Hi all, 3 months ago I bought a new Samsung T350 monitor, but I have some weird patterns (vertical lines, flickering, and things like “ghost screen”) on the screen. I discovered that appears sometimes only when I use the terminal on XFCE with NVIDIA proprietary drivers.
inxi -Fxxxza –no-host:
Kernel: 5.10.96-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=544492c1-f068-4da0-aff5-7a8a309f4311 rw quiet
udev.log_priority=3 apparmor=1 security=apparmor
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: Z170-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3805
date: 05/16/2018
Info: model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEA
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 801 high: 804 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 804 2: 800 3: 800 4: 800
bogomips: 28009
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: ZOTAC driver: nvidia
v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1401 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fba
class-ID: 0403
Sound Server-1: ALSA v: k5.10.96-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8179 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
vendor: ASUSTeK PRIME B450M-A driver: r8168 v: 8.049.02-NAPI modules: r8169
port: c000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.95 TiB used: 1.05 TiB (35.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 223.57 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM12.3
temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000VN007-2AH16M
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5980 serial: <filter> rev: SC60 scheme: GPT
ID-1: / raw-size: 38.42 GiB size: 37.57 GiB (97.78%)
used: 22.56 GiB (60.0%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 150 MiB size: 147.7 MiB (98.45%)
used: 301 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 201 Uptime: 2h 19m wakeups: 0 Memory: 31.3 GiB
used: 3.36 GiB (10.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1294 lib: 358 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
What I tried (when the problem appears):
• Power off and unplug it from the power monitor and pc.
• Disconnect the HDMI cable.
• Connect the monitor to another pc.
• Reboot into windows.
• Enter the UEFI
Here some images: Imgur: The magic of the Internet
In all cases, the problem persist, so I think the problem is the monitor, because others monitors doesn’t have that problem, and when the pattern appears, the only solution is to wait around 20-30 minutes until they disappear and everything returns to normal. But on the other hand, I tested it on Manjaro KDE (proprietary drivers) and Xubuntu and Manjaro XFCE (open source drivers) and I don’t have that problem. The strange thing is that the trigger of the problem is only Manjaro XFCE with proprietary drivers, in addition, it also happens in the live usb.
Does the terminal cause the monitor (which could have a manufacturing defect) to fail? Any ideas?
Thanks
