Wayland slightly lags every ~2 seconds on external monitor/2K res only
My browser (Firefox), and some games (mostly visible in Geometry Dash), run smoothly for ~2 seconds, then for a tiny bit drop/stutter to ~100fps.
Other visuals such as the selection box when you hold and move your mouse on the desktop, or just moving around a window seem to start off laggy, but “ramp up” to 144fps as you keep moving them.
This does not happen on my built-in laptop screen, it only happens on my external 2K screen. Both screens are 144hz. This also does not happen on X11, but i don’t want to use it as it often freezes on my favorite games. Bigger windows seem to lag more, and Geometry dash has stutters only if the window is a little bit bigger than 1K res.
From what i can tell this is probably related to either a high resolution, or using an external monitor in general
This might not be enough info, do ask more questions
inxi -zv8
  Kernel: 6.13.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
    root=UUID=03ee3d1a-f410-4f0c-a123-be0d24dfaa05 rw udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA507UV_FA507UV
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FA507UV v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: FA507UV.310
    date: 04/12/2024
  ID-1: BAT1 charge: 69.8 Wh (80.2%) condition: 87.0/90.2 Wh (96.5%)
    volts: 16.3 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: not charging
  System RAM: total: 16 GiB available: 14.91 GiB used: 9.73 GiB (65.2%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 5600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
    part-no: HMCG66AGBSA095N serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 8945H w/ Radeon 780M Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705206
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3311 min/max: 400/5263 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3311 2: 3311 3: 3311
    4: 3311 5: 3311 6: 3311 7: 3311 8: 3311 9: 3311 10: 3311 11: 3311 12: 3311
    13: 3311 14: 3311 15: 3311 16: 3311 bogomips: 127755
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
    avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s ports:
    active: none off: HDMI-A-1 empty: DP-9,eDP-2 bus-ID: 01:00.0
    chip-ID: 10de:28e0 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Phoenix3 vendor: ASUSTeK
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
    bus-ID: 65:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 44.0 C
  Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:2233
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: radeonsi
    gpu: amdgpu,nvidia,nvidia-nvswitch d-rect: 4480x2520 display-ID: 0
  Monitor-1: HDMI-A-1 pos: primary,top-left model: Samsung Odyssey G50A
    serial: <filter> built: 2022 res: mode: 2560x1440 hz: 144 scale: 100% (1)
    dpi: 109 gamma: 1.2 chroma: red: x: 0.686 y: 0.310 green: x: 0.263
    y: 0.671 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 3840x2160, 1920x1080, 1680x1050, 1600x900, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97
  Monitor-2: eDP-1 pos: bottom-r model: AU Optronics B156HAN15.H built: 2022
    res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2 chroma:
    red: x: 0.651 y: 0.329 green: x: 0.298 y: 0.620 blue: x: 0.149 y: 0.059
    white: x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: radeonsi
    x11: drv: radeonsi
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: amd mesa v: 24.3.4-arch1.1
    gfx1103_r1 LLVM 19.1.7 DRM 3.61 6.13.5-2-MANJARO) device-ID: 1002:1900
    memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Laptop GPU driver: N/A device-ID: 10de:28e0
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
    Radeon Graphics (RADV GFX1103_R1) driver: N/A device-ID: 1002:1900
  Device-1: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 65:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 65:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 65:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-5: Jieli IGH4000 driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.1:3
    chip-ID: 4c4a:4155 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.13.5-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
    vendor: AzureWave driver: rtw89_8852be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:b852
    class-ID: 0280
  Device-3: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.3:5
    chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
  IF: enp103s0f3u1u3 state: down mac: <filter>
  Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
    rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 13d3:3571
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 476.94 GiB used: 79.6 GiB (16.7%)
    model: MZVL8512HELU-00BTW size: 476.94 GiB block-size: physical: 512 B
    fw-rev: KXJ72W1Q temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 79.6 GiB (17.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 03ee3d1a-f410-4f0c-a123-be0d24dfaa05
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 8B45-3963
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-2:2 info: Logitech USB Receiver type: mouse,keyboard,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
  Device-2: 1-4:3 info: Sonix USB2.0 HD UVC WebCam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 322e:2233 class-ID: 0e02
  Device-3: 1-5:4 info: IMC Networks Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 13d3:3571 class-ID: e001 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 5-1.1:3 info: Jieli IGH4000 type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-2: 5-1.2:6 info: Microdia Redragon Mitra RGB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
    chip-ID: 0c45:5004 class-ID: 0301
  Device-3: 5-1.3:5 info: Realtek RTL8152 Fast Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 2.0
  Hub-7: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-9: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 53.4 C mobo: 43.2 C gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): cpu: 2800
  Packages: 1495 pm: pacman pkgs: 1487 libs: 472 tools: pamac pm: flatpak
    pkgs: 8
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    5: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    6: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    8: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 370
  1: cpu: 48.0% command: kwin_wayland pid: 1977 mem: 398.8 MiB (2.6%)
  2: cpu: 27.0% command: firefox pid: 42807 mem: 1609.0 MiB (10.5%)
  3: cpu: 11.9% command: firefox pid: 2942 mem: 835.0 MiB (5.4%)
  4: cpu: 8.0% command: firefox pid: 51254 mem: 389.2 MiB (2.5%)
  5: cpu: 5.2% command: steamwebhelper pid: 3857 mem: 626.3 MiB (4.1%)
  Memory top: 5 of 370
  1: mem: 1609.0 MiB (10.5%) command: firefox pid: 42807 cpu: 27.0%
  2: mem: 835.0 MiB (5.4%) command: firefox pid: 2942 cpu: 11.9%
  3: mem: 774.5 MiB (5.0%) command: baloo_file_extractor pid: 13768
    cpu: 0.0%
  4: mem: 626.3 MiB (4.1%) command: steamwebhelper pid: 3857 cpu: 5.2%
  5: mem: 614.3 MiB (4.0%) command: plasmashell pid: 2523 cpu: 0.5%
  Processes: 370 Power: uptime: 4h 55m states: freeze,mem,disk suspend: s2idle
    image: 5.92 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 257
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
Just gathering a little more information that might be useful to those wishing to help.
  • Are you using a KVM of some kind; if so, provide information about that.
  • Or, are you slaving the monitor(s) directly from laptop graphic outputs?
  • Please provide details about the cables/connectors used.
I’m sure someone will offer assistance as soon as they are able. Note that weekends are sometimes a little slow.
My monitor is connected via HDMI, directly from the port on the side of my laptop to the monitor. I also tested a 1K 100hz monitor, different cable too, but the external monitor still has similar issues. It’s not a big issue, the contents of most windows are smooth, It may even be simply how Wayland works but since i haven’t seen anyone report this kind of issue, it may just be a few that have this.
