Hello
I have installed Manjaro on this machine 3 years ago (as soon as I bought it actually), but since a little more than 2 weeks, I have a very crappy WiFi. I thought it was an ISP problem at first (I don’t have other devices to check), but they didn’t find any problem on their side.
I started to look for related problems, and I tried several ones:
It didn’t change anything. I also didn’t find anyone who’s problem came a long time after installation
inxi:
Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6ab256b5-4041-4180-bab6-dda068075cca rw quiet apparmor=1
security=apparmor udev.log_priority=3 pcie_aspm=off ath10k_core.skip_otp=y
Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: ASUSTeK product: X541NA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X541NA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X541NA.313 date: 08/10/2017
ID-1: BAT0 charge: 24.3 Wh (93.1%) condition: 26.1/34.6 Wh (75.4%)
volts: 10.8 min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 1137
RAM: total: 3.7 GiB used: 2.45 GiB (66.2%)
Info: Quad Core model: Intel Pentium N4200 bits: 64 type: MCP arch: Goldmont
family: 6 model-id: 5C (92) stepping: 9 microcode: 44 cache: L2: 1024 KiB
bogomips: 8756
Speed: 1807 MHz min/max: 800/2500 MHz Core speeds (MHz): 1: 1807 2: 2388
3: 1844 4: 1571
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
flexpriority fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep ss sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq tsc_reliable vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spec_store_bypass status: Not affected
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Integrated
Graphics
vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5a84
class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 13d3:5a01 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 505 (APL 3) v: 4.6 Mesa 21.1.5
direct render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:0e.0 chip-ID: 8086:5a98
class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: e000 bus-ID: 02:00.0
chip-ID: 168c:0036 class-ID: 0280
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-4:5
chip-ID: 04ca:3010 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 313.62 GiB (67.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1J scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00
dev-links: cdrom
ID-1: / raw-size: 465.46 GiB size: 457.16 GiB (98.22%)
used: 313.62 GiB (68.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6ab256b5-4041-4180-bab6-dda068075cca
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 15C8-6DD2
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
Device-1: 1-4:5 info: Lite-On type: Bluetooth driver: btusb interfaces: 2
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 04ca:3010 class-ID: e001
Device-2: 1-5:3 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Device-3: 1-7:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 7 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 37.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2200
Processes: 222 Uptime: 8h 1m wakeups: 23431 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1521 pacman: 1518 lib: 441
flatpak: 0 snap: 3 Shell: Bash v: 5.1.8 running-in: gnome-terminal
inxi: 3.3.06
I know I don’t have the best machine, I’m planning on buying a new one, but I don’t have the means right now
