I get the following popups showing up after every login:
Wayland Diagnose
It is recommended to install Input Method Panel Gnome Extensions…
If I follow the link, then I end up with a page showing this error message:
No such native application org.gnome.chrome_gnome_shell
Any idea what I should do with this?
Welcome to the Manjaro Community @kuropka
I have moved your post to a separate support topic.
I’m assuming you are using GNOME. A quick web search indicates that the:
message is related to either the fcitx or fcitx5 input method package. If you do not use any special keyboard layouts or input methods, then you could probably just remove those packages if nothing else requires them.
If you do use custom input methods/keyboard layouts, then you may need to configure them via the relevant configuration tool: fcitx-configtool or fcitx5-configtool. Both of those tools can be installed via Manjaro’s package manager.
