Not entirely sure how to describe this error, but after updating my Kernel alot of website glitch out, when interacting with specific elements, e.g. if I open an image on discord its basically guaranteed to glitch out, and it will flash and go invisible/visible alot.
Im not really sure what the root cause is, whether its a graphics driver issue, or a kernel issue, and I appreciate its not really much for you guys to work off, but any help would be appreciated
$ inxi -Fza
Kernel: 6.6.47-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=3dbd5efc-d3d1-4379-a733-f0c1a89e6059 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-F GAMING v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 0904 date: 09/14/2018
Info: model: Intel Core i3-8350K bits: 64 type: MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4000 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 4000 2: 4000 3: 4000 4: 4000 bogomips: 32013
disabled
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
Device-1: NVIDIA GP104 [GeForce GTX 1070] driver: nvidia v: 550.107.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1
bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia display-ID: 0
Monitor-1: HDMI-A-1 res: 2752x1152 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: zink
inactive: gbm,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.107.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 550.107.02
device-ID: 10de:1b81 surfaces: xcb,xlib,wayland
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Razer USA Barracuda Pro 2.4
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14.1:36 chip-ID: 1532:053a class-ID: 0301
serial: <filter>
API: ALSA v: k6.6.47-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF-ID-1: br-1494bb5b81e2 state: down mac: <filter>
IF-ID-2: br-1f30ec505556 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-50b69e2fbee8 state: down mac: <filter>
IF-ID-4: br-81b83e4653ad state: down mac: <filter>
IF-ID-5: br-8ab10e42ee70 state: down mac: <filter>
IF-ID-6: br-96f2b79ea0e8 state: down mac: <filter>
IF-ID-7: docker0 state: down mac: <filter>
IF-ID-8: veth3d53281 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: vethdd2fe6e state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Local Storage: total: 22.74 TiB used: 12.42 TiB (54.6%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST22000NT001-3LS101
size: 20.01 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20EURX-63T0FY0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80
ID-1: / raw-size: 833.56 GiB size: 819.4 GiB (98.30%)
used: 236.73 GiB (28.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
used: 25.9 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB available: 31.26 GiB used: 9.11 GiB (29.1%)
Processes: 315 Power: uptime: 5h 51m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1272 libs: 353 tools: pamac pm: flatpak pkgs: 0
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.32
running-in: konsole inxi: 3.3.36
Hi @JDChris100 ,
Have you tried with a different kernel again?
ydar
9 October 2024 13:38
3
The info you show isn’t for the latest released kernel version or nvidia driver that’s available in the stable branch.
Kernel should be 6.6.52-1, nvidia should be 550.120-2
Just updated and still getting the same issues
Kernel: 6.6.52-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Speed (MHz): avg: 4001 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 4001 2: 4001 3: 4001 4: 4001 bogomips: 32013
disabled
Device-1: NVIDIA GP104 [GeForce GTX 1070] driver: nvidia v: 550.120
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 550.120 device-ID: 10de:1b81
lanes: 1 mode: 1.1 bus-ID: 1-14.1:3 chip-ID: 1532:053a class-ID: 0301
serial: <filter>
API: ALSA v: k6.6.52-1-MANJARO status: kernel-api with: aoss
IF-ID-2: br-1f30ec505556 state: down mac: <filter>
fw-rev: 0A80
used: 238.82 GiB (29.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 50.0 C mobo: N/A
Memory: total: 32 GiB available: 31.26 GiB used: 3.78 GiB (12.1%)
Processes: 245 Power: uptime: 2m states: freeze,mem,disk suspend: deep
tool: systemctl
Packages: pm: pacman pkgs: 1292 libs: 363 tools: pamac pm: flatpak pkgs: 0
So it happened after switching from 6.9.12-3-MANJARO I tried using 6.10.11-2 and 6.11.0-6 but both of those just gave me a black screen and didnt boot correctly
I also tried it with 6.1.111-1 and it had the same errors. So its possible the kernel change was unrelated?
Quite likely. But as to what,
Apart of telling you to make sure all your .pacnew files are handled,
https://wiki.archlinux.org/title/Pacman/Pacnew_and_Pacsave#.pacnew
I have absolutely no idea how to proceed.
Sorry!
@JDChris100 , so you have website glitches, fine. Why don’t you share with us what browser you are using?
Please start your browser without addons/extensions enabled.
If these glitches you describe seem to magically go away , then enable each extension – one at a time (testing each time) – until you find the extension that causes these glitches…
Then remove that extension, and either:
See if removing it, closing/reopening the browser and reinstalling the extension makes any difference; or…
Never install the extension again.
Cheers.
Default Firefox, but it also happens on the Discord app, which I believe is chromium
And what are the results of:
soundofthunder:
Cheers.
Sorry, thought I replied to this, this doesnt fix it either.
Honestly, im also getting alot of random other issues, and alot of stuff seems to be broken, so i might try a factory reset and see if that fixes it
firefox about:support
has 3 buttons to Refresh Firefox ; run Troubleshooting Mode and Clear startup cache
