I have a very weird issue with libreoffice: launching it from konsole libreoffice --writer executes without issues, however using an desktop launcher with the exact same command it gets stuck in the logo.
Moreover launching from terminal it executes natively in wayland, while the desktop launcher executes it in xwayland. I have reviewed the desktop launcher and found nothing to trigger this:
content of /usr/lib/libreoffice/share/xdg/writer.desktop
# This file is part of the LibreOffice project.
# This Source Code Form is subject to the terms of the Mozilla Public
# License, v. 2.0. If a copy of the MPL was not distributed with this
# file, You can obtain one at http://mozilla.org/MPL/2.0/.
# This file incorporates work covered by the following license notice:
# Licensed to the Apache Software Foundation (ASF) under one or more
# contributor license agreements. See the NOTICE file distributed
# with this work for additional information regarding copyright
# ownership. The ASF licenses this file to you under the Apache
# License, Version 2.0 (the "License"); you may not use this file
# except in compliance with the License. You may obtain a copy of
# the License at http://www.apache.org/licenses/LICENSE-2.0 .
[Desktop Entry]
Version=1.0
Terminal=false
Icon=libreoffice-writer
Type=Application
Categories=Office;WordProcessor;X-Red-Hat-Base;X-MandrivaLinux-Office-Wordprocessors;
Exec=libreoffice --writer %U
MimeType=application/vnd.oasis.opendocument.text;application/vnd.oasis.opendocument.text-template;application/vnd.oasis.opendocument.text-web;application/vnd.oasis.opendocument.text-master;application/vnd.oasis.opendocument.text-master-template;application/vnd.sun.xml.writer;application/vnd.sun.xml.writer.template;application/vnd.sun.xml.writer.global;application/msword;application/vnd.ms-word;application/x-doc;application/x-hwp;application/rtf;text/rtf;application/vnd.wordperfect;application/wordperfect;application/vnd.lotus-wordpro;application/vnd.openxmlformats-officedocument.wordprocessingml.document;application/vnd.ms-word.document.macroEnabled.12;application/vnd.openxmlformats-officedocument.wordprocessingml.template;application/vnd.ms-word.template.macroEnabled.12;application/vnd.ms-works;application/vnd.stardivision.writer-global;application/x-extension-txt;application/x-t602;text/plain;application/vnd.oasis.opendocument.text-flat-xml;application/x-fictionbook+xml;application/macwriteii;application/x-aportisdoc;application/prs.plucker;application/vnd.palm;application/clarisworks;application/x-sony-bbeb;application/x-abiword;application/x-iwork-pages-sffpages;application/x-mswrite;application/x-starwriter;
Name=LibreOffice Writer
GenericName=Word Processor
GenericName[en]=Word Processor
Comment=Create and edit text and graphics in letters, reports, documents and Web pages by using Writer.
Comment[en]=Create and edit text and images in letters, reports, documents and Web pages by using Writer.
StartupNotify=true
X-GIO-NoFuse=true
Keywords=Text;Letter;Fax;Document;OpenDocument Text;Microsoft Word;Microsoft Works;Lotus WordPro;OpenOffice Writer;CV;odt;doc;docx;rtf;
InitialPreference=5
StartupWMClass=libreoffice-writer
X-KDE-Protocols=file,http,ftp,webdav,webdavs
Actions=NewDocument;
[Desktop Action NewDocument]
Name=New Document
Name[en]=New Document
Icon=document-new
No problems with other desktop launchers, yes I’m in manjaro KDE wayland
Are you using libreoffice fresh or still ?
There is a config file under .config/libreoffice/.
Maybe copying this to .bak and then starting Libreoffice helps.
Launching from terminal the start center itself i get
[alex@alex-b450aoruselite ~]$ libreoffice
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
So perhaps it cannot activate the writer after this? The start center opens fine from terminal
The Calc throw this
[alex@alex-b450aoruselite ~]$ libreoffice --calc
This plugin supports grabbing the mouse only for popup windows
[alex@alex-b450aoruselite ~]$ kioclient exec /usr/share/applications/libreoffice-writer.desktop
kf.config.core: "KConfigIni: In file /usr/share/applications/electrum.desktop, line 6: " "Invalid escape sequence \"\\\"\"."
kf.config.core: "KConfigIni: In file /usr/share/applications/electrum.desktop, line 21: " "Invalid escape sequence \"\\\"\"."
kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
kf.service.sycoca: Invalid Service : "/usr/share/applications/qemu.desktop"
kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
it started without the ` . I have noticed a permission problem (how?)
[alex@alex-b450aoruselite ~]$ kioclient exec `/usr/lib/libreoffice/share/xdg/writer.desktop`
bash: /usr/lib/libreoffice/share/xdg/writer.desktop: Permission denied
kioclient: Syntax error, not enough arguments
--------------------------------------------------------------------------------------------------------------------------- 10:49:46
[alex@alex-b450aoruselite ~]$ kioclient exec /usr/lib/libreoffice/share/xdg/writer.desktop
--------------------------------------------------------------------------------------------------------------------------- 10:50:00
[alex@alex-b450aoruselite ~]$ qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
But not the other errors, and Writer launches OK
what is electrum, and how is it related to LibreOffice?
OR
Are you trying to tell me that on a Wayland system all those .desktop files are supposed to be called when ever you open an application, just so wayland can work out what icon to display?
