@nikgnomic pls checkout what I got
pacmd dump
Output:
### Configuration dump generated at Mon Dec 7 22:37:09 2020
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="1" name="usb-GENERAL_GENERAL_WEBCAM-02" card_name="alsa_card.usb-GENERAL_GENERAL_WEBCAM-02" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="0" name="pci-0000_00_1b.0" card_name="alsa_card.pci-0000_00_1b.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0 xauthority=/home/krtirtho/.Xauthority
load-module module-x11-xsmp display=:0 xauthority=/home/krtirtho/.Xauthority session_manager=local/krtirtho-tobefilledbyoem:@/tmp/.ICE-unix/909,unix/krtirtho-tobefilledbyoem:/tmp/.ICE-unix/909
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1b.0.analog-stereo 0xe66a
set-sink-mute alsa_output.pci-0000_00_1b.0.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1b.0.analog-stereo yes
set-source-volume alsa_input.usb-GENERAL_GENERAL_WEBCAM-02.mono-fallback 0x10000
set-source-mute alsa_input.usb-GENERAL_GENERAL_WEBCAM-02.mono-fallback no
suspend-source alsa_input.usb-GENERAL_GENERAL_WEBCAM-02.mono-fallback yes
set-source-volume alsa_output.pci-0000_00_1b.0.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1b.0.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_00_1b.0.analog-stereo 0x76d5
set-source-mute alsa_input.pci-0000_00_1b.0.analog-stereo no
suspend-source alsa_input.pci-0000_00_1b.0.analog-stereo yes
set-card-profile alsa_card.usb-GENERAL_GENERAL_WEBCAM-02 input:mono-fallback
set-card-profile alsa_card.pci-0000_00_1b.0 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_00_1b.0.analog-stereo
set-default-source alsa_input.usb-GENERAL_GENERAL_WEBCAM-02.mono-fallback
### EOF
pacmd list-cards
outputs:
2 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "1"
alsa.card_name = "GENERAL WEBCAM"
alsa.long_card_name = "GENERAL GENERAL WEBCAM at usb-0000:00:1a.0-1.1, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:1a.0-usb-0:1.1:1.2"
sysfs.path = "/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.2/sound/card1"
udev.id = "usb-GENERAL_GENERAL_WEBCAM-02"
device.bus = "usb"
device.vendor.id = "1b3f"
device.vendor.name = "Generalplus Technology Inc."
device.product.id = "2002"
device.product.name = "808 Camera"
device.serial = "GENERAL_GENERAL_WEBCAM"
device.form_factor = "webcam"
device.string = "1"
device.description = "808 Camera"
module-udev-detect.discovered = "1"
device.icon_name = "camera-web-usb"
profiles:
input:mono-fallback: Mono Input (priority 1, available: unknown)
input:multichannel-input: Multichannel Input (priority 1, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <input:mono-fallback>
sources:
alsa_input.usb-GENERAL_GENERAL_WEBCAM-02.mono-fallback/#0: 808 Camera Mono
ports:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: unknown)
properties:
index: 1
owner module: 7
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xf7c00000 irq 30"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "1c20"
device.product.name = "6 Series/C200 Series Chipset Family High Definition Audio Controller"
device.string = "0"
device.description = "Built-in Audio"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#1: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1b.0.analog-stereo/#2: Built-in Audio Analog Stereo
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: unknown)
properties:
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
amixer -c 1
outputs:
Simple mixer control 'Mic',0
Capabilities: cvolume cvolume-joined cswitch cswitch-joined
Capture channels: Mono
Limits: Capture 0 - 2
Mono: Capture 2 [100%] [50.00dB] [on]
