Wayland keeps reverting back to X org after restart
I log out and select wayland as the option. It works but after a restart it automatically switches back to x org. I am using a 5700xt so that should not be a issue.
Maybe you have a default set in /etc/sddm.conf.d/ ?
I do have virtualkeyboard.conf and 00_manjaro_settings.conf.
In 00_manjaro_settings.conf I only see information about my current theme but nothing about wayland or x org.
Is there any way to add Wayland as a default in 00_manjaro_settings.conf? Thanks.
Are you using automatic login, i.e. you are not required to enter your password at the sddm login screen?
If so:
System Settings > Startup and Shutdown > Login Screen (SDDM) > Behavior…
After “with session”, select Wayland in the pull-down menu.
Thanks this works!
