I got a webcam with a microphone off amazon: https://www.amazon.com/gp/product/B07MVY1H9V
and I’m on a desktop, using the i3 distro of manjaro. alsamixer sees the microphone, but when I try to record things with audacity, nothing shows, and when I try testing with zoom/google meet, nothing shows. Not sure what to do?
Welcome to Manjaro!
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Thanks for the suggestions. Here’s inxi --full --verbosity=7 --filter --no-host
Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: Micro product: B244 v: 1.0 serial: <filter>
Mobo: ASRock model: A320M-HDV R4.0 serial: <filter>
UEFI: American Megatrends v: P3.70F date: 01/15/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: Discharging
RAM: total: 5.79 GiB used: 2.48 GiB (42.9%)
RAM Report:
Topology: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics
bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
bogomips: 59231
Speed: 1315 MHz min/max: 1400/3700 MHz boost: enabled
Core speeds (MHz): 1: 1259 2: 1260 3: 1259 4: 1260 5: 1260 6: 1259
7: 1260 8: 1259
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc
cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep
sev sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a
ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Device-1: AMD Picasso driver: amdgpu v: kernel bus ID: 07:00.0
chip ID: 1002:15d8
Display: x11 server: X.Org 1.20.8 compositor: compton
driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: 1600x900~60Hz s-dpi: 96
OpenGL: renderer: AMD RAVEN (DRM 3.37.0 5.7.14-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 1002:15de
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 07:00.6 chip ID: 1022:15e3
Device-3: Microdia Webcam Vitade AF type: USB
driver: snd-usb-audio,uvcvideo bus ID: 1-1:4 chip ID: 0c45:6366
serial: <filter>
Sound Server: ALSA v: k5.7.14-1-MANJARO
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel bus ID: 04:00.0 chip ID: 8086:24fb
IF: wlp4s0 state: up mac: <filter>
vendor: ASRock driver: r8169 v: kernel port: f000 bus ID: 05:00.0
chip ID: 10ec:8168
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 232.89 GiB used: 62.52 GiB (26.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS250G2B0C-00PXH0
size: 232.89 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: 211070WD scheme: GPT
ID-1: / size: 191.87 GiB used: 62.50 GiB (32.6%) fs: ext4
dev: /dev/nvme0n1p5 label: N/A
uuid: 3c1f6537-f49d-417d-927e-4cf969842d51
ID-2: /boot/efi size: 252.0 MiB used: 25.1 MiB (10.0%) fs: vfat
dev: /dev/nvme0n1p1 label: SYSTEM uuid: 3895-0B1B
ID-1: /dev/nvme0n1p2 size: 128.0 MiB fs: <superuser/root required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 size: 36.17 GiB fs: ntfs label: Windows
uuid: 74729591729558A6
ID-3: /dev/nvme0n1p4 size: 400.0 MiB fs: ntfs label: Windows RE tools
uuid: 942A95A72A9586C0
Hub: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:4 info: Microdia Webcam Vitade AF type: Video,Audio
chip ID: 0c45:6366 serial: <filter>
Device-2: 1-4:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 046d:c534
Device-3: 1-9:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aa7
Hub: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1
speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
Hub: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1
System Temperatures: cpu: 38.4 C mobo: N/A gpu: amdgpu temp: 38 C
Processes: 242 Uptime: 10h 19m Init: systemd v: 245 Compilers:
gcc: 10.1.0 Packages: 1199 pacman: 1193 snap: 6 Shell: Bash v: 5.0.18
running in: urxvtd inxi: 3.1.05
and here are a few lines from journalctl (I stripped my username):
Aug 22 09:55:56 systemd[1183]: Reached target Sound Card.
Aug 22 09:55:56 mtp-probe[5391]: bus: 1, device: 4 was not an MTP>
Aug 22 09:55:56 mtp-probe[5391]: checking bus 1, device 4: "/sys/>
Aug 22 09:55:56 kernel: USB Video Class driver (1.1.1)
Aug 22 09:55:56 kernel: usbcore: registered new interface driver >
Aug 22 09:55:56 kernel: input: USB Camera: USB Camera as /devices>
Aug 22 09:55:56 kernel: uvcvideo 1-1:1.0: Entity type for entity >
Aug 22 09:55:55 kernel: uvcvideo: Found UVC 1.00 device USB Camer>
Aug 22 09:55:55 kernel: usbcore: registered new interface driver >
Aug 22 09:55:55 kernel: usb 1-1: 3:1: cannot get freq at ep 0x84
Aug 22 09:55:55 kernel: videodev: Linux video capture interface: >
Aug 22 09:55:55 kernel: mc: Linux media interface: v0.10
Aug 22 09:55:55 mtp-probe[5350]: bus: 1, device: 4 was not an MTP>
Aug 22 09:55:55 mtp-probe[5350]: checking bus 1, device 4: "/sys/>
Aug 22 09:55:55 kernel: usb 1-1: SerialNumber: SN0001
Aug 22 09:55:55 kernel: usb 1-1: Manufacturer: USB Camera
Aug 22 09:55:55 kernel: usb 1-1: Product: USB Camera
Aug 22 09:55:55 kernel: usb 1-1: New USB device strings: Mfr=2, P>
Aug 22 09:55:55 kernel: usb 1-1: New USB device found, idVendor=0>
Aug 22 09:55:54 kernel: usb 1-1: new high-speed USB device number>
Audio section in
inxi
looks good. -
journalctl
output is stripped beyond the 80th column. -
What is the output of:
arecord --list-devices
Sorry sorry! Here’s journalctl again:
Aug 22 13:52:48 kernel: usb 1-1: 3:1: cannot get freq at ep 0x84
Aug 22 13:52:48 systemd[1186]: Reached target Sound Card.
Aug 22 13:52:48 mtp-probe[11017]: bus: 1, device: 4 was not an MTP device
Aug 22 13:52:48 mtp-probe[11017]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-1"
Aug 22 13:52:48 kernel: USB Video Class driver (1.1.1)
Aug 22 13:52:48 kernel: usbcore: registered new interface driver uvcvideo
Aug 22 13:52:48 kernel: input: USB Camera: USB Camera as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-1/1-1:1.0/input/input31
Aug 22 13:52:48 kernel: uvcvideo 1-1:1.0: Entity type for entity Camera 1 was not initialized!
Aug 22 13:52:48 kernel: uvcvideo 1-1:1.0: Entity type for entity Processing 2 was not initialized!
Aug 22 13:52:48 kernel: uvcvideo 1-1:1.0: Entity type for entity Extension 3 was not initialized!
Aug 22 13:52:48 kernel: uvcvideo 1-1:1.0: Entity type for entity Extension 4 was not initialized!
Aug 22 13:52:48 kernel: uvcvideo: Found UVC 1.00 device USB Camera (0c45:6366)
Aug 22 13:52:48 kernel: usbcore: registered new interface driver snd-usb-audio
Aug 22 13:52:48 kernel: videodev: Linux video capture interface: v2.00
Aug 22 13:52:48 kernel: mc: Linux media interface: v0.10
And here’s arecord --list-devices
**** List of CAPTURE Hardware Devices ****
card 1: Generic_1 [HD-Audio Generic], device 0: ALC887-VD Analog [ALC887-VD Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: Generic_1 [HD-Audio Generic], device 2: ALC887-VD Alt Analog [ALC887-VD Alt Analog]
Subdevices: 1/1
card 2: Camera [USB Camera], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Weird. that all looks good…
Does it work anywhere? (I.E. Cheese, Skype, …)
Nope, can’t get any audio through anywhere. This is the second webcam I’ve tried, though so I’d be surprised if it’s the webcam
After trying it on an ubuntu liveusb, then on my ubuntu laptop and then on a friend’s mac laptop, I think I can definitively say that it’s the camera. I guess it had nothing to do with the OS, after all. Thanks for the help!
