I’m new to Manjaro-sway. When I edit the waybar config in ~/.config/waybar/ (to remove some of the modules I don’t need) and reload, the config seems to get overwritten by the default config, and the bar remains unchanged. Is there a way to stop this from happening?
which version are you using?
From the terminal:
Manjaro-sway Linux 5.10.59-1-MANJARO x86_64 21.1.0 Pahvo
Does the version affect whether the config gets overwritten?
First of all it looks like you are using the sway edition on x86 PCs, which is a different setup than the ARM one. But even for the ARM one the version matters as we did some rework on the config and theming stuff the last months…
I can’t move this to x86, perhaps sb could do this?
anyway. it think you may not be using our new and shiny override mechanism. here an example how this should work:
cp .config/waybar/config.jsonc.example .config/waybar/config.jsonc
- edit
"modules-left": [
"sway/workspaces",
"custom/scratchpad"
- super + shift + c
this way you removed the menu icon.
Yeah that’s the issue. I could edit the config file (config.jsonc equivalent?), but saving and pressing super + shift + c returns the config file back to the pre-edit state. This happens, for example, when I try to remove the “custom/menu” line under “modules-left”.
Sorry. Have changed flag to reflect it’s not ARM.
did you update the manjaro-sway/manjaro-sway-settings package? the only explanation I have is that probably your settings package ist very(!) old and still has the generator mechanism.
You’re right! My version of manjaro-sway was somehow bad… I had to pass -Syuu in pacman to downgrade mine to the community version (I usually just do -Syu). This allowed my waybar configs to persist.
Thank you!
that is exactly wrong. you should use the newest one (from the manjaro-sway repo).
