I did an update which seems to have solved my issues. I still have no clue about what happened, I can provide more information if you tell me how. The Sway Service session still does not work, and redirect to the login screen after failing to load services. I still have a gray screen for few secs when openning my session but maybe it is normal ?
Still, thanks for the update !
Yes, that is fine-ish (still looking to speed that up eventually).
Hello again,
I’m dusting off this thread after a similar issue with waybar after another system update.
This time it seems despite updating to the most recent version of waybar (0.10.3-1). Whenever it runs I get the following error message
waybar.sh[3340]: waybar: error while loading shared libraries: libspdlog.so.1.13
The most recent version of spdlog is installed (1.14)
This really just seems to be a conflict with wherever the file is being launched from despite updating, reinstalling, running skel then reloading sway.
I know the most recent version of waybar is installed according to pacman, however I cannot get a --version flag from waybar in the cli, it just shoots back the same error pasted above.
So my next step was locating all of the files for the package
pacman -Ql waybar
I have abbreviated the output to the complete paths
/etc/xdg/waybar/config.jsonc
/etc/xdg/waybar/style.css
/usr/bin/waybar
/usr/lib/systemd/user/waybar.service
/usr/share/licenses/waybar/LICENSE
… /man/pages
At this point I’m not sure what I need to replace or modify. I have not bothered with trying to play with the systemd unit files and it seems unrelated to this problem.
How do I ensure the correct version of Waybar is being launched?
I think that is the wrong question. Waybar needs to be rebuilt for ARM with the current toolchain. I pinged the @Manjaro-Arm about it multiple times, as I don’t have the permissions and tools to do so.
Looks like arch-arm maintains waybar. The latest version in unstable was built 5 days ago.
[ray@jellyfin ~]$ sudo pacman -Si waybar
Repository : extra
Version : 0.10.3-1
Description : Highly customizable Wayland bar for Sway and Wlroots based
compositors
Architecture : aarch64
URL : https://github.com/Alexays/Waybar/
Licenses : MIT
Groups : None
Provides : None
Depends On : atkmm cairomm fmt gcc-libs glib2 glibc glibmm
gtk-layer-shell gtk3 gtkmm3 jack jsoncpp
libdbusmenu-gtk3 libevdev libinput libmpdclient libnl
libpipewire libpulse libsigc++ libwireplumber
libxkbcommon playerctl sndio spdlog systemd-libs upower
wayland libatkmm-1.6.so=1-64 libcairomm-1.0.so=1-64
libgtk-3.so=0-64 libjack.so=0-64 libjsoncpp.so=25-64
libpipewire-0.3.so=0-64 libsndio.so=7-64
libspdlog.so=1.14-64 libudev.so=1-64 libupower-glib.so=3-64
Optional Deps : otf-font-awesome: Icons in the default configuration
Conflicts With : None
Replaces : None
Download Size : 661.51 KiB
Installed Size : 2358.99 KiB
Packager : Arch Linux ARM Build System <builder+n1@archlinuxarm.org>
Build Date : Tue 07 May 2024 03:35:17 PM CDT
Validated By : MD5 Sum SHA-256 Sum Signature
