Hello there,
since the last update it is not possible anymore to mount some WebDAV folders in Nautilus.
Especially our School Server (IServ) is affected.
I get a sign in dialogue but nothing happens, when I type in my user name and password.
This used to work flawlessly. It is very annoying, that such a useful feature suddenly broke down.
The only way to mount my online WebDav-folders was with this command:
sudo mount.davfs https://webdav.server.de/ /home/username/mountfolder -o rw,uid=username
While this seemed to work at the beginning, it led to the problem, that online documents, that I opened via nautilus in LIbreOffice and that I tried to save with the edited changes, suddenly were saved as 0 KB files and their whole content was lost. This is terrible!!!
Please, can somebody fix this WebDav issue? The same issue ocures on two different Versions of Manjaro (Gnome and XFCE) just after installing all updates. By the way: in Windows and Ubuntu there are no issues to connect to WebDav-Servers in the local file manager.
Thanks in advance
Salih
