Hi,
I don’t know why webview on Telegram desktop is not working in Manjaro.
By webview I mean “instant view” of links and bot front-ends like Wallet or Durger King.
Example below:
Did anyone found a way to make it work?
My system:
Kernel: 6.1.90-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: GNOME v: 46.1 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASRock model: Z790 Taichi serial: <superuser required>
UEFI: American Megatrends LLC. v: 10.01 date: 10/06/2023
Info: 24-core (8-mt/16-st) model: 13th Gen Intel Core i9-13900KF bits: 64
type: MST AMCP arch: Raptor Lake rev: 1 cache: L1: 2.1 MiB L2: 32 MiB
L3: 36 MiB
Speed (MHz): avg: 1165 high: 5497 min/max: 800/5500:5800:4300 cores:
1: 800 2: 800 3: 5497 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800
11: 800 12: 800 13: 800 14: 800 15: 800 16: 800 17: 4301 18: 800 19: 4299
20: 800 21: 800 22: 800 23: 800 24: 800 25: 800 26: 800 27: 800 28: 800
29: 800 30: 800 31: 800 32: 800 bogomips: 191744
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Gigabyte driver: nvidia
v: 550.78 arch: Lovelace bus-ID: 01:00.0
Device-2: Insta360 Link driver: snd-usb-audio,uvcvideo type: USB
bus-ID: 1-5:4
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6 driver:
X: loaded: nvidia gpu: nvidia resolution: 1920x1080
API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA AD102 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: Logitech G733 Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-2:3
Device-4: Insta360 Link driver: snd-usb-audio,uvcvideo type: USB
bus-ID: 1-5:4
Device-5: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 1-7.3:12
API: ALSA v: k6.1.90-1-MANJARO status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 1.0.5 status: off
Server-4: PulseAudio v: 17.0 status: active
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169
v: kernel port: 3000 bus-ID: 6e:00.0
IF: enp110s0 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:14
Report: btmgmt ID: hci1 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Device-2: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB
bus-ID: 1-7.1:8
Report: ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 5.18 TiB used: 78.96 GiB (1.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
temp: 45.9 C
ID-2: /dev/nvme1n1 vendor: Western Digital model: WDS100T3X0C-00SJG0
size: 931.51 GiB temp: 42.9 C
ID-3: /dev/nvme2n1 model: PCIe SSD size: 111.79 GiB temp: 34.9 C
ID-4: /dev/sda vendor: SanDisk model: SSD PLUS 240GB size: 223.58 GiB
ID-5: /dev/sdb vendor: Samsung model: SSD 850 PRO 1TB size: 953.87 GiB
ID-6: /dev/sdc vendor: Crucial model: CT1050MX300SSD1 size: 978.09 GiB
ID-7: /dev/sdd vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
ID-1: / size: 218.72 GiB used: 78.96 GiB (36.1%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 316 KiB (0.1%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 33.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 64 GiB note: est. available: 62.62 GiB used: 5.26 GiB (8.4%)
Processes: 527 Uptime: 17m Init: systemd
Packages: 1529 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
inxi: 3.3.34
Telegram Version: 5.1.4 (not working since many versions before)
Telegram Log:
flatpak run org.telegram.desktop
Gtk-Message: 08:00:37.319: Failed to load module "xapp-gtk3-module"
Gtk-Message: 08:00:37.338: Failed to load module "canberra-gtk-module"
Qt: Session management error: Could not open network socket
QPainter::begin: Paint device returned engine == 0, type: 2
QWidget::render: Cannot render with an inactive painter
qt.svg: Error while inflating gzip file: SVG format check failed
Gtk-Message: 08:00:42.424: Failed to load module "xapp-gtk3-module"
Gtk-Message: 08:00:42.445: Failed to load module "canberra-gtk-module"
Gtk-Message: 08:00:42.511: Failed to load module "xapp-gtk3-module"
Gtk-Message: 08:00:42.533: Failed to load module "canberra-gtk-module"
src/nv_gbm.c:288: GBM-DRV error (nv_gbm_create_device_native): nv_common_gbm_create_device failed (ret=-1)
KMS: DRM_IOCTL_MODE_CREATE_DUMB failed: Permission denied
Failed to create GBM buffer of size 384x590: Permission denied
