Weird quiet beeping/static sound playing constantly
Hello this is my first time using(not testing) Linux and I genuinely wanna learn it. But I’m quite sensitive to repeating sounds. I have Razer Kraken V3’s and they are not making the same sound when using them on Windows moreover I tested Fedora for a day once and the sound wasn’t there. I’m assuming it has to do with drivers but i’m not quite sure anymore. Beeping persists even when sound is muted in system. It sounds almost like a dog whistle or something like that, like its a ever changing mostly high pitched static/beep. Any pointers or any knowledge would be amazing.
Hello there @addjam and welcome to the forums.
Please post the result of inxi -zv8 so we get more info about your system.
When posting the info, either put three backticks ( ` -sign) on an empty line before and after it, or paint over the text and then press “preformatted text” </> from the post toolbar. With long entries, you might also want to use “hide details” on it from behind the + -button on the toolbar to make the post more manageable.
Hey so here’s the result :slight_smile:
Summary
Memory:   System RAM: total: 32 GiB available: 30.9 GiB used: 12.78 GiB (41.4%)   Message: For most reliable report, use superuser + dmidecode.   Array-1: capacity: 128 GiB slots: 4 modules: 2 EC: None     max-module-size: 32 GiB note: est.   Device-1: DIMMA1 type: no module installed   Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)     size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1     width (bits): data: 64 total: 64 manufacturer: Patriot     part-no: 6000 Series serial: <filter>   Device-3: DIMMB1 type: no module installed   Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)     size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1     width (bits): data: 64 total: 64 manufacturer: Patriot     part-no: 6000 Series serial: <filter> PCI Slots:   Permissions: Unable to run dmidecode. Root privileges required. CPU:   Info: model: AMD Ryzen 5 7500F bits: 64 type: MT MCP arch: Zen 4 gen: 4     level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)     model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C   Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 threads: 12 tpc: 2     smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB     desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB   Speed (MHz): avg: 5050 min/max: 545/5074 boost: enabled scaling:     driver: amd-pstate-epp governor: powersave cores: 1: 5050 2: 5050 3: 5050     4: 5050 5: 5050 6: 5050 7: 5050 8: 5050 9: 5050 10: 5050 11: 5050 12: 5050     bogomips: 88828   Flags: 3dnowprefetch abm adx aes amd_lbr_pmc_freeze amd_lbr_v2 aperfmperf     apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2     avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f     avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush     clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm     cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de     decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu     fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs     invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor     movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw     overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core     perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse     pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni     skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp     succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk     v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt     x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology   Vulnerabilities:   Type: gather_data_sampling status: Not affected   Type: indirect_target_selection status: Not affected   Type: itlb_multihit status: Not affected   Type: l1tf status: Not affected   Type: mds status: Not affected   Type: meltdown status: Not affected   Type: mmio_stale_data status: Not affected   Type: reg_file_data_sampling status: Not affected   Type: retbleed status: Not affected   Type: spec_rstack_overflow mitigation: Safe RET   Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via     prctl   Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer     sanitization   Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:     conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not     affected   Type: srbds status: Not affected   Type: tsa mitigation: Clear CPU buffers   Type: tsx_async_abort status: Not affected   Type: vmscape mitigation: IBPB before exit to userspace Graphics:   Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070     XT/9070 GRE] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-4     code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5     speed: 32 GT/s lanes: 16 ports: active: DP-1,DP-2     empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550     class-ID: 0300   Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9     compositor: kwin_wayland driver: X: loaded: amdgpu     unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi     gpu: amdgpu d-rect: 5120x1440 display-ID: 0   Monitor-1: DP-1 pos: primary,left model: Dell G2724D serial: <filter>     built: 2024 res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2     chroma: red: x: 0.659 y: 0.329 green: x: 0.286 y: 0.631 blue: x: 0.145     y: 0.055 white: x: 0.314 y: 0.329 size: 596x335mm (23.46x13.19")     diag: 684mm (26.9") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,     1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800, 1152x864,     1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400   EDID-Warnings: 1: parse_edid: unknown tag 112   Monitor-2: DP-2 pos: right model: Dell G2724D serial: <filter> built: 2024     res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2 chroma:     red: x: 0.659 y: 0.329 green: x: 0.286 y: 0.631 blue: x: 0.145 y: 0.055     white: x: 0.314 y: 0.329 size: 596x335mm (23.46x13.19")     diag: 684mm (26.9") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,     1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800, 1152x864,     1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400   EDID-Warnings: 1: parse_edid: unknown tag 112   API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi     device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi     wayland: drv: radeonsi x11: drv: radeonsi   API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2     glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi     gfx1201 LLVM 21.1.6 DRM 3.61 6.12.61-1-MANJARO) device-ID: 1002:7550     memory: 15.62 GiB unified: no display-ID: :1.0   API: Vulkan v: 1.4.328 layers: 6 device: 0 type: discrete-gpu name: AMD     Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.3.1-arch1.2     device-ID: 1002:7550 surfaces: N/A   Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo     de: kscreen-console,kscreen-doctor wl: wayland-info     x11: xdpyinfo, xprop, xrandr Audio:   Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio     driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16     bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403   Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio     vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4     speed: 16 GT/s lanes: 16 bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403   Device-3: Razer USA Kraken V3 driver: hid-generic,snd-usb-audio,usbhid     type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2     chip-ID: 1532:0549 class-ID: 0300 serial: <filter>   Device-4: JMTek LLC. USB PnP Audio Device     driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s     lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 0c76:161e class-ID: 0300   API: ALSA v: k6.12.61-1-MANJARO status: kernel-api with: aoss     type: oss-emulator tools: alsactl,alsamixer,amixer   Server-1: JACK v: 1.9.22 status: off tools: N/A   Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse     status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin     tools: pactl,pw-cat,pw-cli,wpctl Network:   Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169     v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0     chip-ID: 10ec:8125 class-ID: 0200   IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>   IP v4: <filter> type: dynamic noprefixroute scope: global     broadcast: <filter>   IP v6: <filter> type: noprefixroute scope: link   Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter     driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1     bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280   IF: wlp15s0 state: down mac: <filter>   Info: services: NetworkManager,systemd-timesyncd   WAN IP: <filter> Bluetooth:   Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1     speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:6 chip-ID: 0e8d:0616     class-ID: e001 serial: <filter>   Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends Logical:   Message: No logical block device data found. RAID:   Message: No RAID data found. Drives:   Local Storage: total: 1.82 TiB used: 134.18 GiB (7.2%)   SMART Message: Required tool smartctl not installed. Check --recommends   ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital     model: WD Blue SN5100 2TB size: 1.82 TiB block-size: physical: 512 B     logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>     fw-rev: 3523M0WD temp: 32.9 C scheme: GPT   Message: No optical or floppy data found. Partition:   ID-1: / raw-size: 1.23 TiB size: 1.23 TiB (100.00%) used: 134.15 GiB (10.6%)     fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A     uuid: dba7c183-21da-4278-b954-b5a75c7ccaf4   ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)     used: 31.7 MiB (16.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1     label: N/A uuid: A44B-E9A9   ID-3: /home raw-size: 1.23 TiB size: 1.23 TiB (100.00%)     used: 134.15 GiB (10.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4     label: N/A uuid: dba7c183-21da-4278-b954-b5a75c7ccaf4   ID-4: /var/cache raw-size: 1.23 TiB size: 1.23 TiB (100.00%)     used: 134.15 GiB (10.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4     label: N/A uuid: dba7c183-21da-4278-b954-b5a75c7ccaf4   ID-5: /var/log raw-size: 1.23 TiB size: 1.23 TiB (100.00%)     used: 134.15 GiB (10.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4     label: N/A uuid: dba7c183-21da-4278-b954-b5a75c7ccaf4 Swap:   Alert: No swap data was found. Unmounted:   ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>     label: N/A uuid: N/A   ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 600 GiB fs: ntfs label: N/A     uuid: BEB24C44B24C02FF USB:   Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0     speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002     class-ID: 0900   Device-1: 1-4:8 info: Razer USA DeathAdder V3 type: mouse,keyboard     driver: razermouse,usbhid interfaces: 3 rev: 2.0     speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA     chip-ID: 1532:00b2 class-ID: 0301   Hub-2: 1-6:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1     speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA     chip-ID: 174c:2074 class-ID: 0900   Device-1: 1-6.2:5 info: Razer USA BlackWidow V3 type: keyboard,mouse,HID     driver: razerkbd,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)     lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:024e class-ID: 0300   Device-2: 1-7:4 info: Micro Star MYSTIC LIGHT type: HID     driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)     lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0076 class-ID: 0300     serial: <filter>   Device-3: 1-8:6 info: MediaTek Wireless_Device type: bluetooth     driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1     mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>   Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1     speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003     class-ID: 0900   Hub-4: 2-6:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0     speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA     chip-ID: 174c:3074 class-ID: 0900   Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0     speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002     class-ID: 0900   Device-1: 3-2:2 info: Razer USA Kraken V3 type: audio,HID     driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0     speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA     chip-ID: 1532:0549 class-ID: 0300 serial: <filter>   Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1     speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003     class-ID: 0900   Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0     speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002     class-ID: 0900   Device-1: 5-2:2 info: JMTek LLC. USB PnP Audio Device type: audio,HID     driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1     speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA     chip-ID: 0c76:161e class-ID: 0300   Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1     speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003     class-ID: 0900   Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0     speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002     class-ID: 0900 Sensors:   System Temperatures: cpu: 53.1 C mobo: 40.2 C gpu: amdgpu temp: 53.0 C     mem: 76.0 C   Fan Speeds (rpm): N/A gpu: amdgpu fan: 0 Repos:   Packages: 1326 pm: pacman pkgs: 1306 libs: 374 tools: pamac,yay pm: flatpak     pkgs: 20   Active pacman repo servers in: /etc/pacman.d/mirrorlist     1: https://mirrors2.manjaro.org/stable/$repo/$arch     2: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch     3: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch Processes:   CPU top: 5 of 402   1: cpu: 512%     command: Z:\home\addjam\.local\share\Steam\steamapps\common\Space pid: 13287     mem: 5947.0 MiB (18.7%)   2: cpu: 20.9% command: steam pid: 2816 mem: 350.6 MiB (1.1%)   3: cpu: 14.2% command: exe pid: 6744 mem: 528.2 MiB (1.6%)   4: cpu: 7.6% command: steamwebhelper pid: 3158 mem: 668.5 MiB (2.1%)   5: cpu: 7.5% command: kwin_wayland pid: 1311 mem: 346.0 MiB (1.0%)   Memory top: 5 of 402   1: mem: 5947.0 MiB (18.7%)     command: Z:\home\addjam\.local\share\Steam\steamapps\common\Space pid: 13287     cpu: 512%   2: mem: 697.8 MiB (2.2%) command: firefox pid: 5221 cpu: 3.2%   3: mem: 668.5 MiB (2.1%) command: steamwebhelper pid: 3158 cpu: 7.6%   4: mem: 650.7 MiB (2.0%) command: plasmashell pid: 1578 cpu: 0.6%   5: mem: 562.6 MiB (1.7%) command: firefox pid: 4862 cpu: 3.0% Info:   Processes: 402 Power: uptime: 1h 9m states: freeze,mem,disk suspend: deep     avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,     suspend, test_resume image: 12.34 GiB services: org_kde_powerdevil,upowerd     Init: systemd v: 258 default: graphical tool: systemctl   Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40  ~ >
That is not the full output from inxi -zv8 please redo and post the full out put using the </> button to format it.
I don’t even imagine how you succeeded to post the inxi on one line, i think you are the first with that formatting error ever :facepalm: :grin:
Could you try once more? Select, copy, paste…
MS-Windows. Like MS-DOS before it, it requires a combination of a newline character and a carriage return as line breaks, whereas UNIX only needs a newline character. :wink:
inxi -zv8 | grep -vE 'MAC|UUID|IP' > ~/Desktop/inxi.txt
Produces a nicely formatted text file…
Pasted text file...
  Kernel: 6.18.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    udev.log_priority=3 amd_pstate=passive snd_hda_intel.power_save=0
    systemd.battery_check=false highres=on acpi_irq_balance nokaslr
    random.trust_cpu=on cpuidle.governor=teo rcupdate.rcu_expedited=1
    rd.systemd.show_status=true mitigations=off clocksource=tsc
    transparent_hugepage=never numa_balancing=disable numa=off pcie_aspm=off
    nowatchdog nmi_watchdog=0 audit=0
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.20.0
    wm: kwin_wayland with: krunner vt: 2 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550M Steel Legend
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: P2.30 date: 02/24/2022
  System RAM: total: 16 GiB available: 14.99 GiB used: 5.32 GiB (35.5%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3600C17D4/8GX serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500012
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2394 min/max: 404/4466 boost: enabled scaling:
    driver: amd-pstate governor: schedutil cores: 1: 2394 2: 2394 3: 2394
    4: 2394 5: 2394 6: 2394 7: 2394 8: 2394 9: 2394 10: 2394 11: 2394 12: 2394
    bogomips: 93426
    xsaves xtopology
  Type: spec_rstack_overflow status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Type: tsa status: Vulnerable
  Type: vmscape status: Vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: HDMI-A-1 empty: DP-1,DP-2 bus-ID: 04:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 43.0 C
    gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: LG (GoldStar) TV serial: <filter> built: 2011
    res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 305 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 160x90mm (6.3x3.54") diag: 184mm (7.2")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1400x1050, 1600x900, 1280x1024,
    1440x900, 1360x768, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
    renoir ACO DRM 3.64 6.18.0-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: no display-ID: :0.0
  API: Vulkan v: 1.4.328 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.3.1-arch1.2
    device-ID: 1002:1638 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASRock
    bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.0-1-MANJARO status: kernel-api with: aoss
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
  IF-ID-1: zt3jnqw6tl state: unknown speed: 10000 Mbps duplex: full
    mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
    bus-ID: 3-2.3.4:7 chip-ID: 0a12:0001 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
    lmp-v: 6 status: discoverable: no pairing: yes class-ID: 6c0104
  Local Storage: total: 9.32 TiB used: 4.2 TiB (45.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MD04ACA400
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD40EZAX-00C8UB0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1A01
  ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD20EZRX-00DC0B0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
    scheme: GPT
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 164.62 GiB (72.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: ROOT
    uuid: a0074377-fd97-4125-9151-1b09cc8e32cb
    used: 468 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: F99D-EAF9
  ID-3: /mnt/T4 raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
    used: 1.3 TiB (36.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: T4
    uuid: 1e85632e-1c5f-4da4-a229-e349fba9efc9
  ID-4: /mnt/W2 raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.23 TiB (67.4%) fs: btrfs dev: /dev/sdd1 maj-min: 8:49 label: W2
    uuid: 7a89257a-6b14-46ba-85d9-55f079184774
  ID-5: /mnt/W4 raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
    used: 1.51 TiB (42.3%) fs: ext4 dev: /dev/sdc maj-min: 8:32 label: W4
    uuid: 05e296c6-eb11-4d00-89b1-c8318c4549c5
  ID-6: /tmp/.mount_nextcljomIma raw-size: N/A size: 183.9 MiB
    used: 183.9 MiB (100.0%) fs: fuse.nextcloud_desktop_sync_client.appimage
    source: ERR-102
  Kernel: swappiness: 50 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-2: swap-2 type: zram size: 16 GiB used: 3.05 GiB (19.1%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
  Hub-2: 1-7:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-8:3 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
  Hub-6: 3-2.2:3 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Hub-7: 3-2.3:4 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Device-1: 3-2.3.1:5 info: 2.4G Wireless type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 32c2:0066 class-ID: 0301
  Device-2: 3-2.3.3:6 info: China Resource Semico 2.4 Wireless Device
    type: HID,keyboard,mouse driver: hid-generic,usbhid interfaces: 4 rev: 1.1
    chip-ID: 1a2c:8fff class-ID: 0300 serial: <filter>
  Device-3: 3-2.3.4:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
    mode) type: bluetooth driver: btusb interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
    class-ID: e001
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
  Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-11: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 60.2 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Packages: 2629 pm: pacman pkgs: 2608 libs: 461 tools: octopi,pamac,paru,yay
    pm: flatpak pkgs: 21
    1: https://mirror.freedif.org/Manjaro/testing/$repo/$arch
    2: https://manjaro.kurdy.org/testing/$repo/$arch
    3: https://kartolo.sby.datautama.net.id/manjaro/testing/$repo/$arch
    4: https://mirror.phoepsilonix.love/manjaro/testing/$repo/$arch
    5: https://manjaro.syxpi.fr/manjaro/testing/$repo/$arch
    6: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/testing/$repo/$arch
    7: https://mirrors2.manjaro.org/testing/$repo/$arch
    8: https://mirror.raiolanetworks.com/manjaro/testing/$repo/$arch
    9: https://manjaro.mirrors.lavatech.top/testing/$repo/$arch
    10: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    11: https://gsl-syd.mm.fcix.net/manjaro/testing/$repo/$arch
    12: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    13: https://ask4.mm.fcix.net/manjaro/testing/$repo/$arch
    14: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
    15: https://distrohub.kyiv.ua/manjaro/testing/$repo/$arch
    16: https://mirrors.dotsrc.org/manjaro/testing/$repo/$arch
    17: https://manjaro.mirrors.uk2.net/testing/$repo/$arch
    18: https://mirror.fcix.net/manjaro/testing/$repo/$arch
    19: https://mirror.2degrees.nz/manjaro/testing/$repo/$arch
    20: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
    21: https://mirrors.ft.uam.es/manjaro/testing/$repo/$arch
    22: https://ziply.mm.fcix.net/manjaro/testing/$repo/$arch
    23: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
    24: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    25: https://mirror.telepoint.bg/manjaro/testing/$repo/$arch
    26: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    27: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
    28: https://muug.ca/mirror/manjaro/testing/$repo/$arch
    29: https://cofractal-ewr.mm.fcix.net/manjaro/testing/$repo/$arch
    30: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    31: https://mirror.vinehost.net/manjaro/testing/$repo/$arch
    32: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
    33: https://manjaro.mirror.wearetriple.com/testing/$repo/$arch
    34: https://repo.ialab.dsu.edu/manjaro/testing/$repo/$arch
    35: https://ftp.gwdg.de/pub/linux/manjaro/testing/$repo/$arch
    36: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    37: https://mirror.koddos.net/manjaro/testing/$repo/$arch
    38: https://edgeuno-bog2.mm.fcix.net/manjaro/testing/$repo/$arch
    39: https://mirror.alpix.eu/manjaro/testing/$repo/$arch
    40: https://ftp.free.org/mirrors/repo.manjaro.org/repos/testing/$repo/$arch
    41: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
    42: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/testing/$repo/$arch
    43: https://mirrors.gigenet.com/manjaro/testing/$repo/$arch
    44: https://manjaro.ynh.ovh/testing/$repo/$arch
    45: https://ftpmirror1.infania.net/mirror/manjaro/testing/$repo/$arch
    46: https://mirror.init7.net/manjaro/testing/$repo/$arch
    47: https://mirrors.sjtug.sjtu.edu.cn/manjaro/testing/$repo/$arch
    48: https://mirror.csclub.uwaterloo.ca/manjaro/testing/$repo/$arch
    49: https://mirror.xenyth.net/manjaro/testing/$repo/$arch
    50: https://mirror.easyname.at/manjaro/testing/$repo/$arch
    51: https://mirror.futureweb.be/manjaro/testing/$repo/$arch
    52: https://manjaro.c3sl.ufpr.br/testing/$repo/$arch
    53: https://mirror.alwyzon.net/manjaro/testing/$repo/$arch
    54: https://mirrors.ocf.berkeley.edu/manjaro/testing/$repo/$arch
    55: https://mirrors.ucr.ac.cr/manjaro/testing/$repo/$arch
    56: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/testing/$repo/$arch
    57: https://mirror.23m.com/manjaro/testing/$repo/$arch
    58: https://mirror.hostiko.network/manjaro/testing/$repo/$arch
    59: https://mirror.bouwhuis.network/manjaro/testing/$repo/$arch
    60: https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
    61: https://manjaro.mirror-services.net/pub/testing/$repo/$arch
    62: https://mirrors.up.pt/pub/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 400
  1: cpu: 9.4% command: kitty pid: 313462 mem: 112.1 MiB (0.7%)
  2: cpu: 6.2% command: desktop.so started-by: kioworker pid: 313555
    mem: 24.8 MiB (0.1%)
  3: cpu: 4.2% command: firefox pid: 308637 mem: 498.2 MiB (3.2%)
  4: cpu: 3.5% command: firefox pid: 308880 mem: 392.6 MiB (2.5%)
  5: cpu: 2.9% command: fish pid: 313496 mem: 12.4 MiB (0.0%)
  Memory top: 5 of 400
  1: mem: 664.6 MiB (4.3%) command: firefox pid: 3342 cpu: 2.3%
  2: mem: 498.2 MiB (3.2%) command: firefox pid: 308637 cpu: 4.2%
  3: mem: 452.0 MiB (2.9%) command: firefox pid: 3672 cpu: 0.6%
  4: mem: 392.6 MiB (2.5%) command: firefox pid: 308880 cpu: 3.5%
  5: mem: 377.7 MiB (2.4%) command: plasmashell pid: 2049 cpu: 0.4%
  Processes: 400 Power: uptime: 20h 31m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 5.97 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: fish v: 4.2.1 default: Zsh
    v: 5.9 running-in: kitty inxi: 3.3.40
Maybe that’s a nicer way to go for noobs - I do like a text file… it’s sad that folks can’t just drag and drop to attach a .txt file to the forum (only images, which are discouraged).
To help over come that annoyance, some text apps (particularly editors) will give a choice of \n, \r, or \n\r so the document can be used interchangeably between systems.
This is nothing new. Neither is the fact that lesser and lesser people seem to be aware of it; perhaps because they typically doesn’t see them unless they check settings. :man_shrugging:
If an IDE is used, when let’s say coding PHP, they are quite commonplace; used to force PHP output to follow the expected flow of a HTML document, for example.
Hm, sure, let’s make that happen…
  • Q: My thing stucked and it no wurkz! Haaalp! plz!! :sob:
  • A: Here, load dis worm text fix 2 ya PC!! It free!!. :smiling_face_with_horns:
Hey i think i managed to fix it the way you guys want. :sweat_smile:
Edit. I also made sure if its the full output of ~ > inxi -zv8.
Summary
inxi -zv8:
  Kernel: 6.12.61-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=dba7c183-21da-4278-b954-b5a75c7ccaf4 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
  Type: Desktop Mobo: Micro-Star model: B850 GAMING PLUS WIFI6E (MS-7E80)
    v: 1.0 serial: <superuser required> uuid: <superuser required>
    Firmware: UEFI vendor: American Megatrends LLC. v: 1.A10 date: 06/02/2025
  System RAM: total: 32 GiB available: 30.9 GiB used: 3.3 GiB (10.7%)
  Device-1: DIMMA1 type: no mod[/details]ule installed
  Speed (MHz): avg: 545 min/max: 545/5074 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 545 2: 545 3: 545
    4: 545 5: 545 6: 545 7: 545 8: 545 9: 545 10: 545 11: 545 12: 545
    bogomips: 88840
    affected
    class-ID: 0300
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1~ > inxi -zv8
  Local Storage: total: 1.82 TiB used: 135.49 GiB (7.3%)
    fw-rev: 3523M0WD temp: 23.9 C scheme: GPT
  ID-1: / raw-size: 1.23 TiB size: 1.23 TiB (100.00%) used: 135.46 GiB (10.7%)
    used: 135.46 GiB (10.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  Device-1: 1-4:2 info: Razer USA DeathAdder V3 type: mouse,keyboard
    driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00b2 class-ID: 0301
    serial: <filter>
  System Temperatures: cpu: 38.1 C mobo: 27.5 C gpu: amdgpu temp: 26.0 C
    mem: 52.0 C
    pkgs: 20
Processes:
  CPU top: 5 of 360
  1: cpu: 12.7% command: brave pid: 4996 mem: 301.3 MiB (0.9%)
  2: cpu: 12.6% command: brave pid: 4657 mem: 494.1 MiB (1.5%)
  3: cpu: 8.8% command: brave pid: 4846 mem: 347.9 MiB (1.0%)
  4: cpu: 7.3% command: kwin_wayland pid: 3814 mem: 333.4 MiB (1.0%)
  5: cpu: 7.3% command: brave pid: 4753 mem: 363.2 MiB (1.1%)
  Memory top: 5 of 360
  1: mem: 550.6 MiB (1.7%) command: plasmashell pid: 4116 cpu: 7.0%
  2: mem: 494.1 MiB (1.5%) command: brave pid: 4657 cpu: 12.6%
  3: mem: 477.8 MiB (1.5%) command: manjaro-hello started-by: python3
    pid: 4386 cpu: 5.0%
  4: mem: 363.2 MiB (1.1%) command: brave pid: 4753 cpu: 7.3%
  5: mem: 347.9 MiB (1.0%) command: brave pid: 4846 cpu: 8.8%
  Processes: 360 Power: uptime: 4m states: freeze,mem,disk suspend: deep
