Wayland, Login and splash screen isnt visible
When i put my laptop on sleep and open it again this is what i get, if i type in my password it will show me the main desktop and things work perfectly its just that splash screen and login form are not visible as it can be seen in the image.
Complete System Information
  Kernel: 5.16.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.16-x86_64
    root=UUID=743a4304-0427-41b0-a08e-fec1f1e988ef rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=vendor
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
  Mobo: HP model: 87B1 v: 31.23 serial: <superuser required> UEFI: AMI
    v: F.25 date: 08/18/2021
  ID-1: BAT0 charge: 32.5 Wh (68.1%) condition: 47.7/47.7 Wh (100.0%)
    volts: 11.6 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: N/A status: discharging cycles: 429
  RAM: total: 7.19 GiB used: 3.78 GiB (52.5%)
  RAM Report:
  Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600106
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1433 high: 1844 min/max: 1400/3000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1396
    3: 1397 4: 1391 5: 1393 6: 1389 7: 1394 8: 1389 9: 1844 10: 1420 11: 1397
    12: 1397 bogomips: 71897
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: nvidia v: 470.103.01
    alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1f99 class-ID: 0300
  Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1636
    class-ID: 0300
  Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
    bus-ID: 3-3:3 chip-ID: 0408:5365 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
    compositor: kwin_wayland driver: X: loaded: modesetting gpu: nvidia,amdgpu
    display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
  OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.16.20-2-MANJARO)
    v: 4.6 Mesa 22.0.3 direct render: Yes
  Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound Server-1: ALSA v: k5.16.20-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.51 running: yes
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: speed: Unknown
    lanes: 63 link-max: gen: 6 speed: 64 GT/s port: e000 bus-ID: 02:00.0
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF-ID-1: br-422dabb5f04a state: down mac: <filter>
  IF-ID-2: br-7cbe40212edd state: down mac: <filter>
  IF-ID-3: br-ab9953022f69 state: down mac: <filter>
  IF-ID-4: br-cbb0dd38796b state: down mac: <filter>
  IF-ID-5: br-d469c65ad241 state: down mac: <filter>
  IF-ID-6: br-e0483103e4b3 state: down mac: <filter>
  IF-ID-7: br-fb6f70e9d722 state: down mac: <filter>
  IF-ID-8: br-fb8b751b6cb8 state: down mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-9: docker0 state: down mac: <filter>
  IF-ID-10: docker_gwbridge state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-11: veth119f877 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
  Local Storage: total: 1.36 TiB used: 241.36 GiB (17.3%)
    model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
    rev: 211210WD temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    type: HDD rpm: 5400 serial: <filter> rev: 7C scheme: GPT
  ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
    used: 37.46 GiB (38.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: 743a4304-0427-41b0-a08e-fec1f1e988ef
  ID-2: /boot/efi raw-size: 518.7 MiB size: 517.6 MiB (99.80%)
    used: 576 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: NO_LABEL
    uuid: 6497-3A88
  ID-3: /home raw-size: 301.76 GiB size: 301.76 GiB (100.00%)
    used: 203.9 GiB (67.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: bc6344b2-5481-4008-a3de-03f6d61d1917
  ID-4: /run/timeshift/backup raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
  ID-5: /var/cache raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
  ID-6: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: zram size: 7.19 GiB used: 1.8 MiB (0.0%) priority: 100
    dev: /dev/zram0
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
    uuid: 64E3-F61C
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 367.32 GiB fs: ntfs
    label: Windows uuid: 67FC557B9811BE1A
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 522 MiB fs: ntfs
    label: Windows RE tools uuid: 2BC478AA0508AED6
  ID-5: /dev/sda3 maj-min: 8:3 size: 628.98 GiB fs: ntfs label: Local Disk
    uuid: 3022E1E322E1ADD2
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-2:2 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
  Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Microdia USB Keyboard type: Keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 0c45:7603 class-ID: 0301
  Device-2: 3-3:3 info: Quanta HP TrueVision HD Camera type: Video
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 408 Uptime: 1h 5m wakeups: 2 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1526 pacman: 1517 lib: 363
  flatpak: 9 Shell: Zsh v: 5.8.1 running-in: yakuake inxi: 3.3.15
you are using wayland with nvidia on kde and you expect it to work? … dont use wayland, switch to x11
Nvidia driver are not enabled actually, by default it uses my Amd APU GPU… its a laptop so i have to switch to nvidia to use which i dont do it like never its just install… that is all
so if you run this command: nvidia-smi are your drivers loaded…
but still wayland on kde is buggy, dont use it…
UI really feels alot more alive and responsive on Xorg its not…
āÆ glxinfo|egrep "OpenGL vendor|OpenGL renderer"
OpenGL vendor string: AMD
OpenGL renderer string: AMD RENOIR (LLVM 13.0.1, DRM 3.44, 5.16.20-2-MANJARO)
nvidia-smi
Screenshot_20220518_145124
i have the opposite on wayland its laggy, glitches, on xorg its very smooth …
Interesting in mine laptop, intial UI load really slow even though its on SSD and on wayland it load in an instant… and app switching works really amazing…
Fedora has really great implementation but in customisation seems alot to be desired on gnome side of things…
you can go to system settings/ screen locking and uncheck ā€˜after waking from sleep’ click apply
then go to system settings/ sddm click on behaviour and check automatically log in… click apply
Thanks will use this workaround for now, no option i guess…
Tested work like a charm…
maybe there is some option how to fix it on wayland, but i dont know how, so at least i suggested those options in system settings…
will look into it later but using this workaround for now… thanks
