-ID: 0300
  Device-3: 7-1.2.5:7 info: VIA Labs USB Billboard Device type: billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 chip-ID: 2109:8884 class-ID: 1100 serial: <filter>
  Device-4: 7-1.3:4 info: Razer USA ProClickM type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:009a class-ID: 0300
    serial: <filter>
  System Temperatures: cpu: 46.1 C mobo: 39.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 39.0 C mem: 63.0 C fan: 5 watts: 20.00
    device: amdgpu temp: 41.0 C
  Packages: 2387 pm: pacman pkgs: 2380 libs: 529 tools: pamac pm: flatpak
    pkgs: 7
    1: https://ask4.mm.fcix.net/manjaro/testing/$repo/$arch
    2: https://gsl-syd.mm.fcix.net/manjaro/testing/$repo/$arch
    3: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    4: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    5: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
    6: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
    7: https://mirrors2.manjaro.org/testing/$repo/$arch
    8: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    9: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    10: https://mirror.fcix.net/manjaro/testing/$repo/$arch
    11: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
    12: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    13: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
    14: https://mirror.alpix.eu/manjaro/testing/$repo/$arch
    15: https://cofractal-ewr.mm.fcix.net/manjaro/testing/$repo/$arch
    16: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    17: https://ipng.mm.fcix.net/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 451
  1: cpu: 1.0% command: [kworker/u64:4-sdma1] pid: 368382
    mem: 0.00 MiB (0.0%)
  2: cpu: 0.8% command: firefox pid: 4220 mem: 1040.8 MiB (1.6%)
  3: cpu: 0.8% command: firefox pid: 351725 mem: 359.6 MiB (0.5%)
  4: cpu: 0.8% command: [kworker/u64:1-pm] pid: 352863 mem: 0.00 MiB (0.0%)
  5: cpu: 0.8% command: [kworker/u64:2-events_unbound] pid: 364328
  Memory top: 5 of 451
  1: mem: 1040.8 MiB (1.6%) command: firefox pid: 4220 cpu: 0.8%
  2: mem: 708.6 MiB (1.1%) command: firefox pid: 29648 cpu: 0.2%
  3: mem: 647.1 MiB (1.0%) command: steam pid: 2739 cpu: 0.3%
  4: mem: 575.7 MiB (0.9%) command: plasmashell pid: 1593 cpu: 0.1%
  5: mem: 565.1 MiB (0.9%) command: firefox pid: 6138 cpu: 0.3%
  Processes: 451 Power: uptime: 2d 1h 55m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 24.08 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 262 default: graphical
    tool: systemctl
  Compilers: clang: 23.1.4 gcc: 16.2.1 Shell: Zsh v: 5.9.2
    running-in: konsole inxi: 3.3.41
Welcome to the forum! :waving_hand:
Have you tried 6.18 LTS? It’s always good to have another kernel installed for fallback either way.
If you didn’t already know, you can install kernels via Manjaro Settings Manager (GUI) or mhwd-kernel (CLI).
Good.
The point is they are, except in rare cases, such as your example which I allowed, useless for the purpose of debugging your problem.
That is why we ask for text out put from the CLI. We can use that to debug your issue.
This is most likely a memory management bug caused by the interaction between the amdgpu kernel module, Mesa and KWin (Wayland) under kernel 7.3 (and 7.2). See here:
Artifacts in the screenshot:
Since the memory error occurs directly in the VRAM buffer of the compositor (KWin) and not in the graphics card’s display output, the corruption continues to flicker continuously within a screenshot manager like Spectacle and moves along natively when switching virtual desktops.
When the squares appear, you can immediately clear the corrupted memory buffer of the Plasma interface via the terminal without closing any open programs:
$ systemctl --user restart plasma-plasmashell.service
To identify the error following commands could be helpful to read the journal:
$ journalctl -b 0 | grep -E "amdgpu.*[fF]ence|TTM|ring.*timeout"
$ journalctl --user -b 0 -u plasma-kwin_wayland.service --grep="buffer|drm"
Please, share with us.
In EndeavourOS forum a fix is proposed:
There it is written that this error can be worked around by forcing KWin to strictly finalize framebuffer contents after rendering and temporarily disabling buffer aging.
First you need to create a config file:
$ nano ~/.config/environment.d/99-kwin-flicker.conf
Insert the following lines:
KWIN_USE_BUFFER_AGE=0
KWIN_DRM_FORCE_GL_FINISH_PRESENT=1
Restart the Plasma session or reboot.
A final upstream fix for amdgpu_ttm.c has already been incorporated into the kernel patches and will be delivered natively most likely via the next stable point releases for kernel 7.3.
Running $ systemctl --user restart plasma-plasmashell.service fixes the problem!
As for the diagnostics:
returned nothing, and relaxing to
$ journalctl -b 0 | grep -E "amdgpu.*timeout"
also returned nothing.
I did see [drm] *ERROR* Unsupported screen format RA24 little-endian (0x34324152), but this is another issue I think.
The other command results in:
Nov 08 21:14:49 desktop kwin_wayland[1583]: No backend specified, automatically choosing drm
Nov 10 19:51:24 desktop kwin_wayland[1583]: Failed to allocate a graphics buffer for a swapchain
I’ll keep using kernel 7.3, as the fix is not fare away and the steam frame dongle requires >=7.2, but as Yochanan mentioned I’ll install 6.18 LTS as a backup to be sure.
Thanks for the help!
