Hi,
Waydroid is out and it appears to be working on arm devices. However, I’m having trouble locating the boot file they speak of in the guide. Does the pinebook pro KDE DE store the boot config in a different location? Where do you input line:
binder.devices=“anbox-binder,anbox-hwbinder,anbox-vndbinder,binder,hwbinder,vndbinder”
The boot file is in /boot/extlinux/extlinux.conf in Manjaro ARM.
And you don’t need to run ./mkscr as it only rebuilds the boot.txt boot script, which we don’t use.
I would be interested in knowing if you get it to work.
Unfortunately it did not work. I got the error message below:
modprobe: FATAL: Module binder_linux not found in directory /lib/modules/5.13.7-1-MANJARO-ARM
modprobe: FATAL: Module ashmem_linux not found in directory /lib/modules/5.13.7-1-MANJARO-ARM
mkdir: cannot create directory ‘/dev/binderfs’: File exists
ERROR: Binder and ashmem nodes not found!
anbox-net is already running
chmod: cannot access '/run/user/1000/gvfs': Permission denied
chmod: cannot access '/dev/sw_sync': No such file or directory
chmod: cannot access '/sys/kernel/debug/sync/sw_sync': No such file or directory
chmod: cannot access '/dev/Vcodec': No such file or directory
chmod: cannot access '/dev/MTK_SMI': No such file or directory
chmod: cannot access '/dev/mdp_sync': No such file or directory
chmod: cannot access '/dev/mtk_cmdq': No such file or directory
chmod: cannot access '/dev/video32': No such file or directory
chmod: cannot access '/dev/video33': No such file or directory
chmod: cannot access '/dev/graphics/*': No such file or directory
lxc-start: anbox: cgroups/cgroup2_devices.c: bpf_program_load_kernel: 334 Function not implemented - Failed to load bpf program: (null)
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/ion" onto "/usr/lib/lxc/rootfs/dev/ion"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/kgsl-3d0" onto "/usr/lib/lxc/rootfs/dev/kgsl-3d0"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/mali0" onto "/usr/lib/lxc/rootfs/dev/mali0"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/pvr_sync" onto "/usr/lib/lxc/rootfs/dev/pvr_sync"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/pmsg0" onto "/usr/lib/lxc/rootfs/dev/pmsg0"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/graphics/fb0" onto "/usr/lib/lxc/rootfs/dev/graphics/fb0"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/fb1" onto "/usr/lib/lxc/rootfs/dev/fb1"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/graphics/fb1" onto "/usr/lib/lxc/rootfs/dev/graphics/fb1"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/fb2" onto "/usr/lib/lxc/rootfs/dev/fb2"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/graphics/fb2" onto "/usr/lib/lxc/rootfs/dev/graphics/fb2"
lxc-start: anbox: utils.c: mkdir_p: 234 Read-only file system - Failed to create directory "/usr/lib/lxc/rootfs/sys/module/lowmemorykiller"
lxc-start: anbox: conf.c: mount_entry_create_dir_file: 2410 Read-only file system - Failed to create directory "/usr/lib/lxc/rootfs/sys/module/lowmemorykiller"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/vendor" onto "/usr/lib/lxc/rootfs/vendor_extra"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/sw_sync" onto "/usr/lib/lxc/rootfs/dev/sw_sync"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/Vcodec" onto "/usr/lib/lxc/rootfs/dev/Vcodec"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/MTK_SMI" onto "/usr/lib/lxc/rootfs/dev/MTK_SMI"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/mdp_sync" onto "/usr/lib/lxc/rootfs/dev/mdp_sync"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/mtk_cmdq" onto "/usr/lib/lxc/rootfs/dev/mtk_cmdq"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/video32" onto "/usr/lib/lxc/rootfs/dev/video32"
lxc-start: anbox: utils.c: safe_mount: 1198 No such file or directory - Failed to mount "/dev/video33" onto "/usr/lib/lxc/rootfs/dev/video33"
lxc-start: anbox: utils.c: open_devnull: 1209 No such file or directory - Can't open /dev/null
lxc-start: anbox: conf.c: run_buffer: 323 Script exited with status 126
lxc-start: anbox: start.c: lxc_end: 996 Failed to run lxc.hook.post-stop for container "anbox"
The green arch does appear on the screen, with the bubble going over on, for 5-10 secs and crashes.
Uninstalled Anbox and same result. Will probably wipe / start fresh on Beta13 once its out.
Is the binder.devices=“anbox-binder,anbox-hwbinder,anbox-vndbinder,binder,hwbinder,vndbinder” at the end of /boot/extlinux/extlinux.conf still required?
Or should this be sufficient? sudo pacman -S waydroid-image sudo waydroid init -f sudo systemctl enable waydroid-container --now
