I recently installed Manjaro 22.0 with Gnome/Wayland on a spare PC to test the Intel ARC A750 GPU. After just a little tweaking it is running Steam and several DX11 games pretty well. I am fairly new to Manjaro but I like it enough that I’m considering installing on my normal gaming PC with a Nvidia GPU. I tried a wayland distro about a year ago and it had strange issues with Nvidia. Just wondering if anyone has had good luck with wayland/Nvidia before I go for it.
Thanks
My gaming PC is : Intel i5-13600 CPU with Nvidia RTX 3060ti GPU, 32GB DDR5, MSI Z690 MB
Any reason you would want Wayland with Nvidia? Personally I would stick with the default X11 I don’t see a benefit that would weight more than the problems you may/will have with Wayland.
I’m sure that Wayland/Nvidia situation is not quite ready yet. I feel it will take some time to adapt to a newer and hopefully more efficient protocol. I like the wayland model in theory, especially for gaming. Reduced latency is possible with client-side rendering, and code may be simpler, which could mean faster. I know a lot of legacy applications will have to be rewritten but I think eventually Wayland will be adopted as a standard. Like anything new it takes time to implement. The fact that it is a little tricky with Nvidia makes me want to install a wayland based system and play with it - kind of a challenge
